greenj22 Posted August 11, 2018 Report Share Posted August 11, 2018 Hi All, I have looked at, read, re-read, and been attempting to get EScribe/data connection using a generic USB breakout board. My understanding: From breakout board to DNA60: VCC to pin 15 via 10K ohm resistor Data + to pin 14 Data - to pin 13 @ChunkyButt200 can you please help? No connection. I’ve tried this several times on/off for a looooong time. Help is very-much appreciated in advance. And yes, USB cable is data capable. Link to comment Share on other sites More sharing options...
retird Posted August 11, 2018 Report Share Posted August 11, 2018 Datasheet gives pinout...... see Pin Out Page https://downloads.evolvapor.com/dna60.pdf Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted August 11, 2018 Report Share Posted August 11, 2018 You need to apply power to the board before EScibe will see it. (4.20v to batt neg and batt pos pinouts ~ 10 and 9, respectively). You have the data part covered corretcly now you just need to wake the board up with some juice. Once the board is powered on, then connect the USB cable to EScribe. 1 Link to comment Share on other sites More sharing options...
Wayneo Posted August 11, 2018 Report Share Posted August 11, 2018 @greenj22 Are you going to leave that permanently soldered? I notice a BB on your bench, and my connections are always removable cuz I just couldn't figure how to mount the board Link to comment Share on other sites More sharing options...
greenj22 Posted August 14, 2018 Author Report Share Posted August 14, 2018 On 8/11/2018 at 2:11 PM, Wayneo said: @greenj22 Are you going to leave that permanently soldered? I notice a BB on your bench, and my connections are always removable cuz I just couldn't figure how to mount the board Hi Wayneo, I have sorted out USB install in BB’s, but it is a fair amount of modding. I just wanted to try using different USB or taps that I could install with less modifications. 1 Link to comment Share on other sites More sharing options...
greenj22 Posted August 14, 2018 Author Report Share Posted August 14, 2018 (edited) Spector - Thanks so much! I think I figured it out and you are 100% right! I was expecting to get a connection without power going to the board, just as you would with the stock USB. So I connected the ground and a battery and I’m good to go!! Finally! Thanks for your input. Edited August 14, 2018 by greenj22 Link to comment Share on other sites More sharing options...
MikeyG Posted November 27, 2018 Report Share Posted November 27, 2018 On 8/14/2018 at 10:53 AM, greenj22 said: Hi Wayneo, I have sorted out USB install in BB’s, but it is a fair amount of modding. I just wanted to try using different USB or taps that I could install with less modifications. I know this is an older post but I'm planning to put a USB port on my SXK DNA60 BB. Would you happen to have any advice or guidance on getting a USB board to fit in there? I have an Evolv 1A charge board and know how to wire it just need a little info on milling out the box and physical placement of the board. Not sure I would ever use the USB to charge but would like to have it for Escribe. Thanks! Link to comment Share on other sites More sharing options...
Magneto Posted June 6, 2023 Report Share Posted June 6, 2023 Hello, Please I need your help with updating my device Dna 60 chip. I did the connections exactly as in the picture, but the chip is inside the device and I use the battery while it is inside the device, but when connecting the computer gives me every time "usb not recognized Link to comment Share on other sites More sharing options...
