omega Posted September 9, 2017 Report Share Posted September 9, 2017 Hi All, I have a 2 day old therion DNA 75c which has been fine up until tonight, i now keep getting a double 'clock error message on the lock screen and when in use and no longer have a date or time shown on the mod. I have searched the forum but am unable to fine a answer to this issue, any help would be appreciated. Thanks Link to comment Share on other sites More sharing options...
retird Posted September 9, 2017 Report Share Posted September 9, 2017 2 day old mod..... have you changed anything since you got it, such as the theme, any settings under Theme Designer? Any more info you could give would be helpful.... Link to comment Share on other sites More sharing options...
omega Posted September 9, 2017 Author Report Share Posted September 9, 2017 Hi Retird, I changed the theme yesterday when i received the mod to this and everything has been fine up until tonight when i noticed the clock error message is now shown. I have uploaded the default evolv theme and settings and the error message is still shown. Link to comment Share on other sites More sharing options...
retird Posted September 9, 2017 Report Share Posted September 9, 2017 If you saved the original *.ecig file before you changed themes you might try uploading that.... if not you might contact Lost Vapes or your vendor to get a copy of the *.ecig file to upload. If that doesn't fix it you might fill out a ticket with Evolv and they will guide you.... Maybe someone in this forum can post the original therion DNA 75c *.ecig file if they have it. Link to comment Share on other sites More sharing options...
omega Posted September 10, 2017 Author Report Share Posted September 10, 2017 I have changed the .ecig file to the original and left the batteries out over night and still have the same error message being given. I will open up a ticket with Evolv and see if this is a known problem that can be fixed via a update etc. Not good for a 2 day old mod, i know its only the clock but if this is a chip problem with a failure of a component then whats to say more issues will not appear as use increases. Total puff count 806. Total time used 19.6 minutes Link to comment Share on other sites More sharing options...
giz_60 Posted September 10, 2017 Report Share Posted September 10, 2017 Had that issue once...opening 'Device Monitor' reset the date & time... 1 Link to comment Share on other sites More sharing options...
omega Posted September 10, 2017 Author Report Share Posted September 10, 2017 56 minutes ago, giz_60 said: Had that issue once...opening 'Device Monitor' reset the date & time... Thanks for advice, unfortunately just tried this and still same error message. Link to comment Share on other sites More sharing options...
akiraone Posted December 12, 2017 Report Share Posted December 12, 2017 Hi Did you found solution. I just came back from work, and "clock error" message on screen . I didnt done anything, mod has just one week around 1k puffs .... Link to comment Share on other sites More sharing options...
akiraone Posted December 13, 2017 Report Share Posted December 13, 2017 Ok, I dont know if it is solution. By I could menage fix, by connecting Therion to computer without battery in and connecting to Escribe. Then data and time appear again. After that I installed batterys and for now time and date display correctly on display. Would like really know, what was cause the problem. Oh, maybe good to mentione, that taking out batterys for some time, didnt solve the problem. And sorry guys, for my english . 1 Link to comment Share on other sites More sharing options...
Misha79 Posted December 25, 2017 Report Share Posted December 25, 2017 Да помогло!!!! Link to comment Share on other sites More sharing options...
Misha79 Posted December 25, 2017 Report Share Posted December 25, 2017 Но причина clock error непонятна!!! Link to comment Share on other sites More sharing options...
Adamska Posted March 14, 2018 Report Share Posted March 14, 2018 Same problem here.... Can anyone help? Link to comment Share on other sites More sharing options...
CheetahC Posted May 10, 2018 Report Share Posted May 10, 2018 Same here...... Link to comment Share on other sites More sharing options...
PaiWarNoob Posted August 6, 2018 Report Share Posted August 6, 2018 Just had same issue but managed to fix it. Remove your battery for a while. 30second maybe. Then put em back. It will show your clock and date. Just reset them in setting🙂chill Link to comment Share on other sites More sharing options...
angealvape Posted August 8, 2018 Report Share Posted August 8, 2018 Have the same issue... any fixes yet? Link to comment Share on other sites More sharing options...
