retird
Everything posted by retird
  1. No link needed.... I got my information straight from Evolv on January 14, 2017 neither will be discontinued ....I usually go to the source to verify the validity of rumors when needed.... But yep, a DNA250 can replace a DNA200 in a device as they are the same physical sized boards....
  2. I think this may be helpful..... @ChunkyButt200 posted it.... /topic/66374-topic/?do=findComment&comment=896685 @VapingBad posted this..... /topic/67272-topic/?do=findComment&comment=905461
  3. How many computers or wall chargers have you used to try to charge the device? Have you tried several USB cables? Have you cleaned the battery contacts on the battery sled? What batteries are you using and what is their age? What have you done to try to get it to charge? A bit more info would help I think. Review of your 4 screen shots of Device Monitor: Screen shot #1: 0.00 WH Cell 1: 3.18v Cell 2: 3.41v. Cell 3: 4.08v. Puffs: 61818 Screen shot #2: 6.+ WH 3.96 4.03 4.01 61846 Screen shot #3: 4.+ WH 3.77 3.88 3.84 61909 Screen shot #4: 10.5 WH 3.67 3.72 3.69 61967 Please post another screen shot showing the latest Mod tab settings. Also a screen shot of Device Monitor showing Cell 1, Cell 2, Cell 3, and wattage while firing the device. THX
  4. I'm guessing you had a few hours invested in machining that one....
  5. And just a further note..... while charging with the red led showing as it reaches 100% the charge rate decreases and you may think it will never turn green..... be patient...
  6. Kinda looks like most of your Mod settings don't agree with the .ecig file from Wismec. You might consider installing the default .ecig file from Wismec Jabo again and see if that helps. You might want to save the .ecig file that you are using first before installing the default .ecig from Wismec Jabo. Here is the web site where you can download the .ecig file from Wismec Jabo (Reuleaux DNA200) : http://www.wismec.com/product/reuleaux-dna200/ Here is the downloaded file if you want to use it or you can download your own: W009-151116-2.8V-CASEJB.ecig
  7. Not much info to go on from the OP yet....
  8. It seems you all heard or received poor information...neither one is scheduled to be discontinued....
  9. What is set in the Mod Tab.... Maximum Puffs or Maximum Recharges ? They charge to 4.2 and 4.1 V per cell respectively.
  10. Try downloading it again.... If it won't download then..... Try to download this zip file....... I zipped the file you posted you wanted... see if you can get it this way dna_250.zip
  11. Try adding a material with the name you want to the "available" with no device connected (with the csv you want). See if it shows up after opening EScribe again without any device connected. Connect device again and see if it is still listed in "available". Add the material to the materials on the device. Check that the proper material name is in the related profile. Once you add the material with the name you want you can delete the materials you don't want I think. I'm not sure that certain materials in the "available" can't be deleted by default....
  12. So are you saying you are saving the .ecig file as a different name after changing what you want? Then uploading the saved .ecig file to the device? Note: I always save the original .ecig file of the device so I can reload it if I need to.
  13. So, after you change them what process are you doing to save the changes? It could also be that you are using the material you are changing the name of in a profile.
  14. You welcome.... enjoy and somebody here is usually available for further discussion. Your last screenshot post was most helpful.... THX
  15. If your coils are contact coils try spacing them also... 15 wraps per coil is a lot of wraps.
  16. You have Temp Dominant checked in your profile thus Temp is displayed.
  17. Can you post a Device Monitor screenshot showing Power, Power Set, Temperature, Temperature Set, Cold and Live ohms? Each coil you have is almost 0.8 ohm's? Have you tried using a default profile for SS316L?
  18. Great news.... That seems to be a common issue with some devices and not a board related issue but a device manufacturing issue..... my thought is that the device maker is the point of contact for assistance instead of Evolv. Enjoy.....
  19. The device is not seeing your coil as a TC type coil. It is vaping in power mode and in power mode while running it is set to display volts. What type of material are you using to build your coil and what type coil are you building (standard, clapton, fused, etc.)?
  20. Let us know what Lost Vapes says or does. After all they made the device....
  21. My guess is that you are seeing "battery sag" with the 26650 which is not quite up to the task. You say 18650's work just fine so I suspect the 26650 battery.
  22. Please let us know what the problem is/was.... may help others...
  23. OK.... try forcing the firmware SP update you just mentioned again to the device just to see if that might help ya....
