Everything posted by CMK
Adding new fonts to Theme Designer
CMK replied to croyleje's topic in EScribe, Software and Firmware
Eigentlich sollte jeder, welcher "systemfremde" Schriftarten verwendet, diese auch benennen - möglichst mit Bezugsadresse. So machst Du es, so mache ich es und es ist der beste Weg, anderen Usern keine Steine in den Weg zu legen - es beginnt ja bereits wenn jemand die Namen der Profile individualisieren möchte... -
Meines Wissens gibt es diese Möglichkeit nicht - die Schriftart wird auch nicht im Theme gespeichert. Es werden erfahrungsgemäß nur die verwendeten Symbole exakt an der verwendeten Stelle gespeichert. Bereits das Verändern von Beschriftungen im ThemeDesigner führt zu fehlerhaften Darstellungen, wenn die Schriftart nicht auf dem PC installiert ist. -
- 6 comments
- ecig themes
- dna color themes
(and 1 more)
Tagged with:
"MAIN SCREEN Genie comes out of the lamp as the battery level goes higher. goes in as the battery level goes down. LOCK SCREEN: Half moon becomes clear when battery is full and fades away as battery goes down. When charging the arabian lamp glows. When not charging its off. Arabian Light glows red when connecte d to PC." Really fun idea - I really like it
- 6 comments
- 1
- ecig themes
- dna color themes
(and 1 more)
Tagged with:
In operation with the boost function, the set power is increased at the beginning so that the coil is heated up more quickly. Of course, this has an impact on the average power output. Your first puff takes a little longer each time, probably because your coil is still cold - towards the end you are approaching the set 100W. In the following puffs, your coil is already very hot, so your puff is very short. The mod remains in the boost and the average power is thus well above 100W.
Theme Designers 'Top Downloads' panel - count spamming. STOP!
CMK replied to Wayneo's topic in Themes and Custom Screens
Of course you have a special position here - in a positive sense - and I also understand that it is easier for your compatriots to find a theme in Russian directly via the toplist. But still: it is as it is; an English language forum. Perhaps it would be a possibility, the moderators would attach your theme, which has no alternative in Russian on this platform, on the first page as a recommendation. But this decision can only be made by the moderators. -
I find it just as noticeable as the continued strong presence of another theme author, although it may also be due to my subjective evaluation. Overall, however, I trust that they are trying to keep the download numbers clean and I really think that's okay. I had fixated myself on these numbers in the past - maybe the counters should just be turned off, hidden, if that's what the trouble is. -
Hey, honestly - what interest should the moderators have, especially since they don't publish any themes themselves? -
Das war auch meine Herausforderung - beide Anforderungen in einem Theme zu vereinigen (auch wenn ich es anders formuliert hätte) That was also my challenge - to combine both requirements in one theme (even if I would have phrased it differently) -
Das ist sehr schade....
- 6 replies
- theme designer
- chart
(and 2 more)
Tagged with:
Ich kann nur für mich persönlich sprechen - Ich würde diese Kritik besonders ernst nehmen, wäre aber nicht verärgert; ich ginge von einer objektiven Kritik aus. Selbst hat man einen verklärten Blick auf das eigene Theme. I can only speak for myself personally - I would take this criticism particularly seriously, but I wouldn't be angry; I would start from an objective criticism. You yourself have a glorified view of your own theme. -
Okay, kein Problem. Okay, no problem. 😁 -
Da dies der treffende Oberbegriff ist möchte ich fragen, ob es in Zukunft geplant ist, die Chartanzeige im Themedesigner genauso flexibel einzusetzen, wie jedes andere Feld auch, also an Bedingungen verknüpft, verstecken usw.? Dies würde der Gestaltung von Themes neue Impulse geben.
