retird
Everything posted by retird
  1. Picked up a C-to-C cable at Walmart... less than 4 bucks.... Charges/data flow...... on my Windows laptop charging the 100C device at 3 amps
  2. DNA Go Orion manual if it may help ya... https://www.lvevapor.com/wp-content/uploads/2018/11/Orion-DNA-GO-User-Manual-min.pdf
  3. Was curious about the theme I'm using on a 100C Hyperion and the unlock interval.. Was able to unlock by slowly clicking the button with 5 clicks over a 20 second interval. Clicks were about the same interval between clicks ( about 4 seconds in between clicks). Haven't looked at theme designer yet but will nose around a bit...
  4. https://icons8.com/icons/set/battery-status https://www.flaticon.com/free-icons/battery-level Google is your friend....
  5. Mod Resistance was preset in my Hyperion 100C at 0.004 just like all of my other DNA. Haven't done a test tho..... seems just fine to me as I use the same setting in TC on it as with other DNA's. Let us know if you test it... in Atomiser Analyzer the Raw ohms plus the mod resistance ohms gives me the same reading as shown on the device rounded to 2 decimal points..
  6. Hum, why does my screenshot not look like yours... (item marked in RED.) I'm using the latest EScribe I think.... Version 2.0 SP30.4 I have no problem adjusting and uploading the cold ohms
  7. From my archived notes: How to get the DNA40 to re-set the TP resistance reference: Turn down to 1W, turn off TP, fire mod in wattage mode, disconnect atty, turn TP mode back on, put atty back on. Should clear the TP reference and re-read. Note: This is rarely actually required and does not indicate something wrong with the board.
  8. Thunderbolt enables data transfer, charging, and video output all through a single port — and MacBook Air has two of them. Would something like this work? https://www.amazon.com/JSAUX-Charger-Braided-Compatible-Devices/dp/B0828Z13J5/ref=sr_1_1_sspa?dchild=1&gclid=Cj0KCQjw_fiLBhDOARIsAF4khR0DkoqgUVb5YidGi4B8wcZyaBgaWEWbRMPOGQxkMoZoKB8QUaO43U4aAuyCEALw_wcB&hvadid=557567559350&hvdev=c&hvlocphy=9026243&hvnetw=g&hvqmt=e&hvrand=756348208532192458&hvtargid=kwd-403004777730&hydadcr=951_1014953149&keywords=type-c%2Bto%2Bmicro%2Busb%2Bcable&qid=1635678347&sr=8-1-spons&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyWTNNNE1LSFdTT1lKJmVuY3J5cHRlZElkPUEwMzUwNzE0M01NN1M1RzYxME9EVSZlbmNyeXB0ZWRBZElkPUEwNTMzNjYxMkRXWUE1RlFHVTJXVyZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU&th=1
  9. Guessing it's the boost or preheat?? You can always check the Theme in Escribe Theme Designer. Hammer of God 400c
  10. Lots of info that may help can be seen/downloaded and etc. The datasheet has a lot of info. EScribe software is also very beneficial.. Assuming th Kenedy has the DNA250 board... https://www.evolvapor.com/products/dna250 More links: https://www.google.com/search?q=Kennedy+box+mod&rlz=1C1CHBF_enUS840US840&oq=Kennedy+box+mod&aqs=chrome..69i57j0i22i30l4j69i60l2.17821j0j15&sourceid=chrome&ie=UTF-8 https://www.google.com/search?q=kennedy+box+mod&rlz=1C1CHBF_enUS840US840&source=lnms&tbm=vid&sa=X&ved=2ahUKEwiElNmjxaXzAhXVgGoFHd63B68Q_AUoA3oECAEQBQ&biw=1600&bih=937&dpr=1
  11. Big Black Blob appeared the other day that covered most of the words " Replay Active". Didn't appear to be cracked screen so just monitored it. The Blob, over several days, moved to it's current location and is smaller now. Guessing just a bit of juice floating on the glass screen.... Still getting smaller so we will see.... Worst case I can open up the device and do a bit of cleaning...
  12. LOL.... Not interested in clouds or fog here but wondering if duals and very short puffs would have an effect on flavor... can always just use 1 coil....
  13. I do MTL and DL just a bit.... .... TC and Replay.... Just got a DL 28mm RTA to experiment with dual "notch coils" ????
  14. Well, as 1 who has used SS316L "Notch Coils" for years and many moons ago fine truned the vape in TC I enjoy the consistant vape in TC and Reply. No fiddling with making coils, adjusting TC Profile and etc. An Example: https://www.fasttech.com/products/0/10014736/9623837-mkws-316l-stainless-steel-notch-coil-10-pack
  15. UK Warranty Repair for DNA: https://www.stealthvape.co.uk/evolv-warranty-repair/
  16. You might contact Visionary Mods especially if less than 30 days old. See if they will help you. Nice mod by the way....
  17. If the screen gets crcked it can go black. Any signs of a crack?
  18. Are you comparing the 250 C to a device that is not a DNA and that is why you need to adjust 50 up/down?? Simple answer: Start a ticket wth Evolv and link this thread and EXPLAIN what you want to know. Link: https://helpdesk.evolvapor.com/index.php?a=add&category=1
  19. AND... contacting the Help Desk gives you the ability put a link to this thread and also fully explain the issue to Evoilv Support. You can also attach and send the Help Desk the pictures... no middle man needed...
  20. That's why multiple cells in a device should be "mated for life" and only used together.... but we already know that... just saying in case a new vapor drops by...🙂
  21. There are web sites out there such as these.... https://www.stealthvape.co.uk/product-category/mod-parts/ http://analogboxmods.ca/Box-Mod-Kits https://www.motleymods.com/ And this may help also... lots of video help https://www.google.com/search?q=build+your+own+box+mod&rlz=1C1CHBF_enUS840US840&source=lnms&tbm=vid&sa=X&ved=2ahUKEwj9m5yfpYvyAhUPOs0KHd0kAuUQ_AUoA3oECAEQBQ&biw=1607&bih=946
  22. Connected to Device Monitor in EScribe you can see how the device is managing watts/temp/battery/battery sag and etc. while firing You are not using Kanthal from what you posted which is stainless steel.... wondering if it is just battery sag while firing??
  23. You are using just 2 batteries thus the max output is reduced from what a 3 or 4 cell device will do... this datasheet may help... https://downloads.evolvapor.com/dna250color.pdf
  24. Lots of videos out there... been there for a while.. google is your friend https://www.youtube.com/watch?v=kaciYP5IrCMhttps://www.youtube.com/watch?v=J9dejMw5Q2g https://www.youtube.com/watch?v=yYfZclDRgiY https://youtu.be/kaciYP5IrCM?t=4
  25. Download EScribe, connect device to it. Then open Device Monitor and see what the voltage of each battery shows. Also on the main page of EScribe in the upper left it will show if an update is available for the software.
