rsrider Posted July 8, 2016 Author Report Share Posted July 8, 2016 Hey I have a problem with my MOD Box i soldered everything right the Balancer is reading the 2x 18650 Batterys but doesnt charge it what can be the reason for this ? Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted July 8, 2016 Report Share Posted July 8, 2016 welcome rsrider...........do you have everything correctly selected in escribe regarding two cell operation? will the mod charge with a wall usb charger? if you select diagnostic in device monitor, select "set usb current limit" to 1 amp what happens Link to comment Share on other sites More sharing options...
rsrider Posted July 8, 2016 Author Report Share Posted July 8, 2016 yes 2 cells and when i make the batterie test it failes. I Set the A to 1 and nothing happens Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted July 8, 2016 Report Share Posted July 8, 2016 rsrider said: yes 2 cells and when i make the batterie test it failes. I Set the A to 1 and nothing happens Expand i have never seen this screen before when using escribe, lol. where is this particular "functional tests" page? is this somethiñg you made? Link to comment Share on other sites More sharing options...
rsrider Posted July 8, 2016 Author Report Share Posted July 8, 2016 this page is under tools -> production utility Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted July 8, 2016 Report Share Posted July 8, 2016 rsrider said: this page is under tools -> production utility Expand never noticed it. go into device monitor and try what i said. set your usb current to 1 amp. what is your battery's watt hour? total. anyone else feel free to chime in with any ideas. Link to comment Share on other sites More sharing options...
rsrider Posted July 8, 2016 Author Report Share Posted July 8, 2016 i did the amp limit to 1A but nothing happend.my batteries are 2x 18650 Sony Vtc5 2600mah each Set to 17,77 Whmy wiring is like that https://s3-us-west-2.amazonaws.com/cdn-nonameboxmods-com/dna-200-dual-18650-wiring.pdf Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted July 8, 2016 Report Share Posted July 8, 2016 as long as you're positive your wiring looks like this, then it's correct.did the mod ever charge? try a few other usb cables. you could also double check what you input for your watt hours, make sure you typed it in correctly. try a soft and a hard reboot. Link to comment Share on other sites More sharing options...
rsrider Posted July 8, 2016 Author Report Share Posted July 8, 2016 yes wiring ist the same.tryed hard reset and soft reset nothing changes.no its the first time i try to charge i build it today.thx for your help Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted July 8, 2016 Report Share Posted July 8, 2016 is it possible for you to take some close up pictures of the board, mainly the lower bottom half of the board, both front and back? maybe you have some missing board components or a problem with the balance taps and/or battery wire soldering somewhere. Link to comment Share on other sites More sharing options...
rsrider Posted July 8, 2016 Author Report Share Posted July 8, 2016 Is that normal when no batteries in the Box ?i will make pictures tomorrow ty Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted July 8, 2016 Report Share Posted July 8, 2016 yes that's normal. no batteries when plugged into escribe creates sporadic battery readings. ok, post some pics when you can tomorrow. Link to comment Share on other sites More sharing options...
VapingBad Posted July 9, 2016 Report Share Posted July 9, 2016 It will probably not ever reach 1 A off a PC most of them restrict the current to 500 mA and your battery should be below 4 V. I see yours were < 4 V and current was 0 so it not those. I tend to turn this test off on the Production until as I only occasional make a mod to sell and always test it vaping for a while. Does it charge normally from a USB supply? Link to comment Share on other sites More sharing options...
dwcraig1 Posted July 9, 2016 Report Share Posted July 9, 2016 Just to add to the above ^^^When the mod sees a data path the max amperage is 500 ma. Link to comment Share on other sites More sharing options...
BillW50 Posted July 9, 2016 Report Share Posted July 9, 2016 Are you sure it has to do with a data path? My XTAR VC4 battery chargers for example, also limits the current draw depending on what you plug the USB into (doesn't use the data connection). There are tons of devices that all work similar. And from observation, I think they operate by monitoring the USB voltage. The more current you draw, the lower the voltage will be on most supplies (including computers, wall chargers, etc). And I think they monitor the voltage and only draw as much as to keep the voltage high enough. Link to comment Share on other sites More sharing options...
dwcraig1 Posted July 9, 2016 Report Share Posted July 9, 2016 BillW50 said: Are you sure it has to do with a data path? My XTAR VC4 battery chargers for example, also limits the current draw depending on what you plug the USB into (doesn't use the data connection). There are tons of devices that all work similar. And from observation, I think they operate by monitoring the USB voltage. The more current you draw, the lower the voltage will be on most supplies (including computers, wall chargers, etc). And I think they monitor the voltage and only draw as much as to keep the voltage high enough. Expand I found this much,https://forum.evolvapor.com/topic/68472-topic/?do=findComment&comment=915836 Link to comment Share on other sites More sharing options...
BillW50 Posted July 9, 2016 Report Share Posted July 9, 2016 That is very strange. I have a power only USB cable here and plug that in this machine's USB port and the Triade is only drawing 400ma. Plug the same Triade and cable into a XTAR's USB power adapter (5v @ 2.1A) and the Triade draws 800ma. Yet plug in my USB TV tuner in the same USB port on this computer and it draws 900ma. Link to comment Share on other sites More sharing options...
