dylang919 Posted August 15, 2016 Report Posted August 15, 2016 dwcraig1 said:As I said in a few posts back. I use TCR setting of 0.00238. It's a different composition than Unkamen's 430, CW's contains Ni for one.The TCR I'm using is one that I came up with after much experimenting (not a scientist, not even close). Thank You. I will give 0.00238 a spin
dylang919 Posted August 16, 2016 Report Posted August 16, 2016 Ok, have my SS 430 from crazy wire working at 0.00238. 65 watts, 430 degrees. Nice, very nice!!!! Thank You very much dude!!
dylang919 Posted August 16, 2016 Report Posted August 16, 2016 Jentz9517 said:Must be lots of nickel in that wire Must be. That tcr is pretty high but it definitely works. dwcraig1 definitely did his homework.
dwcraig1 Posted August 16, 2016 Report Posted August 16, 2016 Jentz9517 said:Must be lots of nickel in that wire from CW"s site"Chemical Composition:Fe, <0.12% C, 16-18% Cr, <0.75% Ni, <1.0% Mn, <1.0% Si, <0.040% P, <0.030% SC Min - - Max - 0.12Mn Min - - Max - 1Si Min - - Max - 1P Min - - Max - 0.04S Min - - Max - 0.30Cr Min - 16 Max - 0.18Mo Min - - Max - - Ni Min - - Max - 0.50N Min - - Max - -"
dylang919 Posted August 18, 2016 Report Posted August 18, 2016 I have a general question about temp control. How do you guys run yours? I raise my temp until it's quits say temperature protection, then I drop it down 10 degrees so that it does. Is that pretty standard or do you guys use it differently?
VapingBad Posted August 18, 2016 Report Posted August 18, 2016 I adjust for the best flavour, which often means keeping it low and sometimes making a coil with more contact area, now and again I may add a few degrees if I want more of a hit.
BillW50 Posted August 18, 2016 Report Posted August 18, 2016 TC/TP can be used in two ways:Power Dominant - Use just like power (wattage) mode and set the temperature as high as you ever want to go and you regulate it by wattage. Here the preheat (punch) is really helpful.Temperature Dominant - This is just the reverse of Power Dominant. A good place to start with the wattage is about 50% higher than you normally would use wattage for what you are vaping. Now regulate the temperature for the vape you want.Okay either method you use, it is working by wattage only at first. Once it hits the temperature, wattage is out of the loop and temperature is now controlling the wattage to keep the temperature the same.
dylang919 Posted August 18, 2016 Report Posted August 18, 2016 Ok, well right now I have a dual fused clapton running at 0.21 at 490 degrees using 65 watts. Stainless build that is. Anyway, I started it at 420 and it was way too cold temp protecting in like 5 seconds. I always start low and work my my up. I get it to 500 degrees and no more temp protect warning. So I backed it down to 490. I get the temp protect warning, and a nice vape. Should I do it a different way or something? Clearly it's not hitting 500 degrees or it would throw up the warning. Been doing temp control my way since the begining. Maybe I've been doing it wrong this last year and a half. That's why I wanted different opinions on the matter.
Jentz9517 Posted August 18, 2016 Report Posted August 18, 2016 dylang919 said:Ok, well right now I have a dual fused clapton running at 0.21 at 490 degrees using 65 watts. Stainless build that is. Anyway, I started it at 420 and it was way too cold temp protecting in like 5 seconds. I always start low and work my my up. I get it to 500 degrees and no more temp protect warning. So I backed it down to 490. I get the temp protect warning, and a nice vape. Should I do it a different way or something? Clearly it's not hitting 500 degrees or it would throw up the warning. Been doing temp control my way since the begining. Maybe I've been doing it wrong this last year and a half. That's why I wanted different opinions on the matter. Is that the ss430 or 316 ?
Jentz9517 Posted August 18, 2016 Report Posted August 18, 2016 I am using the csv's that I shared earlier in thread and normally hit temp protection if my set wattage is too high and it has to limit it but vape right around the 485-495 range
VapingBad Posted August 18, 2016 Report Posted August 18, 2016 Temp protected is an info message more than a warning IMO and I think most people spend most of their vape at that temperature so hitting it is not a reason to turn it up the device is doing what is was designed to. I don't think there are any hard and fast rules as to what temp and your liquid probably has a sweet spot, the atty and build also heavily influence it. I used to like a very warm vape, but find my liquid tastes better at lower temps, so if i can't get enough vapour at that temp I increase the contact area of the coil to wick. It doesn't always work I can't get good flavour out of a Serpent Mini without turning the temp up about 70 F. Higher temp is not better than lower temp and vice versa, it's what works for you with your set up.
dylang919 Posted August 18, 2016 Report Posted August 18, 2016 Jentz9517 said: Is that the ss430 or 316 ? 316l right now at 490. My other efusion mini DNA 200 has SS 430 on top and I'm running that at 420 with a regular round wire build.
Modbustersecig Posted August 19, 2016 Report Posted August 19, 2016 VapingBad said:Temp protected is an info message more than a warning IMO and I think most people spend most of their vape at that temperature so hitting it is not a reason to turn it up the device is doing what is was designed to. I don't think there are any hard and fast rules as to what temp and your liquid probably has a sweet spot, the atty and build also heavily influence it. I used to like a very warm vape, but find my liquid tastes better at lower temps, so if i can't get enough vapour at that temp I increase the contact area of the coil to wick. It doesn't always work I can't get good flavour out of a Serpent Mini without turning the temp up about 70 F. Higher temp is not better than lower temp and vice versa, it's what works for you with your set up. I am new to SS stayed with TI tell this last up date I find what you say very spot on it's like a fine balance to get the juice to boil but not to much or it seems to lose flavor then the RTA /RDA and wicking play a big role after getting everything else close I am still playing with space coils not space glow lightly or not at all I am getting great flat line good flavor there are just so many variables it seems like but that's what keeps it interesting
mrphilip Posted November 16, 2018 Report Posted November 16, 2018 On 8/14/2016 at 6:18 PM, Jentz9517 said: Yep got it in the basket 25g. Wonder if I should get thinner also and twist .. Probably so whats this 904 L ? Edit SS 904 has been used by Rolex for watches and now Uwell has released Crown IV coils made from this level of Stainless Steel which is apparently more corrosion resistant. Still looking for the files to use for this metal.
zark Posted January 22, 2019 Report Posted January 22, 2019 Я не отношусь к тем людям, которые могут почувствовать разницу во вкусе между клептоном и фьюзед клептоном, межу микро койлом и спейс койлом. Разница бесспорно есть, но я даже не собираюсь строить из себя гурмана, способного отличить тончайшие нотки ирландских сливок на вдохе и легкое послевкусие неспелой клубники на выдохе. Что-то такое я конечно чувствую, но моя цель в вейпинге просто получить нужную дозу никотина, выполнить определенный ритуал, в конце концов наслаждаться густым и вкусным паром. Скажу сразу я не сторонник вариватта – предпочитаю термоконтроль. Вариватт имеет ряд положительных качеств, для меня это возможность парить любой металл, взрывной нагрев койлов даже очень массивных, высокая температура пара и как следствие густой и вкусный пар, короткая затяжка. Парение на вариватте основано больше на собственных ощущениях, равномерности затяжек, «честности» мода, побора обдува спирали и меньше всего на алгоритмах самого мода, может поэтому ощущения парильщика легко повторяются на разных модах от дешевых до дорогих. Но те же качества дают и некоторые ограничения, лично для меня. Быстрый нагрев ведет к быстрому перегреву, а значить затяжки короче (мне лично нравятся затяжки 3,5-4 сек.), необходимость увеличивать тягу и укорачивать время затяжек при интенсивном парении из-за того, что спираль тупо не успевает остывать между затяжками. Да с опытом парильщики на уровне рефлексов после отпускания кнопки фаер, на какие то доли секунды не прекращают тягу, а дыхание автоматически меняется в зависимости от температуры пара. Но я считаю вариватт кнопочным телефоном в эпоху смартфонов- в общем-то функцию телефона выполняет, просто, надежно, но не дает возможности использовать всю полноту технологий сегодняшнего дня. С термоконтролем все намного сложнее, здесь решающим является уже само оборудование, как спираль, так и в большей мере мод. Спираль — это не столько форма, сколько сам материал- его геометрические параметры и соответствие реальных химических и физических характеристик тем, которые заложены производителем в алгоритмы термоконтроля. Для меня обидным ограничением термоконтроля стало невозможность использования кантала и нихрома, потому, что эти материалы мне нравятся очень высокой скоростью разогрева и как следствие даже массивные спирали из этих материалов буквально вспыхивают при нагреве. Скажу сразу что последнее время я почти всегда использую паралельку из 0,5 нержи и 0,4 кантала. ДНК моды спокойно вытягивают такой гибрид, но с небольшой оговоркой- при разных параметрах намоток бывают провалы в термозащиту, или очень частые (не годится), или очень-очень редкие (правильный подбор длины). У меня это 5,5-6,5 витков на оправу 2,5. Ну все, от соплей к делу! Теперь о самом термоконтроле. Многие, не понимая самой сути работы этого режима выбрасывают койлы из нержи и переходят на кантальный вариватт. А имея в руках плату ДНК, термоконтролем можно пользоваться, в прямом смысле слова, филигранно, получить от него все то что на что способен атомайзер, в таком виде как вы хотите. Нужно только понять простые принципы работы этого режима. И так, термоконтроль- контроль нагрева спирали, посредством контроля роста текущего сопротивления. Как это работает- очень просто: 1. при установке спирали Вы замеряете и блокируете так называемое холодное сопротивление (сопротивление койла при комнатной температуре, например, при 21 °C). Это есть отправная точка для работы алгоритма термоконтроля 2.