Everything posted by Vapors Tongue
Lost Vape Paranormal dangerous overheat
Vapors Tongue replied to Photo Pete's topic in General Discussion
better contacting them through facebook in a private message , they do reply maybe a few days but they will either point you in the right direction or offer advice but dont mention you have undone the mod to see what's happening or you carried the mod in your pocket you won't have a leg to stand on. if you dont know lostvape changed their name on their fb page and everyone had trouble finding them again also their website but here the link to there fb group https://www.facebook.com/LVEvapor/?epa=SEARCH_BOX -
Never buy a yihi or smok mod then as those 2 manufacturers wriggle out of responsibility in fact smok dont bother replying to anything , if you bought it locally then that's your best bet and see what he says , then try lostvape - like i said i think it would be a case of discretion but i would assume they would offer you a replacement product or offer to fix the one you have , if you post it to the allocated authorised repair center wherever that may be , i think lostvape have one in the UK -
i think this would be down to the manufacturer's discretion as the mod was previously working fine , there's so many user errors that can occur with problems with mods , not saying at all this is what's happened with you or your problem - lost vape offer a 6 months warranty im not sure where evolv stand on their warranty but since you bought the full mod form lost vape i would say that's where your warranty lies but the dwcraig and retird would know better about evolv's warranty procedure . its a tough one to be honest to get a full refund from evolv they just supply the board and lost vape issue the warranty and its been longer than 6 months -
possibly like dwcraig1 said maybe the wiring to the the battery connecter has worked lose and the heat from the previous episode its become unsoldered , i had a minikin V2 with the same thing the positive wire had worked lose and touching the metal casing inside and immediately when you put the batteries in it became hot -
just a wild guess you've had your mod since since june last year with no problems until recently , i would suggest juice has gotten inside the mod over a period of time and has either caused the fire button to stick without noticing or the juice has acted as a conductor causing it to fire randomly without being aware. -
sorry everything is to small on the screen i cant read it and is there any need for a settings of little use , but i will give credit for the colour display bit like a rainbow just missing a unicorn , not to mention the fact its a bit of a copy and paste of franks superb theme but good luck you have potential do not stop in copying others work - i just dont like the features none suit me at all - maybe you should swap the wallpapers make it more beautiful instead of generic black and enlarge the font just an idea but if you need help message me' . we all start from somewhere - good first attempt
if you alter any option or blank space in the language section you can not delete it , you can only change what you last wrote - if simply removing what you wrote last time and not fill it it again it always reverts back to what you last wrote - is this a bug ?
- theme builder
- evolv
(and 1 more)
Tagged with:
evolv 250c What i would like to see in the next update
Vapors Tongue replied to Vapors Tongue's topic in General Discussion
option would be great wouldnt it either to enable or disable that function , if you swap from one profile to another Temp to Replay mode and Watts - it wouldnt be to hard to enable or disable the feature - not many people have a few atomizers in their pockets at anyone time and with using SS coils they get warm and dont give a cold reading -
i've just analyzed my 3 DNA devices and none are like that , have you tried swapping the batteries out ?
Vapecige VTX 250C Battery Charge Problem
Vapors Tongue replied to dwcraig1's topic in General Discussion
Crazy , do these people test these device , its like the Drone Squonker why make a door so flimsy when that's the main area its going to get most usage but i like the mod very much but with the ultem you certainly have to watch out about that door area on squeeze to hard and if the door isnt aligned or slightly out something then its going to break -
not really a question for me but for people who seem to have trouble installing themes with errors on their device running out of memory ? i've seen the solution before but i cant for the life of me remember what it was , i know its something to do with service packs either reverting or going up can someone refresh me or point me in the right direction. Thank You
ahh the VTX is a squonker - just been having a look i'm sure you posted a pic of it in the group didn't you change the board in it or is that one that looked similar -
juice was going down the 510 ? did you see what was going on and fix it or send it back - i hope i dont experience anything like that i really like this box -
Just got a VTbox but not experiencing any problems -
Vapors Tongue posted a topic in General Discussion
whenever the next update comes along i would like to see the option of setting , measuring and locking resistance through all profiles , so when you lock your coils resistance that's registered in all profiles -
Replay mode not working (May have the answer)
another update , i think this is a big pointer , so i've recently got a new RDA that i've been having trouble with in replay mode as i've mentioned above well i'm going to add to it it seems if you pack the coil with to much cotton not enough for a dry hit but to much so the juice is not wicking properly and effectively replay will start to play up -
Spot on Retird , i've been vaping for over 3 years now but using a DNA device for the past 14 months and i'm still learning - almost everything is a variable with vaping right down to juices you never stop learning , especially coils, wicks ,juice and atomizers what may be right for one is not for another. there is no set answer regarding those things i mentioned you just got to learn yourself what's best for you
im sure youve got more hours and knowledge under your belt than i have , but was wondering what you could actually change after hearing different things from what are suppose to be well known sources whom i think should have the experience to be correct if they are going to review something - and as for the only thing in replay mode i see is replay warmth and and punch that seems to be changeable but on a scale of 1 to 11 and i was wondering those scales was changed by changing the scale through pre heat wattage and preheat temperature similar to what a power curve would achieve but like you have said temperature sensing coils will not work that way in replay mode which i assume if you're in replay you are using such coils
i dont need to be proved anything , i will just take your word for it, that's why i asked a simple question for the answer i was looking for which occurred through being misinformed of what you can or cant do or which is not possible magically
like to update this a little more the RDA i was having trouble with seems to be working fine with replay , changed the coil and the wick but its still the same wire used , i've yet to experience what i mentioned above a few days ago -
its just that im seeing miss information when different reviewers on youtube say or tell you something that is not even possible - jai haze said you can alter change the boost in replay by going to profile boost watts then back to replay that seems to do nothing whatsoever , so the only thing changeable in replay mode is punch , boost on and warmth from the scale 1 to 11 there is no other way to actually select a different wattage for the boost or warmth
right the pre heat power is only available in temp control , so now i'm wondering what is actually changeable in replay mode , as in boost , replay warmth and punch
i've done a theme and added preheat power and pre heat temp they are both set in the theme to be changed and not read only , yet the pre heat power option will only allow me to read and the preheat temp is fine , is there something im not doing ? in another setting that will allows the preheat power to become changeable
- 5 comments
- 1
- drone
- paranormal
- (and 13 more)
just to let you know my findings , now i know replay has to have heat sensing material coils like stainless steel this also could be a mixture of coils so long as the coil is suitable for temp control , well its happened to me twice now using SS316L on a Steam Crave Aromamizer plus and a QP design Kali V2 RDA it seems to happen when the coil or deck is hot and you happen to cancel replay to change the wattage , i find replay will not engage again - i just left the mod/tank to cool down and then all of a sudden replay came back without any change to the menu or anything so i believe its something to do with heat from the deck or coil. is this a bug or something nobody had found out , granted my other tanks do not do this but the ones i mentioned have done it in the past thanks Paul
