Frank65
Everything posted by Frank65
  1. Hello , to change watts\temp stepping , you have to select the control , click options and change step size like in the picture :
  2. @mactavish just sent you a modified theme , let me know if it's ok
  3. @mactavish : what version of theme do you use ? I will modify it and send you via forum message (I'll try ) ps : do you have wrong charging issue as explained by user hearts above .. ?
  4. hi @Hearts I'm pretty sure it's not theme related , my suggestion is to ask in the forum . It could be something you have to adjust on escribe .
  5. Hello , to find the watts field under "replay ready" field , you have to RIGHT click in the zone and then click on "select other control" window until you find the coil power control. Coordinates are 0,48 , don't know if this may help. I'm a MTL user , so i'm vaping with very low wattages , that's why I'm using 0.5 watt . Temp should be already 5 degree steps , isnt it ?
  6. In TC temperature is the setpoint , in power mode watts is the setpoint. Then , as I understand this board works , when you want to use replay with TC , you have to set temperature , either on power mode your setpoint is watts. I think if you really want to modify watts in replay mode AND tc , you can set it under system info menu (i icon on main menu). I'm not sure if using replay with TC has a sense , since Evolve advice is to use watts , but since they left this possibility alive , I did leave it on my theme too. @Chodi Thanks for the question , hope you can read my low level english
  7. Thanks for your feedback and suggestions , which I did applied in last 2.8.3 , please check and any problem let me know
  8. New version 2.8.3 is coming in few hours . Bug fixed : - Now you can use whatever profile you want (with same functionalities as before) Pre-heat and Boost menu rewritten Please let me know any problems , tnx
  9. Thanks for the feedbacks. Yes 2.8.1 was a little buggy , happy to see 2.8.2 solved glitchy problems. About boost locked at 200W , I cannot replicate the problem. You mean under pre-heat menu , pwr function ? I can adjust that parameter as usual. Please explain what's locked at 200W , so I can fix it ! Found boost locked problem , I will working on it today Thanks Ps : Under replay profile , you can choose watts (then on theme you can adjust watts) or TC material (SS316L,Ni200 ...) then on theme you can adjust temperature. That's how I have understood replay function By the way , I'm using 2.8.2 theme since yesterday and it's working well for me.
  10. I trim Profile 8 as a condition to show\hide some controls. But if it's working fine for you on 1 I'm happy anyway
  11. EARLY SERVICE PACK (all devices) EScribe Suite 2.0 SP15 For US-based customers (Windows): https://downloads.evolvapor.com/SetupEScribe2_SP15_US_ServicePack.exe For US-based customers (Mac): https://downloads.evolvapor.com/SetupEScribe2_SP15_US.pkg For international customers (Windows): https://downloads.evolvapor.com/SetupEScribe2_SP15_INTL_ServicePack.exe For international customers (Mac): https://downloads.evolvapor.com/SetupEScribe2_SP15_INTL.pkg For customers using Linux, see the beta thread. --- DNA 75 Color (firmware 1.2 SP33.2) --- Replay (International Edition only). To use Replay: (1) Apply the Service Pack. (2) Choose a profile to put Replay on. Check "Use Replay on this profile", and name it how you like. (For most people, the easiest way to use Replay is to choose a profile whose material is Watts.) (3) Load on a theme with Replay support. (The default theme has Replay support. Go to the Theme tab and click Default Theme, and upload.) --- DNA 250 Color (firmware 1.2 SP33.2) --- Minor bug fixes and reorganization. --- Theme Designer --- Double-clicking now works when a control has multiple conditions. The default DNA Color theme now uses 0.5W increments instead of 0.1W increments. --- EScribe Suite --- Made tooltips show up on fields now instead of just their labels, and added some new tooltips. Permission errors on save/load are now more descriptive. Upgraded many icons to high-DPI variants. Minor bug fixes and usability improvements.
  12. Replay Version ready , should work with DNA250C too . Please try and let me know any bug . Thank you !
  13. Thanks for this guide , I managed to improve internal resistance from 0.03 to 0.005 , just by cleaning and screwing , no desoldering needed.
    Simple and nice colors. Something original. I like it !
  14. Version 1.1.0
    2,453 downloads
    Replay , Rev 1.1.0.
  15. Version 1.0.0
    439 downloads
    Lost Vape Paranormal DNA75C settings (.ecig) after case analyzer , resistence test and VTC6 battery test. Battery Analyzer run for dual Sony VTC6 3000mah 17.899wh Cell Soft Cutoff set to lower limit of these 18650's at 2.75v Mod internal resistance measured with copper plug at 0.015 ohms Case Analyzer run at 70 degF \ 21 °C ambient, average over 3 runs Materials and profiles as per my personal use
  16. Version 1.0.0
    773 downloads
    Original Lost Vape Paranormal DNA75C stock settings (.ecig file)
  17. As far as I know room temp is calculated from mod internal temperature. You have to play with Case Static Temp Rise parameter in Escribe mod menu to have a reasonable room temperature. Short story : if measured room temp is high , increase that parameter , vice versa if it is lower than real room temp. But wait for more experienced users feedback ....
  18. hello. Are you sure you have this problem with my theme ? I'm using this theme myself and never had your problem , so I'm sorry i can't help. have a nice day
  19. Heard where ? From who ? When ? Link ?
