Everything posted by retird
EScribe Suite 2.0 (for DNA 75 Color)
retird replied to James's topic in EScribe, Software and Firmware
Might just put it here as a new area will be created soon.... you could edit your last post and add it there if you like.... THX -
The theme I'm using does round robin the profiles and also can scroll one way or the other. It would be nice to only show the Profiles set up by having the choice to hide unused ones... I'm not fluid in Theme Designer yet so I don't know if it is already possible to create a screen to do that????? -
Both versions downloaded fine here... using Chrome 64 bit version... -
600F is not enough for stainless steel coils!
retird replied to sdmf74's topic in EScribe, Software and Firmware
THX for the links to the coils... I've not used any of those coils but I do use Aspire ss316 coils and Wismec Notch coils (similar coil as the one in the EC NC 0.25ohm Head). My experience has been that all of the ones I use operate well within the wattage specs of the coil @ 400 to 450F for me. I use these coils in the attys recommended by the manufacturer. Quite a while ago I purchased an atty that was said to be compatible with the Aspire coils. I tested it using the coils I like and got the exact results you are getting (but I didn't run the temp up to 600F). I did boost the temp up to 550F and got a weak vape so I made sure I tightened all connections and made sure all 510 connections were clean and making a solid connection. The vape then reached 550F and about blew my head off.... was very hot.... Needless to say I don't use that atty.... I always make sure both the atty and device are at room temperature when starting a new coil or switching atty's... Probably not much help to you but that's what I got.... Here is the .cvs file for the SS316L material I use... SS316L.csv Hope you get it figured out.... -
Vaporshark has after-sales service on the 200... their boards are proprietary.... you can contact them... https://www.vaporshark.com/dna/devices
Which specific premade coils are you using and which atty are you using them in? How about a link to the Eleaf and Aspire coils you use. -
hum..... don't think I' ever used a 3S2P (6 cell battery) in a DNA..... Specs: Capacity: 4000mAh Voltage: 3S2P / 6 Cell / 11.1V Discharge: 15C Constant / 30C Burst Weight: 296g (including wire, plug & case) Dimensions: 107x35x31mm Balance Plug: JST-XH Discharge Plug: XT-60
new DNA 75-C questiuons (orobably for staff)
retird replied to alfie's topic in DNA 75 Color and 100 Color
Just a bit more info in reference to the DNA75 Color.... Evolv is introducing an area that will be accessible from the forums for sharing themes. Kind of an app store for themes. Their hope is that it will have previews, descriptions, ratings, and be searchable. -
@dwaindablane and @soulseek.... Attached are the files you asked about.... and Evolv indicated to me today that they hoped to have the EScribe Suite up today or tomorrow.... DNA75C with tabs.zip -
Just set up one of your profiles similar to this and upload it.... You can set the Wattage, Temperature, Preheat, Punch, and Preheat Time Limit to your liking...
Import this into your Available Materials and then add it from there to the Materials on Device. Then upload to device... Then make your SS316L Profile....and upload SS316L.csv
Can you post a screenshot of the Material tab in EScribe for one of the devices so we can see a list of materials that you have....
I have given up on the Lost Vape Therion BF in temp control mode
retird replied to Little Brat's topic in DNA 75
giz... I'm backing out as he is confused with more than one trying to help... I think his material SS316L he is using actually is for Ni200... he has 2 materials named SS316L so choose the other one... good luck... -
And I might add..... in Profile 1 the coil material is set to SS316L... check that drop down list and see if there is another SS316L to choose. If so, select it and see if that helps... Your post #4 shows 2 SS316L materials installed on the device... -
What wire is in the atty Ni200 or SS316L? -
You might compare my SS316L material profile to the profile you posted.... they are quite different.... guess you made that profile???? -
Some of the folks at Evolv drop in from time to time but we volunteered to kinda manage things and etc. here...... -
@dwaindablane and @soulseek: You should contact Evolv's Help Desk with these questions you are asking and the request for Cad files.. The Administrators of this forum are not employees of Evolv and I, for one, don't have the answers but will do some checking..... Help Desk: https://helpdesk.evolvapor.com/?a=add -
A single battery device typical..... A few early videos if you are interested... https://www.e-cigarette-forum.com/forum/threads/vapedroid-x1c2-evolv-dna75-color.798531/ -
VTBox 250 Broken Screen / Dead Box
retird replied to JohnHaley's topic in Connectors, Components, and Accessories
You just said it appears to be firing. If it won't fire using the "Puff" function for 3 seconds then you may have a problem with the device or the circuit board. You might contact the vendor if the device is still in warranty. If not in warranty you could start a ticket with Evolv and they will guide you... Evolv Help Desk: https://helpdesk.evolvapor.com/index.php?a=add&category=1 -
Your latest graph doesn't show it firing... try vaping when you select 3 second puff... does it vape ? -
Now unlocked so try the "puff" feature again to see if it will fire... The Puff usually will fire even when the device is locked tho.... -
5 clicks of the fire button to unlock.... -
With device connected could you go to Device Monitor and then select "Puff" in lower right corner and then select 3 or 4 seconds and see if the device will fire? -
I've not used these batteries.... Mooch tested this battery: https://www.e-cigarette-forum.com/forum/threads/awt-40a-3000mah-18650-bench-retest-results-only-a-20a-battery-damaged-at-over-30a.717124/
