vapedoctor Posted June 8, 2019 Report Posted June 8, 2019 im trying to learn how to create my own theme for both my 75c and 250c and im having a super hard time understanding it. I wanted to see if anyone could explain to me or send me in a direction that I could learn how to go through the entire process. if no one can help me through the entire process is there anyone that could help me understand how to setup a screen for replay so that I could maybe add it to a theme I already have??? sorry im new to all of this and im teaching myself, I have no one to help me out so im turning to you guys!!!!
retird Posted June 9, 2019 Report Posted June 9, 2019 There are a lot of themes designed by others in this forum.... here is a link to 75C and 250C themes you can download. https://forum.evolvapor.com/files/category/6-dna-75-color-250-color/
vapedoctor Posted June 9, 2019 Author Report Posted June 9, 2019 Yes I'm aware that there are many themes already made ready to download. I want to learn how to create my own theme... I'm just looking for a tutorial on exactly how to do that. I'm looking for someone that can give me a run down of ex as ctly what everything means. Again I'm new to designing the theme. Not new to the evolv forums and using someone else's themes.
Wayneo Posted June 9, 2019 Report Posted June 9, 2019 @vapedoctor DJLSB has done a tutorial on theme designer for sure (YouTube), that I used in the beginning. Or, you can find an already created one, that jives with you and use it as a base for your own. 20 hours ago, vapedoctor said: if no one can help me through the entire process is there anyone that could help me understand how to setup a screen for replay so that I could maybe add it to a theme I already have? So looking at the Evolv defaults, Profile 8 has "Use replay on this profile" enabled. The Evolv default theme (in Theme Designer) 'Main Screen' shows the conditions. Temp sensing, Can Replay, Can Replay now. - So if you load and use that, you can follow along with the behavior. For the Can Replay Now, you'll notice it's a 'toggle' (On/Off) with a different graphic for each. Hope this helps.
zark Posted June 10, 2019 Report Posted June 10, 2019 12 часа назад, Wayneo сказал: Тема по умолчанию Evolv (в Theme Designer) «Главный экран» показывает условия. Temp Sensing, Can Replay, Can Replay сейчас. Насколько мне известно учебника не существует. Но это порождает многообразие themes в которых разные авторы предлагают разные пути решения задач, по тому что нет единой методики предложенной производителем! Wayne описал правильный путь, нужно брать Evolv default theme и использовать уже готовые элементы управления. После того как у Вас появятся необходимые знания и навыки в создании собственных разработок можно пробовать использовать и редактировать фрагменты других авторов. Если Вы будете внимательным и последовательным, то очень скоро Вы будете прекрасно понимать назначение каждой команды, а также условия при которых её можно использовать. Не бойтесь и не ленитесь экспериментировать, и все получится! Удачи! 1
Vapors Tongue Posted June 10, 2019 Report Posted June 10, 2019 Best way to learn is understand the original default themeworks , learning what each setting does familiarize yourself with how the menu works and the settings in escribe where your profiles are located , then download another theme whichever you like and make small changes like wallpaper or the way the layout is positioned make small changes - then understand how the theme is configured looking at how each setting is configured and how to replicate it , it takes time and with time each theme you make will become better with time