BillW50 Posted July 9, 2016 Report Share Posted July 9, 2016 VapingBad said: It will probably not ever reach 1 A off a PC most of them restrict the current to 500 mA... Expand I don't think most computers restrict ports to 500ma. At least the many that I have seen don't. Like this machine has four USB2 ports. And I have seen over 900ma being drawn over one port. I think most machines are like this one and supplies 2A (500ma times the USB ports) total.But when you connect up a DNA, it always charges at 500ma. While my USB TV tuners, USB DVD drives, etc. will draw 900ma or more from these same individual port. My two XTAR VC4 battery chargers act very similar to the DNAs (like most devices that charge through the USB). Although my VC4s will only draw about 150ma max from the USB from this machine. Yet connect them up to XTAR's own USB power adapter and it draws 2A max. Link to comment Share on other sites More sharing options...
VapingBad Posted July 9, 2016 Report Share Posted July 9, 2016 BillW50 said: I don't think most computers restrict ports to 500ma. At least the many that I have seen don't. Like this machine has four USB2 ports. And I have seen over 900ma being drawn over one port. I think most machines are like this one and supplies 2A (500ma times the USB ports) total.But when you connect up a DNA, it always charges at 500ma. While my USB TV tuners, USB DVD drives, etc. will draw 900ma or more from these same individual port. My two XTAR VC4 battery chargers act very similar to the DNAs (like most devices that charge through the USB). Although my VC4s will only draw about 150ma max from the USB from this machine. Yet connect them up to XTAR's own USB power adapter and it draws 2A max. Expand Up to Win 7 (IIRC) you could set the max USB current in control panel applet, now the setting is gone and it seems limited to 500 mA with most drivers. There have been a couple of people that posted they got the full amp, but that is rare.I think you need better USB cables Bill, unless it is in the finall stage of charging I get >490 mA from the laptop and >995 mA from USB supplies & my 2 powerbanks, but I weeded out the cables with high loss ages ago. Link to comment Share on other sites More sharing options...
dwcraig1 Posted July 9, 2016 Report Share Posted July 9, 2016 My laptop has 3 usb ports, one is integrated with an eSATA port. With a power only cable I got .5 amp with one, .8 amp with the other and 1 amp from the one that's integrated.With a data cable it's .5 max on all three.Oh, I checked the cable using a 1 amp wall wart and it can due 1 amp OK. Link to comment Share on other sites More sharing options...
BillW50 Posted July 9, 2016 Report Share Posted July 9, 2016 VapingBad said: Up to Win 7 (IIRC) you could set the max USB current in control panel applet, now the setting is gone and it seems limited to 500 mA with most drivers. There have been a couple of people that posted they got the full amp, but that is rare.I think you need better USB cables Bill, unless it is in the finall stage of charging I get >490 mA from the laptop and >995 mA from USB supplies & my 2 powerbanks, but I weeded out the cables with high loss ages ago. Expand That is very strange about saying there is/was a Control Panel applet that controls the limit of USB ports. I have been using Windows since '93 and many other OS before that and I must have more than two dozen Windows machines here. And only Vista and Windows 10 I haven't ran. But the rest from Windows 3.1 and up I have. And I don't ever recall that applet. I am not saying it wasn't there, I just never ran across it. Sounds like it is one of those manufacture dependent drivers to me.As for better USB cables... those were using the very same USB cables. I can get 2A from them without a problem. I do have one data power cable that came with one of my cell phones that I never saw anything higher than 120ma going through it. I have been meaning to check those wires for resistance because they must be quite high. The data side works quite well though. Link to comment Share on other sites More sharing options...
VapingBad Posted July 9, 2016 Report Share Posted July 9, 2016 By applet, I mean a tab on the device properties, I know it's the wrong word, this is from a Vista machine for v cheap mb's USB hubs (via mstsc), but IIRC some driver hw combinations did allow setting max current and have seen others posting the same. Later versions of windows do not have the power tab at all and the only instances I have of these are in hyper V so would not be real world hw related. Link to comment Share on other sites More sharing options...
black lace Posted July 9, 2016 Report Share Posted July 9, 2016 I think the usb output is a manufacture dependant add-on, ,, we where looking for anouther computer last year and one we looked at had this app on it, but nothing to do with windows operating system,, THE TRUTH IS OUT THERE. Now i feel old because i also remember when it was called 3.1 for windows. Lol Link to comment Share on other sites More sharing options...
retird Posted July 9, 2016 Report Share Posted July 9, 2016 I must be way past OLD as I remember Windows which was replaced by Windows 2 in 1987.....lol.... Link to comment Share on other sites More sharing options...
BillW50 Posted July 9, 2016 Report Share Posted July 9, 2016 VapingBad said: By applet, I mean a tab on the device properties, I know it's the wrong word, this is from a Vista machine for v cheap mb's USB hubs (via mstsc), but IIRC some driver hw combinations did allow setting max current and have seen others posting the same. Later versions of windows do not have the power tab at all and the only instances I have of these are in hyper V so would not be real world hw related. Expand Yes that is where I thought you were talking about. Most of my machines have XP installed on them (still my favorite Windows version) and I don't think I ever saw that on XP or older. And I can't ever recall going into Windows 7/8 USB properties for anything. Link to comment Share on other sites More sharing options...
