UPDATED VERSION 12.0
Updated - version 11
NO PC REQUIRED
@SirTimmyTimbit
Edited by BigLarry
Updated to version 11
What's New in Version 7.0 See changelog
Version 7 - Added Transformers & Mortal Kombat lockscreen.
Added option for black or gray background.
Small tweaks including: Improved Replay profile appearance & improved readability of some colors.
With version 7.0:- Download
