Everything posted by TorturedZen
USB unrecognized -I'm stumped
TorturedZen replied to TorturedZen's topic in DNA 75 Color and 100 Color
I have managed to solve the issue although I still don't know what caused it. After a bit of research (to make sure nothing would be damaged) I opened Win10 Device Manager, located the 'USB Host Controller' and selected the option to remove it. Win10 gives a warning that it will reboot. After rebooting, the Host Controller re-installed itself and Voila! All mods are connecting again. Go figure...LOL Thanks to everyone who replied here. I appreciate it! -
Yes, all ports are functional and it sees the Hyperion immediately. -
Good afternoon esteemed colleagues. I have 3 DNA mods - Lost Vape Drone, Dovpo Odin Mini and Lost Vape Hyperion. I can connect with my Hyperion to Escribe using USB 'C' without a problem. But neither the Drone nor Odin will connect using the an older USB 2.0 type cable. All my cables are "data" capable and have used the same 2 cables for quite a while now without any issues. So, I've tried swapping cables and connecting to different ports on my PC. No joy. The funny thing is the mods will charge off the USB, they just won't connect! WTF? Can somebody offer a solution for this before I freakin go postal? Escribe is Ver 2.0 SP 30.1 International - PC is Win10
- harley davidson
- harley
(and 2 more)
Tagged with:
A couple of weeks later...and how is it now?
If you have one why not just measure it yourself?
Concept II - Abstraction
TorturedZen commented on BMan1959's file in DNA 75 Color, 100 Color, 250 Color
odin Enhanced 2 in 1 "DOVPO® / ODIN-special" - Six Designs
TorturedZen commented on CMK's file in DNA 75 Color, 100 Color, 250 Color
The part where you say "...and everything you need is on exactly one screen!" I don't see how. I counted 4 screens initially and now there are 6. With you adding screens, along with boost / preheat and the chart display...are you toggling those functions to fit them on that same one screen? I guess I should just download the file and dissect what's inside to get a better perspective. 🙂 -
I understand your theme just fine. I count 4 screens in your pics. Like you said, the functions appear to be at an absolute minimum. And that's fine for someone who doesn't want to experience the deeper intricacies of the chip. I guess what I was trying to convey though is, if someone wanted a basic TC mod 'just for vaping', there are 1000's of simpler and way cheaper devices that can accomplish that. Vendors always have them in their clearance sections. On the other hand DNA devices are fairly high end. Tinkerer's like you and I are willing to spend extra on these devices just to be able to tweak the shit out them. Maybe I'm wrong and I'm not trying to sound critical so don't take it that way.. But I don't understand the logic that someone would pay the price of a DNA device (knowing what it is capable of) and then re-program it for basic functionality only...by using your theme. That's like driving a Lamborghini and never shifting out of 2nd gear. -
Unless I'm mistaken, they both do the same thing. You can specify the number of clicks to activate/deactivate the lock screen.
Paranormal Carbon Fiber
TorturedZen reviewed biggjohnson2k's file in DNA 75 Color, 100 Color, 250 Color
Sounds like a good idea. If it can be done, which I have no clue, the other mod would probably need to be a DNA also.
TC settings for new ClaptonMesh
TorturedZen replied to kilarskir625's topic in Manuals, Instructions, and Tutorials
If you're talking about the NexMESH/Wotofo Clapton mesh...they aren't compatible. TC requires stainless steel, titanium or Ni200 but the Clapton mesh is Kanthal A1. I've been using the Wotofo RDTA for about a month and I've had to use straight Watts mode on my DNA. Unless they just recently came out with TC versions, but I haven't seen any. -
Chart/Recording options in Theme Designer
TorturedZen replied to TorturedZen's topic in Themes and Custom Screens
Well I hope that's not true because mine changed somehow. I'm positive my graph had 3 different color lines before. Maybe it's theme related so I'll have to check for any discrepancies. Thanks for the reply. -
First question...I've been trying to understand what determines the color for the graph lines in the Chart function. I have Power, Temp and Voltage options selected. When I view the graph it shows Temp in red, but Power and Voltage are both showing yellow. How can I correct this so the graph shows 3 different colors? Second question...in Theme Designer-Chart what is the function of the Time Bars option (defaults to 25) and the color box? Thanks in advance.
So, any word on this. Just curious.
If that's the case then it could be a problem with the theme you're trying to use. Which theme did you use?
Це добре для вапрів, ніж! Добре.
