Everything posted by Nick
1. It can be, however the DNA Go is not necessarily intended for use with replaceable batteries as there is no reverse polarity protection. Extra care must be taken if doing so. 2. Yes, it is a wattage controlled board.
DNA Go compatible EScribe versions can be found here; https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite
Can you save your settings file via EScribe using File > Save As and attach it here?
Paranormal 250c and Vapeston Mesh (Avatar) Nano
Nick replied to Mark Pitt's topic in General Discussion
If you can put a ticket in here we would like to take a look at the device. If you can also send that tank with it that would be great but if not we understand. https://helpdesk.evolvapor.com/?a=add- 1 reply
- paranormal
- dna250c
- (and 9 more)
Edit for clarity: This is getting away from the original topic of information useful to the general public and would be better resolved via email or PM.
These coils are compatible with anything the TFV8 Baby Beast coils are. This was really disappointing, I had high hopes for these as they were all listed as SS316 but that doesn't seem to be the case. Coil: 0.4ohm ProC1 Coil Material: SS316 (?) Replay Compatible: No, Dubious While these coils are listed as being SS316 I am not seeing behavior consistent with that. The resistance only went from 0.366 to 0.386 during a puff at the wattage limit of the coil. I did manage to get it to lock in using Dubious mode but it wasn't the best Replay vape I have had. Coil: 0.2ohm ProC3 Coil Material: SS316 (?) Replay Compatible: No Not enough rise to even lock in on Dubious mode. Definitely not SS316. Coil: 0.15ohm ProC4 Coil Material: SS316 (?) Replay Compatible: No Once again no rise. Not SS316.
What is the resistance at the start and end of a puff? That will at least give you an idea of what they are.
This tank is ONLY viable if using the SS316L Mesh Fireluke coils. I however like these coils better in the UForce than the Freemax tank. Coil: 0.12ohm Coil Material: SS316L Mesh Replay Compatible: Yes Coil: 0.4ohm Material: Unknown Replay Compatible: No Coil: 0.23ohm Material: Unknown Replay Compatible: No
Huzzah! Freemax has done a SS316L Mesh Coil and it is awesome in Replay! Coil: 0.12ohm Coil Material: SS316L Mesh Replay Compatible: Yes! Note: These coils also work in the Voopoo UForce tank.
Great! Post up a thread if you would like.
If they are indeed stainless they should work. I will add these to the list for our next purchase thanks!
I have another mesh RDA here and I can confirm that it works with SS mesh so it should work on the cthulhu as well.
Coil: 0.15ohm X6 Coil Material: Unknown Replay Compatible: No Coil: 0.12ohm T10 Coil Material: Unknown Replay Compatible: No Coil: 0.4ohm Q4 Coil Material: Unknown Replay Compatible: No
I know this tank has a ton of compatible coils, so I'm going to need everyone's help here. I know people love these and a lot of people use them. Coil: 0.35ohm Notch Coil Material: SS316L Replay Compatible: Yes Coil: 0.2ohm Material: Kanthal Replay Compatible: No Coil: 0.5ohm Material: Kanthal Replay Compatible: No Coil: 0.2ohm Nickel Coils Material: Ni200 Replay Compatible: Yes
Coil: 0.1ohm 24 Coil Material: Unknown Replay Compatibility: No Coil: 0.3ohm 12 Coil Material: Unknown Replay Compatibility: No
Coil: 1.6ohm Material: Unknown Replay Compatible: No
Coil: 1.5ohm Material: Unknown Replay Compatible: No Coil: 0.5ohm Material: SS316L Replay Compatible: Yes
Coil: 0.5ohm Material: Kanthal Replay Compatible: Yes The coils say Kanthal but it locked in and worked well in Viable mode surprisingly.
Coil: 0.4ohm GTM-2 Coil Material: Unknown Replay Compatible: No, Dubious Locks in with "Allow dubious coils." but I experienced a dry hit when the atomizer was cold. Not suggested.
Coil: 1.6ohm Material: Kanthal Replay Compatible: No Coil: 0.8ohm Material: Kanthal Replay Compatible: No
Coil: 0.15ohm Material: Unknown Replay Compatible: Dubious Required "Allow dubious coils." mode but did work. This tank also accepts the Smok TFV8 style coils.
Coil: 0.15ohm Q4 Coil Material: Unknown Replay Compatibility: None Coil: 0.12ohm T12 Coil Material: Unknown Replay Compatibility: None
Coil: 0.1ohm Material: Suspected Kanthal or Nichrome Replay Compatible: No Only one flat disc coil available for this tank. I threw as much power at it as I could without burning it and the resistance didn't budge. This would be an excellent tank with a SS disc, hopefully they make one.
Coil: 0.25ohm Notch Coil Material: SS316L Replay Compatible: Yes Coil: 0.5ohm Coil Material: Unknown Replay Compatible: No, Dubious Works well enough to enable Replay with "Allow dubious coils." but my experience was not great, but yours may differ.
