Each to there own but i think its moor trouble than its worth, Ive been 100 degrees out befor now with stainless, bad wire bad coils bad contact, bad csv, chucked it away and used somthing els and no problems with csv, coil build, contacts ect. also the integrity of the wire may be changeing after heating it, so the resistance is all over the place. As a matter of interest, What guage wire and coil size and wraps have you got for :35ohm
Well done, hope they last you, and i got my new fuse fitted and up and running and chucked away the external charger, so happy happy. Lol
There is a pick of one on here posted a few months back, may be because the boards are made as a slab, and then need to be brocken off into individual pieces, the pressure of a thumb on them may fracture the joint in one in a few thousand, just speculation thoe... ive got a bag of charger boards from a different manufacture where the suppliers have grasped every single one with a pair of pliers at the usb clip and worked them back and forth to break the board away to individual pieces from the produced slab load and destroyed every single one. Just very lightly tin up the solder tabs on the componant and a tiny smear of flux, a sharp blade ended solder tip, (flat screwdriver shape) would do a quicker job of it, i wouldnt even go right down onto the board. A hot iron pressed against the sides of the tabs at the base of the inductor componant, as long as the componants pressesed hard down it will flow, you need to be keeping away from the four legs of the little black (i think fets) next to it, if you bridge one of thoes with spatter or swarf, they will burn up when you fire the mod,,,
They are very cool pics, hopefully as the forum evolvs there will be a coil building section, because it is what its all about. ,,, when you get time perhaps you can put up a full deascription to the pics, then we can all copy and try em..
Update download not possible on windows XP..?!?
black lace replied to stamosz's topic in EScribe, Software and Firmware
I Think he means install, if you right click on the warning, then anouther dialog box pops up install anyway, then select yes. Firefox is good, and you can homepage it to wirewizard for you tfr/csv files In pc world they call it a (picnic) problem in chair not in computer, lol and adammary:: ive got a concreat drive, a bloke knocked the door this morning and asked if ive ever thought about having it tarmaced, i said no. -
Ok thanks for that i'll keep it in mind, glad someone else had noticed, (all these little issues we mod builders have to adapt and overcome) we need to form a union and put the price up, lol, as a general tip to anyone.. I turned some brass buttons out of brass rod, (off an old cistern ballvalve) using an electric drill and a file, face of firing button was about 9mm back end was about 11/12mm with groves either side, then the mounting bolts for the board doubled up as guide rails..
Very nice by the way.... I think the problem ive got with mine, the sides of the box, a zinc alloy, not billet aluminium, its very thin so theres nothing to support the pushrod button travelling back and fourth, if i do anouther build in one of these thin sided ones i'll have to add a bit of plate to create a bit of a cylinder barrel efect..
Which fire button do you like best, round or square,?? Reason is because i imagin the square one to catch on the sides and drag??
well ive put my fuse blowing down to the external charger I was using,,because its quit working now,, you know poitee, not everyones grammer is perfect, specialy mine, and can easily be interprated as either straight to the point or quite rude or both,, English language is quite a simple one compared to many with posertive or negative or male and female, left or right, before the sentence starts, we only use 36 characters compared to the chineese 86, but in short a fact of life, when you throw a question out into the world web, you get an answer, , might not be the answer you wanted, but an answere you get.. I broke one the other day, it was in my hand when it broke, shitt happens.......
too late now by the sound of it, JST leads mixed up????? sorry to undermine if that's what you where looking for dwcraig1..
thanks for that, plenty of time to get my head round it,,, the kantal thing I was on about was pretty much a one off but worked well, stuck for time with a back log of attys piling up waiting to be cleaned and rebuilt, I am very much tc, (for the miles of ni200 and nife30 on the bench) but stuck for time last night I resurrected a little rdta and threw it together with some, I suppose macro coils , a bit of resistance with kanthal, found it was way to hot and out of control on a mech mod, also resurrected, I should think we all get a little set in ones ways when having a few mods and attys collecting, that we build to the atty on that particular mod and don't divert to much, , I had almost forgotten the benefits of simple wattage control through the dna200,,, anyway, got a decent vape within minutes and haven't put it down all day.
I did somthing of simular size in a hammond for someone but with a dna 30 clone, i'll edit the post with a picture of the tin and batteries when i get to a computer,, unfortunatly the tin has seen better days but it would be a nice bit of fun mod with a disstrest look and paired up with a little dripper and nanno coils like a hobo or brass monkey or even a mini rtda like a goblin, a 3ml aromatizer might look a bit posh for it, lol, pic to follow... i only vape myselfe on avarage 11watt on a sigle coil rta all day vape and 30ish watt on a twin coil rdta, and at this moment im using a twin coil goblin mini on :30guage loose twisted kanthal, and 18 watts is all it needs with 1:50mm coils at :46 ohm, so a 3ml tank would marry up nice to a little battery mod, old tobbacco tin.. blar dee blar ect lol..
I cant put an arguement up because i aint built one, but to be perfectly straight i have three twin cell lipol batteries at 1200 mah 8:88 Wh measuring 68mm x 33mm x 4mm at 7:4 volt, i would be keen to use them if possible. But simply because i think i could get them squeezed as a parallal pair into a strepcil tin, and also these tins are or have a slight indented face and back so i could polish it then inlay a bit of timber veneer i have.
So whats that 20% ?? Ok not getting too in depth or out of my depth, theoreticaly, possibly,,, but with either mod in hand, twin coiling throughout the day a flat battery at 3pm or flat at 4pm is why a lot of us carry 2, unless your me with a tray of back up devices backing up my back ups. and again its not my field to explain the performance of lipo over ni
It might be nice but why would they, it doesnt meet with my logical thought, i mean; i bought mine as 200 watt capable boards, and i realy cant get my head round designing and building a mod that houses 2x 18650 batteries, when a tripple cell lipo, doesnt fill much moor space,, If it where a cherrished box, fine engraved with mother of pearl or gold inlay and only a twoes would fit, faire enough, but i would still be saying shame ya couldnt get a tripple in there, nothing worse than running on half engin.. and back to the op, shame this thread never got locked because it has some realy good fault finding tips at the start.
Awsome, got me thinking now, ive got some very nice bur wallnut vaneer, and am thinking of using it with some brass,
Yes very nice, you dont see many wooden ones, i love wood metal combination, specialy tree wood, real wood. What size battery in there?
Blue screen? Or is it just fading out?
Way above me.. pic is at bottom of page 28 lets see your 200s by nick admin
Theres a pic somewhere of about six hooked up to a laptop, might be in lets see your 200 ( early last summer)..
Thats what i said didle i. This fuse tjing must be contagouse ive just picked up a charging mod and blown one. What a headach.
Yeh evolvs 510 is based on evolvs 510, very good observation there,
it happened to me with my first build, what I was doing at the time was only coinsidental , a piece of clipped off coil leg had dropped inside onto the board and shorted across a component and burned it out as well as fireing the atty, I think the piece of wire was probably rattling around in there for a few days before coming into contact with a live component and then shorted the whole thing..
Think thats what they call temperature stabalisation, Above at #5 i didnt screwdriver my mod apart, lol, no silly experiments on my dummies, lol,, at #6, kayfun 4 and lemo 2 both have coil deck connections down to the 510 compramised by poor joints, so may give fauls or wavering readings, dont know about the bilow, i have a couple of lemo 2s and some times the one i aint adjusted doesnt even get read as connected until ive unscrewed it and banged the centerpin down on a hard surface.
