BigLarry
BigLarry last won the day on December 16 2024
BigLarry had the most liked content!
4 Followers
  • Full Name
    Big Larry
    Indiana, USA
    Evolve DNA 100c
BigLarry's Achievements
  1. I've had the issue as well. This issue is due to the 100c screen that some of the Lost Vape mods use. It can affect both the Hyperion & Thelema. They use a longer but more slim screen (at least in some.) I know this because I cannibalized 1 to put the screen in a Boxer mod tht died from ejuice. It wouldn't fit. It was too long & skinny. So I had a Rebel & pulled it's screen instead. It was shorter & wider like the Boxer screen & fit. So tht fixed my repair but curious I took apart a new Thelma I had got for Xmas. It had the same slim, long screen that the Hyperion had. Further perplexed & now just messing around I took apart an old, beat to hell DNA 250c from LV. A Centaurus I believe. It's screen fit & was the size of the Boxer/Rebel. I can tell you for sure as I've built a few DNA mods tht if you get an Evolv DNA board the official screen is the size used in the Boxer/Rebel. LV is using a complete different screen instead of the Evolv. It is again longer & slimmer in physical size & display area. I can't speak to why. Perhaps they are using up a screen surplus from past mods or perhaps they had fitment issues late in the game. Either way I THINK the issue is that the LV models w/ the slimmer screen can't fit all the info in some themes tht stretch absolute end to end in design & it causes this. A reset like stated above fixes it & the mod is fine afterwards. I'm not sure that's the reason it looks wonky ofc, but I am sure they've shipped some mods w/ a slightly different size screen. The size is diff enough tht the screens aren't interchangeable into other DNA mods & they sit in a plastic case/frame in the inside to make them fit the LV 100c's. I'll saved the screens in a parts bag in the garage I believe as well. Pretty sure the Giant will work properly after the reset if you run into this as well. It did for me even in the LV screen. If not try a diff wallpaper (if u care.)
  2. Thank you for your comment & for trying it. This by design to encourage color changes & why it's easy to cycles colors . You can set the auto-lock to 4 hours under menu>display which will keep your color the whole day if you prefer. If it bothers enough people that it reverts to white after locking I will attempt to program it to remain. Again thank you & hopefully you enjoy the theme.
  3. Version 2
    237 downloads
    New for version 2: - Perfected color choices - Improved buttons & gauges - Improved text spacing - Massive lockscreen wallpaper dump If you want all text & profile names to fit the theme perfect download my full Escribe Settings. If you want Replay to work on the newest tanks the needed material curves for the various mesh & wire types are in the Escribe Settings below. Download Here: UPDATED 5-29-2022 ESCRIBE SETTINGS.ecig70.37 kB · 89 downloads OLDER - ESCRIBE SETTINGS.ecig57.99 kB · 283 downloads Note If you download my full Escribe settings rather than just the theme: You MUST download & install these Escribe Settings 1st & AFTER that download & apply this theme NEXT. If you just install these Escribe Settings alone you'll be using an outdated version of a different theme. I have renamed the SS 316 & SS 430 profiles that are common to STAINLESS 1 & STAINLESS 2. It makes more sense as you can set the wire type for each SS profile under the settings on the mod itself w/ this theme. I have 316, 316L, 430, & 904L SS in these settings for popular mesh tanks. CHECK OUT MY LAST THEME HERE -
  4. If you got the error on my Color Changer theme then the good news is it was indeed a bug in the theme & not your device. The theme had trouble remembering what parent screen to use after 6 consecutive color changes without going to another screen on the 100c or 7 straight color changes on the 250c. It was indeed a child/parent screen hang up but interestingly not from a missing or bad call. The same call worked as long as you didn't do 6 or 7 color changes back to back. It had to do with the chip memory being so maxed out imo. Rapid color changes would cause it to forget the needed parent & the error sort of reset it. Anyhow it is resolved now. Once I truncated some things, shrunk the theme, & got more headroom in chip memory it resolved itself. if you haven't updated do so & its fixed. I also came up w/ a better system to cycle colors more easily in general in newer versions. My new theme "The Giant" changes colors & is an all original theme that uses color combos tht you can cycle through. If you liked the Color Changer theme you'll likely enjoy "The Giant." Hope tht helps! If it wasn't my theme then I agree tht it's most likely an improper call between a child & a parent screen in the theme. It still isn't a flaw of your mod/DNA.
