External USB Data Connection Trouble - DNA60
greenj22
Hi All,
I have looked at, read, re-read, and been attempting to get EScribe/data connection using a generic USB breakout board.
My understanding:
From breakout board to DNA60:
VCC to pin 15 via 10K ohm resistor
Data + to pin 14
Data - to pin 13
@ChunkyButt200 can you please help?
No connection. I’ve tried this several times on/off for a looooong time.
Help is very-much appreciated in advance.
And yes, USB cable is data capable.
On 8/11/2018 at 2:11 PM, Wayneo said:
@greenj22 Are you going to leave that permanently soldered? I notice a BB on your bench, and my connections are always removable cuz I just couldn't figure how to mount the board
Hi Wayneo,
I have sorted out USB install in BB’s, but it is a fair amount of modding. I just wanted to try using different USB or taps that I could install with less modifications.
Spector - Thanks so much! I think I figured it out and you are 100% right! I was expecting to get a connection without power going to the board, just as you would with the stock USB. So I connected the ground and a battery and I’m good to go!! Finally! Thanks for your input.
Edited by greenj22
  • 3 months later...
On 8/14/2018 at 10:53 AM, greenj22 said:
Hi Wayneo,
I know this is an older post but I'm planning to put a USB port on my SXK DNA60 BB.  Would you happen to have any advice or guidance on getting a USB board to fit in there?  I have an Evolv 1A charge board and know how to wire it just need a little info on milling out the box and physical placement of the board.  Not sure I would ever use the USB to charge but would like to have it for Escribe.  Thanks!
  • 4 years later...
Hello, Please I need  your help with updating my device Dna 60 chip. I did the connections exactly as in the picture, but the chip is inside the device and I use the battery while it is inside the device, but when connecting the computer gives me every time "usb not recognized
