SplashPuddle last won the day on September 21 2023
SplashPuddle had the most liked content!
About SplashPuddle
- Birthday 06/15/1979
Full Name
Splash
Location
Puddle
Lost vape paranormal 250c, VapeCige VTX200 (DNA250C), Hcigar vt Inbox 75
1,978 profile views
SplashPuddle's Achievements
Version 1.0.0
504 downloads
*note: wacked out wonky clock in lock screen preview image will display properly when installed* An animated theme for DNA75C and DNA250C devices featuring Eric Cartman, a blowtorch, a story, and lots of fire. Core functionality and layout is mostly stolen from several excellent themes by formula1, he shall be praised. Lock screen flame = battery level indicator *hint- main screen-->scroll down*- 2 reviews
- south park
- animated
(and 2 more)
Tagged with:
Version 1.0.1
183 downloads
For DNA75C and 250C devices. Based on Digital by SirTimmyTimbit, this Nine Inch Nails tribute theme retains all of Digital's unique functionality while adding bright backgrounds and some larger fonts thereby making text easier to read. Many functions on the main screens have been tweaked so only the most relevant controls to each profile are presented. There are 2 main screens with different backgrounds and slightly different controls. One of which has navigation icons hidden by the NIN logo when not selected. Scroll over the NIN to reveal Profile, Menu, and Switch Main Screen icons. The NIN logo on the lock screen serves as a battery level indicator. Everything else works as in the original Digital theme which can be found with instructions here https://forum.evolvapor.com/files/file/946-digital/ . Artwork modified from the Nine Inch Nails albums Broken and Pretty Hate Machine. Theme modified and posted with permission from original author SirTimmyTimbit, to whom much gratitude is extended for creating and sharing several excellent themes (Digital, Gauges, Materialish Fire, Materialish Ocean). Please comment if you find bugs or have suggestions. -
Wow Sir Timmy, this is a fantastic theme! Definitely my favorite of the 30 or so I've tried. Very slick and clean and such a cool old school effect with that background. Major points for originality. Most of the themes here are tweaked versions of someone else's work but this is totally new and different. I can think of only 2 others that are as unique and this one is cleaner and prettier than either of those. I love that the file size is small enough I was able to add 2 wallpapers and a custom main screen. If you like Gauges or Materialish you'll like Digital. I predict this will be the next theme with over 1,000 downloads. Fabulous work sir, many thanks. The one issue I found (other than mentioned by Redman2u) is with the battery level field on the main screen- there are 2 conditions- the default doesn't show units (%) but the other one does and at 100% wont fit in the box . Easy fix but worth a mention. For future updates consider adding a color background option or 2 since you've got ample space. I added a fire and a water background (fire and ocean, hmm, where have I seen those?) both of which look great.
DJLsb Theme with Replay
SplashPuddle commented on Stepladder's file in DNA 75 Color, 100 Color, 250 Color
Sparkuk- Others might have different reasons but I like to have coil materials selectable independently from profiles because I have set up several atomizer centric (as opposed to material centric) profiles in escribe for certain RDAs and tanks I use with different coil types. The ability to change coil materials within profiles set up for and named after my Pyro V2, Wasp, Drop Dead, and Fireluke atomizers is one of my favorite features of this well thought out theme. Thanks stepladder! -
SplashPuddle changed their profile photo
Some USB cables are "charge only" in which case you'll get that message and be unable to connect to escribe even though the mod is drawing power. Won't happen if you use the cable that came with your device (one for my phone works too).
- 9 replies
- usbproblem
- charging
(and 1 more)
Tagged with:
I tried that too after stumbling upon a how-to video on YouTube. I gave up in frustration after an hour. All was well and pretty simple till the very end where the coil is installed and the wick just needs to be pulled through the tiny holes into the juice chamber. Maddening! Next time I'll feed a length of wire through through the holes beforehand to attach my wick to and fish it through.
Version 1.0.0
181 downloads
Another ripoff of Hyperar's Simple Series-- super intuitive and fully functioned themes without a bunch of clutter. For sure my favorite theme to riff on. All I did here was throw up some backgrounds, change some colors, and strip the lock screen down to just the stuff Elmo wanted. All functionality and utility is thanks very much to Hyperar. -
