retird
Everything posted by retird
  1. All of my devices are DNA devices (and have many of them) and the mod resistance has been set on all of them. They all measure within very minimal difference between each so close that I use the same profiles on each device depending on whether in TC, non-TC, or in Replay (for the 75, 100, 250, or 400C models). You lost me when setting the wattge to 1 watt for safety....??? I never use a screwdriver to short the connector...
  2. You might try using an ohm meter to verify ohms on all 3 devices 510 connectors (no atty attached). Record your results. Then use the ohm meter to check your installed coil (atty not attached to device) where the coil connects to the atty and then check the ohm reading at the atty connector where the atty screws into a device. What are your results?
  3. If you mean the lock screen click the fire button 5 times to lock. Click 5 times again to unlock...
  4. Could be just the design and construction of the SXK device.. The atomizer installation inside the tank could very well change the total resistance especially as the positive post just pops in and the ground of the atty is connected only by the the threads of the top cap thingy...
  5. What he said and FYI 2_SP31_INT works on my computer with latest Windows 11 updates... has ever since Windows 11 came out...
  6. Why not just use the onboard LED. As an example One of my 100C flashes blue when the fire button is pushed... And another 100C flashes purple.... Drill a small hole in the enclosure in the proximity of the LED on the board. This Led can also flash colors while the device is charging and also color changes when charged.
  7. Good point @BillW50.... Max puffs vs. Maximize Recharges.....
  8. This is the default 4 cell builot-in Battery CSV from Evolv in case you wnt to compare:
  9. Another thing that might help is to charge to full charge cutoff (while watching in Device Monitor). When the charge completes (100 %) leave the device plugged in and see that the 100% charge drops a bit (say to 97%) but it doesn't start charging again. Unplug from USB and plug back in and it charges again for a short period to 100%. I alway thought after charging the battery settles from charging a bit thus dropping slightly off 100%. . The drop from 100% to say 97% is very nominal if you look close. Also look at the battery CSV in Escribe. An example is an 18650 battery at full charge say is 4.2 volts and at say 94.6% it is 4.1 volts. So 1/10th of a volt. That's nominal Also remember that when charging voltage and amps are being fed into the battery thus the reading can change as the charging stops. Have noticed this for years. Quiescent Current is very minute but constant while not using. And looking at your screenshot 97% equates to a voltage drop of approximately 0.023 volts at each cell... and is the battery csv taylored to your 4 cell battery configuration?
  10. You can't compare the DNA chipset to non-dna chipsets.... Burning cotton usually can be addressed by changing wattage and/or boost if vaping in wattage mode. And the same wattage and boost (if avialable) settings of non-dna devices may not give the same results on a dna device. The chipset and firmware are way different. Try and adjust wattage and boost a bit to stop the burning of the cotton... Temp Control on a DNA can be set to prevent burning of cotton but the coil material must be a material that Temp Control can use.
  11. Datasheets for the 200, 250, and 250C....: https://downloads.evolvapor.com/dna200.pdf https://downloads.evolvapor.com/dna250.pdf https://downloads.evolvapor.com/dna250color.pdf
  12. Total puff since new is 937. That can't be reset...
  13. If you are using "C" data cable and the INT version of Escribe it should work...Start a ticket at Evolv and they will guide you... link in my sig lines below...
  14. What version of EScribe are you using..
  15. As said before... Your board has an official 1 year warranty, but you can open an RMA at https://www.stealthvape.co.uk/ and they will guide you
  16. Could you post a picture of the screen and board while it is in the device? Also a picture of the screen and ribbon cable while outside of the device... Ribbon cables can easily be damaged when bending into a tight space.
  17. Good deal.... enjoy...
  18. In EScribe go to Device Monitor and post the info in the lower right corner. Version and date... Also what version of Escribe are you using? Under Help/About EScribe you will find the version.
  19. Haven't loaded it yet on the 4-cell 250C... at first glance looks good tho...🙂
  20. The looping menu may be one of the buttons being stuck against the case after you push it... I had 1 do that.....
  21. Great that the device maker has 1 yr. warranty. Start there. I see on the internet that the 4 posts on the battery door are soldered to the cross member metal and excessive heat can cause disconnect of 1 or more of the posts from the metal cross member. You might look there and check continuity between posts...
  22. Saw this Repair kit. Could that be the issue??? Not often we see a mod repair kit.... https://vaperzcloud.com/product/repair-rebuild-kit-for-hammer-of-god-v4/ Saw this also... clik on this... Also you could start a ticket with Evolv. Board has warranty from Evolv. Device does not nor do they have device parts.. What is the warranty from where you purchased this....? https://helpdesk.evolvapor.com/index.php?a=add&category=1 Also watch this....
  23. Can you post a screenshot like this one from Device Monitor?
  24. Content deleted.. posted info for wrong device....:
