  txmonkey214 said:
Are your battery cells charging at the same level?  Low/bad batteries will cause erratic behavior in any device. If not, send it back.
Expand
Battery charges perfectly.  Cells are all even.
If you suspect your .ecig file it might be better to create a new one when you get your repaired device back.  I personally don't download/upload any unknown/suspect .ecig file.
Expand
I have, but only to EScribe and haven't uploaded any to a mod.
  VapingBad said:
I can't see anything in the config that would explain your issue, I copied the screen settings to a DNA 200 and they work fine, I would decrease the fade in time to 0.25 myself.
[image]
Expand
I actually had them at .25 & .75 but changed to 1 & 1 as part of the testing
  retird said:
@Karsten so, I guess you got your device back that you sent about 9 days ago to Evolv by now.... How's it working? Still loosing the display???
Expand
I got it back yesterday but am waiting until Monday morning to fire it after I recreate an ecig
Are you going  to fire it and check it out before changing the ecig file?  Let us know how it goes...  I would probably maker sure I had a properly functioning device before making any changes, but that's just me... :)
Expand
I did switch it to a default Ti profile and gave it about 3 or 4 quick presses. The screen stayed on but that's enough to confirm what I needed before creating a new ecig. I want to test it connected to the PC as well. Plus, I don't know what curve is in there for Ti and would rather not fry a good coil
Understand wanting to not fry a new coil... when I start using or testing a new coil, material, or new coil technology I usually start with a low temp and wattage and migrate upwards... Ti was too "touchy" for me so I don't use it...
  retird said:
Understand wanting to not fry a new coil...Ti was too "touchy" for me so I don't use it...
Expand
It's a Ti Clapton. Best flavor of any material so far. Works great with right curve. Current plan is to bring it up on a basic kanthal and run it for a bit before loading up my Ni200, SS, and Ti's for TC. Debating on whether or not to just blast a full config at it, including screens first go around and basically say 'screw it' and fire up, or take it one step at a time until something either causes it to behave as before or I end up with a good ecig and functional DNA at same time...
Yep one could implement an ecig file is steps or all it once.  If you suspected the ecig file as subject to have caused your issue then it's your call whether to implement all at once or not.  I think I would first save the ecig file currently in the device so it might be reloaded should it be needed.  Good luck and let us know.  :)
Happy to report that after going through both the one-step and all-at-once the DNA200 is performing flawlessly. So, it was either two bad boards in a row or one bad board that was just restored and sent back. Either way the guys at Evolv were great. While it would've been nice to have known what the issue was, it's not a requirement and I'm still a happy user.
Expand
THX for the update..... enjoy
