JacobEvolv
JacobEvolv last won the day on May 31
JacobEvolv had the most liked content!
2,396 profile views
JacobEvolv's Achievements
  1. Hello, Attached is the DNA 80 Screen data sheet. Evolv 128128 Screen DNA 80.PDF
      • 1
      • Like
  2. 160x40ColorScreen rev2.pdf
  3. Hello, Attached is the DNA 60c datasheet. There is a version with a 40mm whip, virtually identical besides the ribbon length.
  4. Hello, @Wayneo Posting these on behalf of timbuc2dan. He came to the support desk. I think he just needs to download the newest version of Escribe - it can be found here : https://www.evolvapor.com/escribe
  5. Try this: Plug the device in & open Escribe. Ignore the connect prompt. Go to Tools> Apply service pack > Try an older service pack. If this applies, then apply the newest service pack from the front page of Escribe. If this doesn't work, I would also try more than one USB cable. Inspect the usb port and ensure it is clean. Even if it looks clean, I would use a small piece of paper towel, isopropyl & a toothpick to carefully clean out the port.
  6. Hello, Attached is the data sheet for the smalls screen that can be used on the DNA 40 & 60. OSD9616P2477-21.pdf
      • 1
      • Thanks
  7. Good Afternoon, Attached is the drawing for the Large non color screen. DNA40 large screen (2).pdf
  8. Start by inspecting the upper internal battery contacts in the device. Whether or not they look dirty, take some isopropyl and a paper towel and clean the upper and lower contacts, as well as the contact pins. Repeat this process on the USB port, using a small piece of paper towel and Iso clean the port gently. I have revived may devices doing this. Ensure the batteries are not inserted while performing these steps, and allow a few minutes to pass to let the Iso to dry.
  9. Howdy! Attached are drawings for the DNA 100c. Enjoy! Jacob DNA100C Drawing (1).tif DNA100C Vertical USBC (1).STEP
  10. Version 1.0.0
    268 downloads
    Hello! This is a variation of the stock theme where the puff count window has been made larger. This will prevent the puff count from being cut off over 9999 puffs. Thanks, Jacob
  11. @stevetheimpact Great theme. This brought some serious nostalgia for me. I especially like the lock ohm being a chest that opens and closes! Too cool! Great job!
  12. Hello! I have created a tutorial on how to change the screen on a Triade. Hopefully this will help if you choose to do the replacement yourself! If you have any questions or comments I would be happy to help! https://drive.google.com/drive/folders/198vVxVLqfuFY67Fh4jrc8paey5n1rT2Y
  13. The screen ribbon is placed directly under the fire button on this device. You have to fold the ribbon so it does not receive pressure when the fire button is pressed. It is pretty tricky to set correctly! Thanks, Jacob
  14. Hello! I have created a tutorial on how to change the screen on a Paranormal, this will work on all Paranormal models. Hopefully this will help if you choose to do the replacement yourself! If you have any questions or comments I would be happy to help! https://drive.google.com/drive/folders/1EnOp3Ejwvh49dzELEHqiudwcj9qw3ieB Thanks, Jacob
  15. MonkSpeed, Can you post a screenshot of the puff on the device monitor window ? It sounds like voltage is the issue here.
