dwcraig1
Everything posted by dwcraig1
  1. I have or had quite a few DNA mods powered with a FullyMax 900 mah battery. Keep in mind that it has the same capacity as a 30 amp 2700 mah 18650. I have my doubts as to try to fit in a larger battery.
  2. What wattage are you using it at ? Have a look at this thread: https://forum.evolvapor.com/topic/72119-dna-100c-wattage-drop-after-3-puffs-geekvape-z100c-p-coils/#comment-940230
  3. I really like this post, thanks for the update.
  4. It would probably be best to ask how to get one here: https://helpdesk.evolvapor.com/index.php?a=add&category=3
  5. dwcraig1
    Pinout?
    It seems as I might need them new glasses sooner than I thought. It said 80 but I saw 60.
  6. So if you don't look at the numbers.....how does it vape?
  7. The wick had time to re-saturate perhaps. I'm going to send you a message.
  8. Here are the screens we want to see, not the screen on the mod.
  9. Even though it's a tank you still should be able to drip juice on the cotton to see if that changes things.
  10. My first thought is the wick/coil drying up. Can you maintain 50 watts when in temperature control? Or does the same thing happen?
  11. The situation where you have 3.2 volts between output and ground is troubling. This is something that I have no experience with so I measured the voltage between output and ground on two of my DNA60s and my one DNA60C, all three read about the same, just over 0.7 volts. And no change if fire button pressed.
  12. A lot of computers with USB 3 ports still have a USB 2.0 port as well. Did you try plugging into a different USB port? I should delete this as it's a USB-C board but will leave it. Please disregard above.
  13. I'm thinking you said you connected with EScribe prior installing board in the enclosure. Yes/no.
  14. Well as a starting point what version of Escribe are you using? You should be using the latest version.
  15. Yes, if that doesn't work we'll try another way
  16. We have never heard of one not being recoverable so just be patient and follow our directions.
  17. The setting for 18650 is correct for a 21700. The difference between the settings is the Cell Soft Cutoff of which an 18650 and 21700 are the same. The items in Device Monitor with the ? mark fill out only when firing. As far as what's on your screen goes that is Theme dependent. You might save your theme and try another one. I recommend starting with Evolv's stock theme. Having all the boxes in Device Monitor checked is quite confusing. I edited your post as it needed it.
  18. It looks to be wired correctly to an Evolv C board. Avoid using a USB hub.
  19. Either with wire or solder bridge. G and B- need to be bridged together. Then 2,3, 4 and B+ need to be bridged together. The yellow is cell #1 positive.
  20. Have you ever tried using a different battery?
  21. So now is the live ohms higher or lower than the cold ohms in Device Monitor when firing?
  22. Your mod resistance of 0.15 ohm is way off from what would be expected, how did it get set to that? Default setting is 0.004 ohm so actual measurement shouldn't be very far from that. I can imagine something like 0.012 ohm but not 0.15 ohm
  23. What should I do to solve this? Your battery voltage drop. Either your cell is really weak or there is a poor connection between battery and board. If this battery works well in another mod then check that it's tight enough against battery contact. Check all battery connections are clean. With a load of 27 - 32 watts I would expect to see voltage drop to about 3.8 volts or higher with a cell that's nearly fully charged.
