Thunderhawk Posted September 23, 2017 Report Share Posted September 23, 2017 So complicate? Link to comment Share on other sites More sharing options...
Thunderhawk Posted September 24, 2017 Report Share Posted September 24, 2017 Maybe this helps. With 26 The Wick is Not recognize by The Chip, When i Turn it on and of, it appear. Under 22 The Chip recognizes imidiatly! A76BDF1C-8D51-49A2-83B9-CDA18FEF1A72.mov Link to comment Share on other sites More sharing options...
nklx Posted September 24, 2017 Report Share Posted September 24, 2017 tried it , nothing detected Link to comment Share on other sites More sharing options...
Thunderhawk Posted September 28, 2017 Report Share Posted September 28, 2017 Still nothing new? Link to comment Share on other sites More sharing options...
jhdelamain Posted September 28, 2017 Author Report Share Posted September 28, 2017 Sent the mod to evolv so it can get fixed!! Link to comment Share on other sites More sharing options...
Thunderhawk Posted September 29, 2017 Report Share Posted September 29, 2017 (edited) Itˋs a Software Problem! Wy should i send it to Evolv? Edited September 29, 2017 by Thunderhawk Link to comment Share on other sites More sharing options...
James Posted September 29, 2017 Report Share Posted September 29, 2017 @jhdelamain sent his mod to us so we could reproduce the bug. I have found the cause. It will be fixed in the next device Service Pack. You do not need to send your device to Evolv. 1 Link to comment Share on other sites More sharing options...
Thunderhawk Posted September 29, 2017 Report Share Posted September 29, 2017 vor 2 Stunden schrieb James: @jhdelamain sent his mod to us so we could reproduce the bug. I have found the cause. It will be fixed in the next device Service Pack. Very Glad to hear this! Link to comment Share on other sites More sharing options...
nklx Posted September 29, 2017 Report Share Posted September 29, 2017 nice.. 10mins ago i sent my device to evolv Link to comment Share on other sites More sharing options...
Lowbytes Posted September 29, 2017 Report Share Posted September 29, 2017 vor 22 Minuten schrieb nklx: nice.. 10mins ago i sent my device to evolv I´m pretty sure that your problem is different - because you have "Check Atomizer" on every firmware even on SP22 - so you did the right thing! 1 Link to comment Share on other sites More sharing options...
nklx Posted September 29, 2017 Report Share Posted September 29, 2017 hope so Link to comment Share on other sites More sharing options...
Thunderhawk Posted October 7, 2017 Report Share Posted October 7, 2017 When will SP8 come out? Link to comment Share on other sites More sharing options...
James Posted October 7, 2017 Report Share Posted October 7, 2017 Most likely this coming week. 1 Link to comment Share on other sites More sharing options...
Thunderhawk Posted October 7, 2017 Report Share Posted October 7, 2017 I Hope before wednesday! Link to comment Share on other sites More sharing options...
timbuc2dan Posted October 15, 2017 Report Share Posted October 15, 2017 On 7/23/2017 at 5:45 AM, giz_60 said: In Escribe...'Tools > Apply Service Pack'... Ok, I've been getting errors saying shorted and or temp protected even though I'm using same atomizer. This only began after I said yes to the upgrade on 1st use of escribe. The only way around it has been to unscrew the atomizer till I don't get the error messages, it used to work fine screwed all the way down. Will doing the apply service pack do away with the theme I chose? Real name is Sean and thanks for any help! Link to comment Share on other sites More sharing options...
timbuc2dan Posted October 15, 2017 Report Share Posted October 15, 2017 On 7/23/2017 at 6:47 PM, James said: Does this happen in other profiles, or just Watts? Thanks! I've been noticing it happens in SS, I used to use just watts but I added Kanthal to the materials since I use only Vaporesso ccell Kanthal, thought it was solved until after few puffs it started doing it again, only slightly unscrewing it stops it giving the shorted or temp protected even with temp protect off. I'm wondering if Evolve modified it due to the battery explosive issues with HCigar mods, nothing gets hot unless I'm taking too many puffs then base of atomizer gets hot. Are you aware of the window that come up if you do the escribe analyze atomizer which says that they've had issues with the ohms drifting in and out of range with atomizers screwed down too much or not enough? that stop when you unscrew it for me at least. What's the point of having a lock ohms or a no temp protect if they both do nothing? Link to comment Share on other sites More sharing options...
Pjr Posted October 15, 2017 Report Share Posted October 15, 2017 Hi! My paranormal mod displays 0.00 volts while firing. Then it will display the correct voltage after awhile it goes back to zero volts but it's firing. This is scary. Anyone having the same issue? Link to comment Share on other sites More sharing options...
giz_60 Posted October 15, 2017 Report Share Posted October 15, 2017 21 minutes ago, Pjr said: Hi! My paranormal mod displays 0.00 volts while firing. Then it will display the correct voltage after awhile it goes back to zero volts but it's firing. This is scary. Anyone having the same issue? I would go to the Theme Designer in Escribe & check that field to see what voltage value is being applied there...there are voltage values from several different sources available to display... 1 Link to comment Share on other sites More sharing options...
Lowbytes Posted October 17, 2017 Report Share Posted October 17, 2017 Am 29.9.2017 um 18:13 schrieb nklx: hope so Any update? Link to comment Share on other sites More sharing options...
nklx Posted October 17, 2017 Report Share Posted October 17, 2017 nothing new, sent the device to evolv - no answer til today Link to comment Share on other sites More sharing options...
James Posted October 17, 2017 Report Share Posted October 17, 2017 Still working on SP8. 1 Link to comment Share on other sites More sharing options...
Thunderhawk Posted October 23, 2017 Report Share Posted October 23, 2017 Any Idea when SP8 will come out? Link to comment Share on other sites More sharing options...
James Posted October 23, 2017 Report Share Posted October 23, 2017 We're testing it at present. Shouldn't be too long unless we run into any bugs. 1 Link to comment Share on other sites More sharing options...
EGO 13 Posted October 23, 2017 Report Share Posted October 23, 2017 This should be a solution : Try an other thème also ... Well it' s just my opinion . :-) Link to comment Share on other sites More sharing options...
Thunderhawk Posted October 23, 2017 Report Share Posted October 23, 2017 vor 19 Minuten schrieb James: We're testing it at present. Shouldn't be too long unless we run into any bugs. That Sounds good! Link to comment Share on other sites More sharing options...
