mackman
Everything posted by mackman
Short answer I do and it does
Unfortunately my week old Orion stopped responding, emailed a RMA request and 1/2 hour later had it....talk about customer service!!
0.25Ω pod will not release...poor manufacturing tolerances? Going to need pliers😆
Received my Orion today and the USB cable is a data cable although not the braided/branded one. Go figure.
HCigar VT75c: do you want one? Think twice.
mackman replied to mjordan79's topic in DNA 75 Color and 100 Color
I have had a red one since they were 1st released and it looks and performs as new. -
Think Vape 250c Thermals Mod res and a couple of battery csv's
mackman replied to Jetro's topic in DNA 250 Color
Positive thoughts and prayers for you Jethro. I am a stage 4 lung cancer( 2 year) survivor...all things are possible -
Green Ohm - English/Deutsch
mackman reviewed Herr Hoeltchen's file in DNA 75 Color, 100 Color, 250 Color
Weak 510 spring pressure, poor solder joints, poor atty pin connection/coil connection , many possibilities, frustrating to sort them out
non temp sensing coils
OK, So WHEN is this NEW software for the 75C coming out?
mackman replied to Joe M.'s topic in DNA 75 Color and 100 Color
Like many others I am anxiously awaiting replay. As a long long time DNA user I am fully satisfied/thrilled with the DNA 75C and can customize my vape onboard to get what I already perceive as a perfect hit each time. -
I had been having problems when starting Escribe getting the message not responding then it would open. I uninstalled and reinstalled Escribe 2.0 SP 9 and the message stopped. I ran the case thermals on a DNA75C mod and when I tried to upload the settings I get this. I also get this message if I try to change any of the profile settings
Asking NEW or OLD coil every time I unlock device
mackman replied to Rburke2x's topic in DNA 75 Color and 100 Color
In regards to asking if it is a new coil each time I read that it was happening for a member only with TI wire. SO I changed to SS 316L and thru several coils it has asked again. -
James that is correct, SP27 is what is installed don't recall about previous versions. -
I had the same problem no matter what I tried. Stopped when I locked resistance -
Just reset the 2.5v cutoff to zero so we will see. Anyone else get the new/old coil message anytime the mod sits for a few minutes?
The problem I have had since the beginning is the check battery message at ~3.40v. I can unscrew/re screw the battery cap and it may be error less for a short while. This is with brand new Sony VTC5 and Samsung 25R batteries. In Escribe battery cutoff is 2.5v. Running a .4 single TI1 coil at 40w and 430 degrees. Really like the ability to dial in the settings from the screen so I just deal with it
Vaping Bad thanks for the prompt response Yes it opens to a folder Evolv>Escribe>Firmware Although I read where the firmware was included in the 9.30.2015 update I thought there was an update included and had lost my friggin marbles
Download and run https://www.dimensionengineering.com/software/SetupES_2015-10-21.exe (51MB standalone installer). Go to Tools>Update firmware..window opens to select file but can't find it (no firmware update type file) Windows 10 OS
Newbie quesfion about device monitor Vi200 box mod
mackman replied to pateyevee's topic in EScribe, Software and Firmware
Pateyevee I would suggest you go thru the Evolv Escribe interactive training course (http://www.evolvapor.com/guide/story.html). It's a good learning tool for learning to use Escribe -
black lace: all up to date vaping bad: no restore or size Thinking it is a conflict having installed over and uninstalled/reinstalled the Escribe. It worked before and haven't downloaded any programs. Only thing that has changed is receipt of Windows update which I can't control
Thanks for the reply VapingBad but move is greyed out
I open Escribe and connect a mod then open the device monitor. It shows on the task bar but it will not show on the screen. It only shows on the screen by hovering over the task bar icon. The main Escribe page projects fine. This has just started, previously it worked as expected. I tried reinstalling Escribe over the current install and even deleted it and reinstalled. OS is Win10