PaiWarNoob Posted August 8, 2018 Report Share Posted August 8, 2018 (edited) 6 minutes ago, angealvape said: Have the same issue... any fixes yet? Yess. remove your battery for a while then put it back Edited August 8, 2018 by PaiWarNoob Link to comment Share on other sites More sharing options...
angealvape Posted August 8, 2018 Report Share Posted August 8, 2018 2 minutes ago, PaiWarNoob said: Yess. remove your battery for a while then put it back I did bro, did not work still got the clock error crap. I tried looking for clock settings in Escribe but seems nothing there Link to comment Share on other sites More sharing options...
PaiWarNoob Posted August 8, 2018 Report Share Posted August 8, 2018 1 minute ago, angealvape said: I did bro, did not work still got the clock error crap. I tried looking for clock settings in Escribe but seems nothing there What is your version of vt75? Mine is vt75D. I removed my battery about 30 second or a minute. Then after i put it back and turn it on. The clock and date displayed just like before but not accurate. Just reset them in setting. Sorry my english is bad😅 Link to comment Share on other sites More sharing options...
angealvape Posted August 8, 2018 Report Share Posted August 8, 2018 1 minute ago, PaiWarNoob said: What is your version of vt75? Mine is vt75D. I removed my battery about 30 second or a minute. Then after i put it back and turn it on. The clock and date displayed just like before but not accurate. Just reset them in setting. Sorry my english is bad😅 no worries about your english - its perfect I am using ThinkVape 250C. And I followed your recommendation. 1. I applied Service Pack 2. I uploaded default.ecig for ThinkVape 3. I tried waiting with batteries nothing works Link to comment Share on other sites More sharing options...
PaiWarNoob Posted August 8, 2018 Report Share Posted August 8, 2018 2 minutes ago, angealvape said: no worries about your english - its perfect I am using ThinkVape 250C. And I followed your recommendation. 1. I applied Service Pack 2. I uploaded default.ecig for ThinkVape 3. I tried waiting with batteries nothing works Yours is powerful than mine😂 Maybe its something to do with firmware. Its not my field😅 Sorry bro i cant help you to solve your issue🙏 Link to comment Share on other sites More sharing options...
ajoe Posted August 8, 2018 Report Share Posted August 8, 2018 (edited) This error has happened on other brands of mods as document on these forums, so it is unlikely a device issue. Please put in a support ticket in with Evolv. In my experience, they respond in 2-3 days and are very helpful. Edited August 8, 2018 by ajoe Link to comment Share on other sites More sharing options...
angealvape Posted August 16, 2018 Report Share Posted August 16, 2018 On 8/8/2018 at 9:28 PM, ajoe said: This error has happened on other brands of mods as document on these forums, so it is unlikely a device issue. Please put in a support ticket in with Evolv. In my experience, they respond in 2-3 days and are very helpful. yes, well... I a, waiting for quite sometime for a reply from them.... lots of tickets it seems. Link to comment Share on other sites More sharing options...
Wayneo Posted August 17, 2018 Report Share Posted August 17, 2018 This should work. Device Monitor -> Diagnostics -> Clock Link to comment Share on other sites More sharing options...
angealvape Posted August 17, 2018 Report Share Posted August 17, 2018 6 hours ago, Wayneo said: This should work. Device Monitor -> Diagnostics -> Clock I don't want to be rude but let's try to be professional here. I know about this option - been using DNA & Escribe since the very 1st that came out. This does not solve the issue as the issue is probably coming for the malfunction of the board itself. Evolv Support provided me also extremely useful information which was to connect to the escribe and set to "removable batteries" ... which is kind of an obvious thing you do once you receive a device which I did long time ago and also is not a solution. Link to comment Share on other sites More sharing options...