- 6 replies
- theme designer
- chart
(and 2 more)
Tagged with:
Betrachtet es als "Eitelkeit", meinetwegen auch "Streben nach Internet-Ruhm", aber tatsächlich haben einige von uns unzählige Stunden Arbeit investiert und unsere Themes sind derart komplex UND ausgereift, dass es einen erheblichen Aufwand bedeutet, daran echte Neuerungen, Verbesserungen vorzunehmen. Bis dahin sind wir durch diese Vielzahl "einfacher" Modifikationen nur noch durch gezielte Suche auffindbar. Aufmerksamkeit ist unser einziger Lohn. Ich sehe natürlich das Problem, neue User, Anfänger nicht zu entmutigen - ihnen die Anerkennung zu geben, dass sie sich weiterentwickeln. Vielleicht ist es ein guter Weg zur Motivation, wenn die Kategorie der "Empfohlenen Downloads" weiter ausgebaut wird? -
Also meiner Meinung nach sollten die Anforderungen an eine Veröffentlichung und das Spammen getrennt voneinander betrachtet werden können - es sind zwei unterschiedliche Probleme. Ein Captcha vor dem Download wäre auf jeden Fall ein guter Anfang. -
DAS ist der Grund, weshalb ich zuvor schon von einer Mindestanforderung an die Schöpfungsrede geschrieben habe. Unzählige Stock-Themes in kürzester Zeit, welche sich nur im Wallpaper unterscheiden. -
Ein zurücksetzen der Statistiken in Kombination mit einem Captcha vor dem Download wäre vielleicht tatsächlich die eleganteste Lösung... -
@zark: "Ich stimme zu, dass ich mich nicht auf Diskussionen einlassen sollte, weil mich jeder als Hasser wahrnimmt, aber ich versichere Ihnen, das ist nicht so" Du bist sehr ehrlich mit Deinen Kritiken und manche Menschen können damit nicht umgehen. Dies ist aber nicht Deine Schuld. Auch wir beide sind/waren nicht immer einer Meinung, dennoch nehme ich gerne Kritik von Dir an. Es wäre sehr schade, wenn Du das Forum verlassen würdest. Ich denke, es bietet die beste Plattform für Dein Theme in Deiner Sprache. -
But remember that installing a theme without having the font on your own computer can lead to incorrect text displays. So you should also provide the appropriate fonts for download with your themes, as well as short instructions for installation, especially with W10. -
Ich möchte, ich muss mich schuldig bekennen, ebenfalls meine eigenen Themes vielfach selbst heruntergeladen zu haben, als auch (zuletzt) unverändert an die Spitze der Übersicht gebracht zu haben... Ich fühlte mich aus niederen Beweggründen getrieben. Zum einen gibt/gab es einen Nutzer, welcher über nicht nachvollziehbare Downloads die Tabelle seit Monaten beständig dominiert/dominierte. Zum anderen habe ich auch den Eindruck, dass zur Zeit die Themenübersicht regelrecht zugemüllt wird mit Stockthemes, bei welchen lediglich das Wallpaper geändert wird, oder immer neue Versionen als neues Theme eingestellt werden. Ich befurchtete, das neue User nach kurzer Zeit gelangweilt die Freude verlieren und ihnen verborgen bleibt, wieviel Arbeit sich ein Teil von uns macht, gemacht hat. Mein eigenes Fehlverhalten entstand aus einer Mischung von Eitelkeit und Kränkung. Mit einem User bin ich auch in persönlichen Kontakt getreten und habe ihn gebeten, zukünftig nicht jedes Wallpaper als neues Theme einzustellen - es stellte sich heraus, dass dies für viele wohl bereits eine Herausforderung darstellt. Einerseits freut mich natürlich der Enthusiasmus der User, andererseits sollte vielleicht doch die Schöpfungshöhe neuer Themes bewertet werden, bevor diese für das Forum freigeschaltet werden. -
The same thing happens when you have set the temperature and power to maximum in TC mode and accidentally turnoff replay!! Sorry, but I think we both have different ideas / demands on the replay function. In my opinion, Replay shouldn't reproduce a chance hit, but the basic settings should already be correct - this also includes a power setting in TC mode that enables the set desired temperature to be reached so that the chipset can regulate via the specified resistance value. Then replay in TC mode makes no sense at all. What strikes me in your graphics is that you apparently did not reach the preset temperature BEFORE activating Replay, although the performance should actually be sufficient; the chipset adjusted back before - unfortunately you did not include a graphic WITHOUT replay. Does your resistance curve actually match the coil you are using? Personally, I see the point of replay in the elimination of external variables in the case of unknown resistance curves - the TC mode actually does nothing else if the resistance curve is known. Basically. Even in TC mode, the default power of the DNA chipset should match the target temperature (resistance); If the power is set too low, you will not reach the temperature and if it is significantly too high, you can clearly see an unclean, clocked control. Apart from that, the result is the same as in the replay mode: the power is adapted to the external variables in order to achieve a preset resistance. I see two paths here that lead to the same goal.
The chipset will EITHER control the resistance calculated according to TC OR the one saved from Replay
If you understand how Replay works, you will see that it makes no sense to use Replay in TC mode. If you use a TC-capable material - like SS316 - the resistance changes with the temperature. In TC mode you set the desired temperature, the chipset calculates the associated resistance and if you do a puff, the chipset controls the required power to achieve and maintain this resistance value. This performance is not only dependent on the material, but also on the temperature of the ambient air, the temperature of the liquid and the strength of the coil cooling depending on the flow speed and amount of air in your puff. In replay mode, the chipset saves the resistance value of your last puff in the background and with the "save" command the chipset will do nothing else in the following puffs than to control the output so that this resistance value is reached and maintained. Now we come to the point where the resistance curve over temperature is unknown; in the case of complex coils, which consist of several individual wires, maybe even combinations of different materials. The resistance curve over temperature is not known. You now set "Watt" as the material, switch to the replay mode and vary the set power and your pull until you achieve an optimal result for you - then you save it. The chipset "remembers" the resistance reached and from now on the chipset will control the performance in such a way that you have a consistent taste experience regardless of the strength of your pull or other external influencing factors. As far as I know, other parameters are actually taken into account in replay mode. This representation is only intended to make it clear that it is nonsensical (and not intended by Evolv!) To combine TC and replay. (this is the result of the Google translator, my native language is German)
Hi, the only question left is what relevance the topic 4 cells / 400 watts actually has for the theme ... Not even the individual voltages of the cells are evaluated, so this theme doesn’t care how many cells are used. A theme is nothing more than a graphical front end and cannot enable the chipset to do anything that the Evolv developers did not plan.
