Everything posted by 67exec
OK, So WHEN is this NEW software for the 75C coming out?
67exec replied to Joe M.'s topic in DNA 75 Color and 100 Color
I can say that replay has spoiled me. I can always tell on a non replay mod when a dry it is coming with an rda, but last night I totally ignored it on my flask166. Totally ruined my tastebuds for like an hr😥 -
The way I understand the wrmth setting, it's used to compensate for the actual temp of your atomizer when the playing puff was saved. Like the difference between the 1st or 2nd puff compared to the 7th or 8th puff in a session
Places to buy DNA 250c Enclosures for custom builds
67exec replied to shroomalistic's topic in Modders' Forum
Here are some references. Hana modz v4 dna 40, Silo 75c, Tesla steampunk nano 100w, ATI b box, and ATI gxl2, regular bic, and a 42mm challenge coin. Pulse 24 atty, and govad atty. Here is an n1 with a titan. -
B box and gxl are bothe 31mm wide. On the outside. I'll post a couple pics in 30min or so -
Aromamizer plus will look tiny on n1, titan would be flush. -
I'm moving to a gxl just so it will stay in my shirt pocket better. Same width and depth, but 1/2"ish shorter than the b box. For me the n1 is a coffee table mod, but I'll still make 1 -
Have you tried uploading the default theme?
Did you try to reset it to default with escribe?
That's how a dna chip works, you can't change it. Even stepping up the current the way they do, they are still one of the fastest hitting boards out there
It doesn't "turn off" afaik. It has locked, unlocked, and stealth. Well off would be no batteries but the clock would zero out
FDA released their 5th revision to the industry guidance that appears to exempt chips and software, coils, wicks, tanks, and several other things. An article That also has a link to the actual revision.
Btw, that's a pulse 24 on top. Got a 30mm tank coming -
The 250c won't work in that enclosure, and that Maxamps 2800 is closer to 1800mah, and voltage sag is terrible. Based on previous experience, the Maxamps will have 19wh-21wh total capacity vs a decent 4s 1600mah will be 22wh-24wh. If you are dead set on 3s, I would buy a 5pin jst connectorLike this. Then wire it like this except only jump pins 4 and 5 together instead of jumping 3 to 4, then 4 to 5 since I was using an old 2s batt I had laying around. Then if you do anything other than 4s, it Will show low battery until you set it as 2s or 3s with escribe. -
I used that box, and battery, ati board holder with drill template, and some m1.6x12mm screws and nuts from the hardware store. Lots of guys glue their board holders, but that makes it super hard if the screen dies. I used a tactile switch that came in a 12 pack from the local hobby store, they were in the arduino stuff for $3.99. I ground out so it will hold 4s 1800. And I use dean's t- connectors since my rc stuff uses them. Also grabbed my board from ati -
How much power do you really need? I can get a full day (6am-11pm) from Ati B Box with 4s 1600mah at 100w-120w and still have 20%+ left -
That wick looks awfully loose in the mesh. I can vape until the cotton is dry to the touch w/o dry hits, just using power mode, when it's so tight that it can't move side to side.
I'm not in front of a comp either, but I'm pretty sure it's in the help tab, then backup. The restore default sets it back to factory evolv settings
I would suggest hooking to escribe and make a backup of the settings, and the theme, then start looking at everything, and maybe make some tweeks here and there to suit you. If it doesn't work as expected, then load your back ups back to the device.
I don't have a dead rabbit, but it sounds like connection issues. May be a good idea to tear it down and give it a good scrub with warm water and an old toothbrush, dry and reassemble. I've had to do that with some of my rda's.
It is designed to give you the same flavour every puff, not exactly the same puff every time. Right after you squonk, it takes more power to get the coils up to the same temp as say the 3rd puff after you squonk, but since that puff is what you saved that's what it tries to duplicate every puff
Maxamps overrates their batts worse than Chinese rewrap 18650's. Mooch tested Maxamps 3s 1850mah and all I can say is I don't get 1
I'd love to see you vape at 400w til the low battery warning on a 2800mah batt
Watt increments are setup in the theme designer
