You dont need to be connected to escribe .. to Change csv profiles, lock device press all three buttons, up down and fire, scrole to desired profile when promted, Change between your eight presets after setting, from an open mod not locked press both up and down buttons to lock up down buttons, double press either up or down button to enter presets, scroll throguh, select by just using what ever is on screen.
What did you say the name of the mod was, some where renound for a robbon pinch, and ribbon loop rubbing on fire button, think one was the hcig.
That box is shorter than a 1590a, but i would go for the said and use a 26650, should be snug and still space for a centered up 510, i hate ofset,,,
no i was on about coming off the board with 4little wires then fitting my jsth connector to them rather than direct onto the board, its just a bit moor move aboutable, but you need all your bits together and think it through whats best and suits you, never needed to shorten the jsth leads off the battery because they just squish down nice and small anyway and it would be pointless extra work, but i have halfed battery leeds and used the half to connect to the board and back to battery via a mechanical connection ie, xt30 ect. Edit.. Oh yeh, i have got someone in mind to do a dna75 for, and then i can say ive built one, and had a good go with it,, but i'm not that taken at the moment, i dont know anything aboug tham.. i'm quite happy with my lipo power paks, moor wattage than i ever need use, except i am pre heat punching Ni200 at 100 watt, so thats one thing to compare..
Rudedog94:: Any new build i fit the board beffor measuring for a battery, unless ive been told otherwise, but have still stripped some of the outer skins off one or two to get to fit (it hasnt worried me, because of being sealed in a metal box,) Xt 60s take up too much space for me, but if you have the room you will probly find that if you have your jsth connector on an inch or so on leads off the board rather than insitue soldered, it will have no pronlem just sliding in between the pos and neg of the xt connector. i cut the male and females out of the xt30s and solder them, and then cover them with shrink tube once connected, just slide it allong..
yes but big, you only have to go 25c constant// 60c puls burst, bet that xt90 will take up half the size of 200 board. you do know that just because its a high output board it doesn't mean the whole thing has to be massive,,
if it doesn't work in your hand but shows signs of life usb connected to escribe, it may be the fuse blown,
when ever its happened to me its been a bad coil connection, try building another coil.. you don't say what wire or ohm, resistance ect
Oh god yeh tin ya wire, nothing worse to give advise and leave a bit out , lol, tin ya wire lad, but not ya board, dont go near it till ya ready to solder to it, just a tiny dab o flux..
DNA 40 (Vapor shark) can it use escribe???
black lace replied to plaibua vithayapul's topic in EScribe, Software and Firmware
Op, you can try other metals on your dna40 in temp mode other than ni200, i know for sure Nife30 works in temp mode and am sure other members when online will list other wires for you. EDIT.. OH GOOD GRIEF MIKE DUDE THAT WAS A MONTH AGO, HES PROBLY KILLED IT BY NOW ANYWAY.. -
Plenty on utube on soldering, Three easy steps 1: keep it clean, wire, board, soldering iron. 2: dab of flux, wire, board, soldering iron. 3: practice ::: on somthing beffor you commit, bits of wire ect.
Yep like a breath of fresh air, weeks can go by beffor you can see somthing that someone has actualy made..
havnt seen many of those, very original, very talented,, yeh, I clicked on that pic to enlarge it and me mug of tea's gone flying across the desk, lol
sos mate i cant help ya with premade stainless coils, i recomend using the build deck and use ni200 or Nife30, but if your set on stainless,,again go for 316 on the build dec and use the pre set value in your mod, people recomend turning off or right down your preheat punch.. in escribe..
So the people at the old address dont know the new address w*****s.
I do to but i have never had any feedback from evolv on what the problem had been on boards ive sent in, i would have thought as a time and production thing it would have gone straight in the bin.. might be different with the one in question if they keep turning up,,,, see what turns up in the wash..
Different screen color from one 200 to another
black lace replied to Wick's topic in General Discussion
Yes ive got three sky blue and one nice white one which i believe to be a true monochrome, there have been some variants in production, one fitting both dna40 and 200 and others, sole 200 and sole 40, even the contractors factory burnt to the ground and then nothing at all for months, so for me anythings better than nothing,, but i do like my white one..... (""So much infact ive put blue plastic over it to keep it safe"":,,lmao) -
""Well done to bill"", so whats the fault then..(burnt out charger circuit??)
Are DNA200s going to be ok carried on board flight USA to UK?
black lace replied to Mac's topic in General Discussion
I dont think its anything to get stressed over, when i send boards out of uk to usa i tell the post master its a dead non live part of a computer circuit no battery no power. When your friend books in, and the same for booking out on the other side, they will have all their baggage with them, the person on the desk will know exactly what to do, its their job, no worries, your friend will definatly not be the first.. -
I got no disrespect to evolv what so ever, they have said on utube ""we will do business with who ever aproches us"",, that is the first rule in business. Every body knows that, even my pet Hyena worked that out, ,, the day i sold him..
Produced by hcig actualy. Your an apology for being to lame to read the thread from op. Assembled in china..
After 20 seconds of reasearch my interest has come to an end now i hear about lights, they must be targeting the seven to fourteen year old side of the market..
He said hes been over it with a fine tooth combe, multi tester, and magnifier..
yeh but via a cargo plane, not civiy, from reputable supply (dhl dont deal with domestic, only too domestic), itamised, labeled, xrayed, sniffed, ect ect. it would have been a lot less anal for him to have orderd direct from evolv, and payed with paypal..
