dwcraig1 Posted April 25, 2016 Report Posted April 25, 2016 While I think an RMA is the best way to go I was still hoping to see the voltage readings taken off the pads where the balance connector connects to the DNA200 board. Just curious if it's a problem with the DNA board or the daughter board.
black lace Posted April 25, 2016 Report Posted April 25, 2016 I do to but i have never had any feedback from evolv on what the problem had been on boards ive sent in, i would have thought as a time and production thing it would have gone straight in the bin.. might be different with the one in question if they keep turning up,,,, see what turns up in the wash..
BillW50 Posted April 25, 2016 Report Posted April 25, 2016 dwcraig1 said:While I think an RMA is the best way to go I was still hoping to see the voltage readings taken off the pads where the balance connector connects to the DNA200 board. Just curious if it's a problem with the DNA board or the daughter board. Me too. But a bad output of one board doesn't necessarily mean that the input side of the other board (DNA board) isn't loading the output (Protection board).
jtdien Posted April 25, 2016 Author Report Posted April 25, 2016 The power from the daughter board to the DNA chip was ~7.4v. I can't see what else is wrong unless its the DNA chip itself.It is working in Power Supply mode but the moment i change it to the Lipo in 2S it just doesnt stay on.
VapingBad Posted April 25, 2016 Report Posted April 25, 2016 jtdien said:The power from the daughter board to the DNA chip was ~7.4v. I can't see what else is wrong unless its the DNA chip itself.It is working in Power Supply mode but the moment i change it to the Lipo in 2S it just doesnt stay on.The voltages on the balance connector pins on the DNA side not the main ones, they are very sensitive to resistance like a dry joint as they are very low current connections.
BillW50 Posted April 25, 2016 Report Posted April 25, 2016 What would be interesting to know is at the balance connection on the DNA. What pin 1, 2, and 3 reads in respect to ground. 1 should read the voltage of cell 1. 2 should read the total of cell 1 and cell 2. And 3 since this is a two cell DNA should read the same as pin 2. But I assume you have it all back together. So I would just wait until you had it apart again.UPDATE: Oh VapingBad was replying too and I didn't see it until after I posted.
jtdien Posted April 25, 2016 Author Report Posted April 25, 2016 I'll definitely give that a try tonight and give the readouts from pins 1-3 in respect to ground from both the DNA chip and the daughter board
BillW50 Posted April 25, 2016 Report Posted April 25, 2016 Well readings from the daughter board isn't important unless the readings are incorrect on the DNA side.
jtdien Posted May 5, 2016 Author Report Posted May 5, 2016 Just an update for you guys. I had it sent to Evolv and they indicated it was a blown fuse despite the fuse looking fine physically.
jtdien Posted May 5, 2016 Author Report Posted May 5, 2016 Oops... forgot to thank everyone for the troubleshooting assistance. It was definitely annoying but fun hahaCheers!
Ampule Posted May 6, 2016 Report Posted May 6, 2016 Hi just caught up with this thread. I had exactly the same issue, turns out I had changed the battery cell number in Escribe during some battery testing and forgot to change is back to the 2 cell setting. Instant fix
