laurie9300 Posted July 15, 2015 Author Report Posted July 15, 2015 I own a variety of Temp mods and I have found myself varying the temp far more than the wattage.Is it possible to re-map the up/down buttons to directly adjust temp instead of wattage?Love my DNA20, Love my DNA30s, Love my DNA40s........looking forward to my 200!
dwaindablane Posted July 16, 2015 Report Posted July 16, 2015 Now that would be a cool idea, when in temp mode put the temp control directly on the up/down keys and watts on the locked menu up/down keys.
retird Posted July 16, 2015 Report Posted July 16, 2015 Doing this as a option one might choose might be a good idea but there are those of us who change wattage more than temp so as long as it's not the default setting to change temp with up/down buttons it would be just another option I guess...
Dejay Posted July 19, 2015 Report Posted July 19, 2015 I REALLY want this option. It's basically variable temperature instead of variable watts.I just set my power to max and change temp only. But clicking five times, holding up down awkwardly, adjusting and then clicking five times again is absurdly complicated. I would play around with temperature far more often if it was easier. I really hope this is added to escribe as an option.
VapingBad Posted July 19, 2015 Report Posted July 19, 2015 Then it will be like a mech in that you will be setting the power by how you build your atomiser. A small single coil and large dual coil set ups will give a very different vape at temp x max watts.
letsavit Posted July 20, 2015 Report Posted July 20, 2015 I run at temp, not watts, it's the primary setting I use. Pressing a sequence of 12 buttons to change the temp is too much, also flashing "temp protection" on screen gives me no feedback in use, showing the temp the coils at ( or fluctuating at) on screen around all the variables (my build, tank, juice etc. sometimes with human error..!) would be far more useful to myself.
John Posted July 20, 2015 Report Posted July 20, 2015 You can already turn off the temperature protected message. It is a setting in Escribe. You can also make it show the temperature in the main display.
laurie9300 Posted July 22, 2015 Author Report Posted July 22, 2015 John said:You can already turn off the temperature protected message. It is a setting in Escribe. You can also make it show the temperature in the main display. any thoughts on my original question?
blueridgedog Posted August 2, 2015 Report Posted August 2, 2015 This would be fantastic on a profile by profile basis...for any TC profile, my watts is typically the max or so high it is never adjusted during vaping. Only way now is different profiles with set temps.
bingwhip Posted September 27, 2015 Report Posted September 27, 2015 Wanted to bump this. I searched for this feature request and really would like to see this. I keep my watts pretty much always set, and often depending on juice/mood/ambient temperature, find myself wanting to change temperature. And while I've gotten pretty good at 5click/one finger double button/adjust, I would REALLY like temp to be adjustable instead of wattage. Make it an option like others have suggested, set up by profile on escribe.
Mad Scientist Posted September 27, 2015 Report Posted September 27, 2015 I had also asked about this. In the mean time, I plan to add a third button the the mod that is "both" -- function is to make the DNA 200 think both buttons are pressed (the buttons both use ground as common so any momentary contact N.O. double pole switch in parallel across the up/down button pads on the board or a single pole switch connected through steering diodes will work fine). It also helps to change the lock sequence to 3 clicks instead of 5.I likewise seem to change temp often enough and I want to be able to do it more easily (like while driving).While we're at it lol, 10 degrees F per click is too much. I'd like to be able to set the increment as a parameter also.And as long as I'm daydreaming on the topic lol, having to hold "both" for 2 seconds is too much. If I press both that means I want the function of pressing both -- do I also have to let it know I really mean it by holding for 2 seconds lol.
VapingBad Posted September 27, 2015 Report Posted September 27, 2015 +1I'd like to be able to set the increment as a parameter also.I find myself setting temps like 394 & 396 F in profiles via Escribe ATM.
Dejay Posted October 25, 2015 Report Posted October 25, 2015 Any news about this? I've heard on reddit evolv is working on this feature. Is there another post or thread about this topic?EDIT: Never mind I found the thread (way more discussion there) https://forum.evolvapor.com/topic/66948-topic/?do=findComment&comment=902253
