giz_60
Everything posted by giz_60
  1. Probably just a hiccup in the software...at least you can download now...
  2. Takes a little while for download permissions from the software...even though you have received a confirmation email...
  3. Bottom right hand corner of 'Device Monitor'....Escribe should notify you if there is an update available...
  4. Sony_VTC4 (2)_18650_2100 mah_14.62 Wh.csv
  5. Can you post a screen shot of the 'Mod' tab & 'Device Monitor'....
  6. No LED on the 166
  7. No LED on the 166...
  8. Good to hear everything is working for you now!!!
  9. If Escribe is closed & you open it up with a device attached, it will load up that device...if Escribe is already open & you connect a device, it will ask...
  10. Try downloading this one.... Kanthal_A1_preheat.zip
  11. Are you talking about on the 'Available Materials' list or 'Materials on Device' list?
  12. You will need to go back & read the thread very carefully...it's not plug & play...it's a CHEAT...the DNA devices were not designed to provide pre-heat in power mode...there is some tweaking that you MAY/WILL have to do to get it to work properly...all the info is in the thread....take your time...it does work...been proven...
  13. I think he was referring to those Brillpower pinks.../topic/65693-topic/ ...CB tried to warn him, but if you read the last post, you will see he learned the hard way...
  14. Glad to hear it was an easy fix...you could try spacing out those aliens...
  15. Sony_VTC6 Sony_VTC5 I have both & the 6's have the most Wh's, but I have an issue with them fitting in my Triade...The cover doesn't seem to want to close all the way...
  16. The only setting, that I am aware of, that might affect run time, is the "Maximum Puffs' / 'Maximum Charge' setting...MP will allow the battery to fully charge to achieve a slightly longer run time between charges & MC will stop the charge cycle short of full charge to prolong the overall life of the battery...the default setting is usually MP Running battery analyzer will result in settings that will improve the accuracy of the battery indicator on the device...Wh's & a .csv for your set of batteries, no difference in the run time...
  17. Just open Escribe, if you haven't updated it in awhile, it should inform you of an update to 1.2 SP5.2...any device, 60,75,200 or 250, that is connected, Escribe will open the appropriate version...
  18. Can you post a couple of screenshots from Escribe...'Mod' tab & the device monitor while firing with the following boxes checked...power, power set, temperature, temperature set, cold ohms & live ohms...
  19. It would appear so, but to get a definitive answer, you may want to shoot Evolv a ticket...https://helpdesk.evolvapor.com/?a=add Evolv warranties the board for 1 yr....you can check the info of the board in Escribe on the General tab>Get Information...