выбираете материал спирали. Это позволяет чипу знать на сколько изменится сопротивление койла при его нагреве на какую-то температуру. 3.устанавливаете желаемую температуру и мощность нагрева спирали (я для первого старта всегда устанавливаю 232 °C, это температура испарения пропилен гликоля) Далее процесс парения регулируется следующим образом: 1.мод, используя алгоритм производителя, устанавливает значение силы тока и напряжения, в зависимости от измеренных и установленных параметров спирали. 2.при затяжке, мод зная на сколько должна изменится температура спирали по сравнению с комнатной, высчитывает какое сопротивление спирали (текущее сопротивление) должно быть при заданной температуре. Проверяя десятки раз за секунду текущее сопротивление мод отключает нагрев по достижении сопротивления рассчитанного программой для данного материала и данной температуры. После программного отключения нагрева, спираль остывает, сопротивление падает и мод возобновляет нагрев до достижения спиралью расчетного текущего сопротивления. Этот цикл повторяется пока зажата кнопка фаер. Я настолько долго описываю этот процесс, чтобы стало понятно- мод не меряет температуру спирали, а высчитывает её используя свойство термоконтрольных материалов изменять сопротивление при изменении температуры. Вот тут и кроется возможность тончайшей настройки параметров пара под свои субъективные ощущения. Значит, Вы проделали все пункты, отключили прехит, выставили желаемую мощность нагрева и сделали первую затяжку. Буду описывать только личные ощущения. 1.температура спирали 232°C –пар достаточно густой, температура пара, субъективно, 37-38°C (почти неощутимо теплый пар) 2.мошность нагрева заданная вручную должна быть хотя бы на десяток ватт выше че та которую использует мод под Ваши параметры (при необходимости установить большую мощность- мод не должен голодать по мощности) 3.обдув на комфортном для Вас режиме 4.прислушиваемся к субъективным ощущениям. Если пар, по-вашему, слишком холодный для установленной температуры — это значит, что в используемой системе что-то либо не греет, либо переохлаждает. Проверяем настройки воздуха, мощности, если все гуд, Корректируем сопротивление спирали вручную. Сразу скажу, что корректировка идёт в десятитысячных долях Омма (четвертый знак после запятой- то есть в настройках мода нужно выставить отображение сопротивления до четвертого знака после запятой). Уже 0,0003-0,0006 Омм заметно изменяют нагрев (зависит, конечно от материала и размера спирали). При недостаточном нагреве сопротивление нужно увеличивать. Далее -затяжка, корректировка, пока получите желаемый результат. То есть соответствие ощущений той температуре, которая отображена на экране. Далее тонкая настройка- прехит, воздух. 5.если пар слишком горячий, опять же проверяем воздух, установленная мощность нагрева все равно должна быть больше, той что использует мод. Корректируем сопротивление-уменьшаем его. Изменение сопротивления вручную это не танцы с бубном, это абсолютно научный подход к исправлению ошибок в системе спираль-атомайзер-мод. Суть состоит в том, что принудительно изменяя холодное сопротивление спирали мы перемещаем ту самую отправную точку с которой и ведется расчет температуры спирали. То есть грубо процесс выглядит так: Холодное сопротивление R0=10,0 Ohm при 21°C (Т0) Установленная температура Т=231°C Значит мод рассчитывает изменение температуры ΔТ=Т-Т0 это 210°C, по характеристикам сопротивления данного материала известно что при таком изменении температуры, сопротивление должно увеличиться на ΔR=Rтек-R0, где Rтек текущее (живое) сопротивление, ну скажем программа рассчитала, что Rтек должно быть 11,0 Ohm при температуре Т=231°C, тогда ΔR=11,0-10,0=1,0 Ohm, при ΔТ=210 °C. При корректировке холодного сопротивления, мы смещаем точку отсчета температуры вправо или влево. Например, при указанных выше параметрах мы вручную изменяем холодное сопротивление R0, ну скажем на 0,5 Ohm, имеем R0=10,5 Ohm при реальных 10,0 Ohm, тогда мод проведя расчеты примет за расчетное текущее сопротивление значение Rтек= R0+ΔR, то есть Rтек= 10,5+1,0=10,5 Ohm. При этом термоконтроль будет поддерживать завышенное сопротивление спирали, тем самым повышенную температуру, не догадываясь про обман. Не сложно представить картину и при уменьшении холодного сопротивления. Интересным есть также режим Replay, в нем поддерживается понравившиеся параметры пара, путем поддержания текущего сопротивления спирали в тех же значениях, что и при эталонной затяжке. При этом не нужны расчеты ΔТ и ΔR, а следовательно, не нужны и TCR профили для материала спирали, главное условие, чтобы материал был термоконтрольным. Режим прост и удобен, полностью завязан на субъективном восприятии температуры, но менее гибок по сравнению с термоконтролем. P.S. Прошу прошения за длинный и нудный рассказ об очевидных вещах, но достала необоснованная критика термоконтроля на ДНК модах. Считаю термоконтроль ДНА эталонным. Z_a_r_k