  5. Version 9
    1,158 downloads
    Also updated the full Escribe settings at bottom of this post for 1st time in months. Use them to unlock the full diag chart, all features, & extra wire types. The largest text I could fit on a portrait screen w/o any cutoff for the things you interact with the most. The preview pics don't do justice to how the theme looks on your actual mod. Change colors on your mod WITHOUT a computer!! Many color combos that have not yet been seen on any mod, DNA or otherwise. No longer are you tied to boring, single color text. Get dynamic color combinations & switch them daily (or more often) w/ a single click. No reused icons, bars, toggles, or assets. Every item was hand drawn in Photoshop by me for this theme. No more remakes of remakes or edits of the same famous themes. This looks different than any theme you've tried. Click the menu button & it opens up the settings to reveal every feature the chip is capable of. Change wire types, toggle Replay, or enable Temp Control per Profile. Lock ohms, set the clock to 24 hour mode, reset the puff counter, & so on. Yes, the battery changes color as it lowers. I'm not going to list every setting. Just know it's all in here & laid out as simple as possible. While I've built all the assets & icons I kept the menu layout as familiar as possible to lessen the learning curve. Spend a few minutes on the Edit Profile screen & you'll get it. After 10 to 15 minutes (maybe less) you'll be fully initiated. If it made sense to move something I did but I made every effort to keep things logical & familiar. Not only is the Watts text large, the highlighting & selected logic was of top priority. No matter what text, slider, or toggle is highlighted (or isn't) it looks correct & is ultra readable. Ever notice how text looks bad or worse when highlighted or selected on the DNA? What about highlighting that diagnostic chart before you select it? This theme was built to resolve that. The more you use it the more you'll realize what I mean. Pick what you like & download it. The themes are all the same besides the Lockscreens. I will likely add more Lockscreens in the future. --------------------------------- If you want all text & profile names to fit the theme perfect download my full Escribe Settings. If you want Replay to work on the newest tanks the needed material curves for the various mesh & wire types are in the Escribe Settings below. Download Here: UPDATED 5-29-2022 ESCRIBE SETTINGS.ecig OLDER - ESCRIBE SETTINGS.ecig Note If you download my full Escribe settings rather than just the theme: You MUST download & install these Escribe Settings 1st & AFTER that download & apply this theme NEXT. If you just install these Escribe Settings alone you'll be using an outdated version of a different theme. I have renamed the SS 316 & SS 430 profiles that are common to STAINLESS 1 & STAINLESS 2. It makes more sense as you can set the wire type for each SS profile under the settings on the mod itself w/ this theme. I have 316, 316L, 430, & 904L SS in these settings for popular mesh tanks.
    A great theme for landscape fans. Many functions, easy to read, & an asset to the community all around.
    This theme is awesome bro. I'm trying it out since I see you putting in work. Love the giant text & the layout. Very professional & overall an exceptional job. I'm impressed & will def try it out in the other orientation. I'd run it if I had more than 1 DNA & the only reason I wouldn't use it is because I have to test & tweak my own theme on my only DNA. It is bittersweet to not use something so good. I see & appreciate the high level of detail & will use this if I get a 2nd DNA
  6. Version v12.0
    659 downloads
    UPDATED VERSION 12.0 - Fixed "Menu Error Press Up" bug - Color button in the status bar now cycles QUICKLY through color options w/o menu diving... FAR MORE ELEGANT - Various tweaks on menu & settings screens ------------------------------------------------------------- Check out my new theme "The Giant" here: All other themes besides these 2 I've made have been removed. ------------------------------------------------------------- Updated - version 11 ------------------------------------------------------------- Change between 11 different colors DIRECTLY on your DNA mod! NO PC REQUIRED Choose between many lock screens w/ more to come. All versions contain all 11 color options. Only the lockscreen is different. ------------------------------------------------------------- FULLY featured & very, very optimized. Replay & TC enabled w/ the ability to adjust both wattage & temp from the main screen. Battery bar w/ percentage that changes from green to orange to red as the battery depletes. Ability to edit all 7 profiles fully on your mod w/o the hassle of connecting to a computer. Tested on a DNA 100c. Now verified working on the 250c. This theme pushes the DNA color chip to the absolute max. Credit to SirTimmyTimbit for the amazing foundation. @SirTimmyTimbit ------------------------------------------------------------- If you want all text & profile names to fit the theme perfect download my full settings posted here. NEWEST - FEB 4TH - ESCRIBE SETTINGS.ecig Note If you download my full Escribe settings rather than just the theme: I'm not going to update my Escribe Settings w/ every theme update any longer. Therefore, if you use these full Escribe Settings you MUST download & install them 1st & AFTER that download & apply the latest version of this theme 2nd. If you just install the Escribe Settings alone you'll be using an outdated version of this theme. It has greatly improved over time! I have renamed the SS 316 & SS 430 profiles that are common to STAINLESS 1 & STAINLESS 2. It makes more sense as you can set the wire type for each SS profile under the settings on the mod itself w/ this theme. I have 316, 316L, 430, & 904L SS in these settings for popular mesh tanks. OLD Escribe Settings use ONLY if issue w/ newer above. MY ESCRIBE SETTINGS.ecig
