Everything posted by Nick
Coil: 0.5ohm Coil Material: Suspected SS316L Replay Compatible: Yes Coil: 0.25ohm Coil Material: Unknown Replay Compatible: No
Coil: 0.6ohm Material: Unknown Replay Compatible: Dubious Works good but your mileage may vary. Will require a warm puff to lock in. Coil: 0.3ohm Material: Unknown Replay Compatible: No
Coil: 0.5ohm Coil Material: SS Replay Compatible: Yes Coil: 0.5ohm Clapton Material: Unknown Replay Compatible: No Coil: 0.2ohm Coil Material: Ni200 Replay Compatible: Yes
Coil: 0.5ohm Coil Material: SS316L Replay Compatible: Yes
Coil: 0.15ohm Material: Unknown Replay Compatible: Dubious This coil requires a long warm puff to be able to save a puff in the normal mode. Once enabled it works well but I do not believe the main coil material to be something with a large resistance change.
Coil: 0.5ohm Coil Material: SS316 Replay Compatible: Yes An excellent coil head for use with Replay. Coil: 0.4ohm Material: Kanthal? Replay Compatible: No, Dubious Your mileage may vary trying to use these, some of them work and some do not. I would not suggesting using these with the 0.5ohm easily available.
Coil: 0.4ohm Material: SS316L Replay Compatible: Yes These coils work great and are one of my favorites. The tank pressure locks a little and may need the top cap loosened enough to allow air in, but they vape great. Coil: 0.2ohm Material: Unknown Replay Compatible: No Coil: 0.16ohm Exo Coil Material: Unknown Replay Compatible: No
If there is no Replay compatibility information available about a specific atomizer you would like to see, leave a comment here and let us know! We are regularly ordering and testing new atomizers and would be happy to pick one up and start a post here with our findings.
Thanks! I don't think rebuildables are worth having in here as the user has near infinite choices of what they want to use. If using Replay is desired then a Replay compatible material should be used. A build that works on one rebuildable should work fine on any rebuildable as long as there is not a connection issue at play. We can certainly have a thread to discuss good builds for Replay though. I do understand that certain builds may be good from a coil fitment and flavor standpoint on one rebuildable, but not another. We'll talk this over internally and find a way to accommodate users that want to share information about a specific rebuildable atomizer as well.
https://www.vapordna.com/OBS-Damo-Sub-Ohm-Tank-p/obsdam.htm
Coil: 0.25ohm Material: Kanthal Replay Compatible: Dubious Kanthal but the coil construction allows it to work fairly decently in "Allow dubious coils." mode. Coil: 0.5ohm Coil Material: Unknown Replay Compatible: None
Coil: 0.5ohm Material: Unknown Replay Compatible: No
Coil: 0.16ohm A5 Coil Material: Unknown Replay Compatible: No Coil: 0.3ohm A3 Coil Material: Unknown Replay Compatible: No
Coil: 0.5ohm Material: Kanthal Replay Compatible: No
Coil: 0.15ohm RX Dual Material: Unknown Replay Compatible: No Coil: 0.5ohm RX Ceramic Material: Unknown Replay Compatible: No
Coil: 0.15ohm VX-033 Coil Material: Unknown Replay Compatible: No Coil: 0.15ohm VX-055 Coil Material: Unknown Replay Compatible: No
Coil: 0.8ohm Material: Unknown Replay Compatible: No Coil: 0.5ohm Material: SS316L Replay Compatible: Yes
Coil: 0.2ohm Material: Unknown Replay Compatible: No Coil: 0.4ohm Material: Unknown Replay Compatible: Dubious The 0.4ohm coil seemed to work fairly reliably. I do not believe it to be a material with a well defined TCR however due to the construction of the coil it locks in easily and vapes well.
Coil: 0.2ohm Coil Material: Unknown Replay Compatible: No Both of these tanks use the same coil. I could not get this coil to function in Replay.
Coil: 0.15ohm Coil Material: Unknown mesh Replay Compatible: No, Dubious Your mileage may vary, however I would not expect this to work reliably due to very low resistance change. A long hot puff in "Allow dubious coils." mode may be required to get it to even lock in.
Coil: 0.2ohm Material: SS316L Replay Compatible: Yes Coil: 0.4ohm Material: Unknown Replay Compatible: No
The purpose of this sub-forum is to have an easy place for users to reference Replay compatibility with replaceable coil head atomizers. Please feel free to jump in on any atomizer post to discuss your experiences. If you are aware of any coil heads that are cross compatible feel free to add this to the discussion of the specific atomizer. If you have a Replay enabled device and an atomizer that was found to not be working, give it a shot anyways and see what you find. We would like to keep the post structure in this forum as follows so users can find the information they need about specific atomizers. Subject - Manufacturer Name Atomizer Name - Replay Compatible/Incompatible/Replay Dubious/(an explanation if it's not so simple) Note: If an atomizer works normally, that's Replay Compatible. If If it does not work, that's Incompatible. If you need to use the DNA 250 Color setting "Allow dubious coils." in Mod->Safety, that's Replay Dubious. If it only kind of works, please provide an explanation. Message Body - Coil: Name and Resistance Material: Coil Material Replay Compatible: Yes, No, Dubious, or an explanation if it's not so simple
My apologies. I don't see any tickets in our system recently, how are you trying to contact us? Get a ticket in here and we would be happy help. https://helpdesk.evolvapor.com/?a=add
