UPDATED VERSION 12.0
Updated - version 11
NO PC REQUIRED
@SirTimmyTimbit
Edited by BigLarry
Updated to version 11
What's New in Version 6.0 See changelog
ANOTHER LARGE UPDATE. THE THEME SEEMS TO BE NEARING IT'S LIKELY FINAL FORM AS IT'S AT THE MAX LIMIT OF BOTH CHIP MEMORY & PHYSICAL SPACE WITHIN THE SCREENS.
I SPENT HOURS COMBING THROUGH EVERY DETAIL TO GET THIS THEME VERY PROFESSIONAL IN THIS UPDATE. I CAN'T LIST EVERYTHING BUT A FEW THINGS I REMEMBER ARE...
THE STATUS BAR THAT HOUSES THE BATTERY, TIME, & COLOR SHORTCUT HAVE BEEN RESIZED, RECOLORED, & REWORKED.
EVERY SINGLE SCREEN WAS COMBED THROUGH TO GET EVERY THING PERFECT.
SPECIAL ATTENTION GIVEN TO WHAT MENUS ROUND ROBIN & WHERE THE HIGHLIGHTED SELECTION STARTS TO MAKE THEME AS USER FRIENDLY AS POSSIBLE.
THE COLORS ON EACH THEME WERE TWEAKED, SOME HEAVILY SO.
MATERIALS UPDATED IN MY ESCRIBE SETTINGS. I ALWAYS POST THESE WITH MY THEME UPDATES.
I ADDED SS904L SINCE POPULAR TANKS LIKE THE FREEMAX & CROWN USE THAT WIRE TYPE.
MATERIAL EDIT TO SS316L TO GET MORE RELIABLE TC THROUGH TESTS & BUILDS COMPLETED LAST NIGHT.
FIXED ISSUE OF WATTAGE TEXT GETTING CUT OFF WHEN THEME WAS IN BOTH REPLAY MODE & OVER 100 WATTS OR MORE. IT WORKED FINE BUT LOOKED UGLY. NOW IT DOESN'T.
With version 6.0:- Download
