vaporlips Posted July 30, 2015 Author Report Posted July 30, 2015 Most of Escribe works fine within Windows 10, but when you go to utilize something with live support, there are problems.I enabled Network Framework 3.5 (by default off) and that seemed to help some. Now when I get a problem, everything doesn't crash to the point of no recovery. I can hit continue, and continue.I receive a crash during atomizer analyzer, and also during "device monitor".Find my two error logs attached.dna200_crashlog.docx
John Posted July 30, 2015 Report Posted July 30, 2015 Did you just update to windows 10? Reinstalling Escribe might help if so. It uses .net framework 4.
vaporlips Posted July 30, 2015 Author Report Posted July 30, 2015 I will try and report back in a moment.Yes, I did just update (this morning).
vaporlips Posted July 30, 2015 Author Report Posted July 30, 2015 Uninstalled Escribe. Downloaded latest escribe, and installed. Restarted PC. Same Problems.second.docx
retird Posted July 30, 2015 Report Posted July 30, 2015 Guess I'll wait for a bit to install Win-10. Anybody else running Win-10 and noticing incompatibility?
RickAdair Posted July 30, 2015 Report Posted July 30, 2015 I'm running a fresh install of Windows 10 on a Surface Pro 3 and all is well with the 7/29 release of Escribe.
retird Posted July 30, 2015 Report Posted July 30, 2015 RickAdair said:I'm running a fresh install of Windows 10 on a Surface Pro 3 and all is well with the 7/29 release of Escribe.Device Monitor works in live mode and Atty Analyzer works too?
RickAdair Posted July 30, 2015 Report Posted July 30, 2015 dc601 said:[QUOTE=RickAdair]I'm running a fresh install of Windows 10 on a Surface Pro 3 and all is well with the 7/29 release of Escribe.Device Monitor works in live mode and Atty Analyzer works too?[/QUOTE]Yes. I am monitoring my box right now. Just ran the Analyzer again and it is working fine.The only thing that may be different is that I do have Visual Studio 2015 installed. It may have added a missing dependancy.
vaporlips Posted July 30, 2015 Author Report Posted July 30, 2015 Windows 10 hasn't been released to the public for much more than 24 hours, so I'm not concerned at this point. I imagine Windows will update a lot the next upcoming days, and hopefully fix everything up.
John Posted July 30, 2015 Report Posted July 30, 2015 It probably is some sort of file dependency that got changed in the update. We'll dig into it over the next week or so as it matures and see what we can see.
retird Posted July 30, 2015 Report Posted July 30, 2015 Windows 10 already has two updates available. From article of 7/30/15 I read: The two update files weigh in at more than 1GB .
dwaindablane Posted July 30, 2015 Report Posted July 30, 2015 With a clean installation of Windows 10 Pro x64, and EScribe 29/7/2015 from the forum, I don't see any problems with the software looks okay to me.
basilray Posted July 31, 2015 Report Posted July 31, 2015 Same boat here. Upgraded to Win 10, and EScribe hates me now.
John Posted July 31, 2015 Report Posted July 31, 2015 So people doing clean windows 10 installs don't have issues, but upgrade installs do? We can find that. Gotta be a dependency thing. Basilray is your issue also related to device monitor and atomizer analyzer?
retird Posted July 31, 2015 Report Posted July 31, 2015 Basilray, did you run the two updates that I read came today?
Justin Posted July 31, 2015 Report Posted July 31, 2015 Working great on my out of date x64 Win10 technical preview. Though I do have issues upgrading the firmware over USB 3.0
basilray Posted July 31, 2015 Report Posted July 31, 2015 dc601 said:Basilray, did you run the two updates that I read came today?I grabbed what looked to be the latest version of EScribe, and reinstalled. Tested every possible compatibility mode combo I could. The one thing I haven't done is tried installing to a different location. I also haven't looked for any registry keys that may have been related. I could see that being an issue based on upgrade.
retird Posted July 31, 2015 Report Posted July 31, 2015 My bad, updates I was talking about were Windows 10 updates.
basilray Posted July 31, 2015 Report Posted July 31, 2015 I did check last night, and there were a couple of pretty innocent looking x64 updates that were out there.I just uninstalled EScribe and did some registry purging, and checked again for Windows updates. Same result. The app installs, opens, then basically becomes unresponsive. I've also tried a few of the past versions of the software, to see if compatibility with Windows 10 MIGHT have been there, but something in a more recent software release is causing an issue. 7-16, 7-14, and 7-09 all have the same issue when running the app...which is exactly what I expected (not sure if all those versions were made public...so if you are all "where did he get those!?!" my bad! ).As a test to see if it has something to do w/ modifications to the way programs are allowed to run from the user profile location in Windows 10, I installed it to C:\EScribe as a test...and the result was the same.Interestingly enough, one of the very first versions of EScribe that was released DOES look to work. But so many features have been added since then, that it's unusable, really.At this point, from a software troubleshooting standpoint, I feel like I've exhausted the standard line of options. I'm sure the brains over at Evolv will sort it out in short order.
retird Posted July 31, 2015 Report Posted July 31, 2015 Yep it'll get sorted out but until then no Win10 for me. LOL
epicwood Posted July 31, 2015 Report Posted July 31, 2015 I've been running the latest escribe software on 3 different Win10 machines, and it's working fine. running Win 10 pro. If there is anything I can do to help, let me know.
retird Posted July 31, 2015 Report Posted July 31, 2015 hum, maybe something different between the Home version and Pro???
John Posted July 31, 2015 Report Posted July 31, 2015 Basilray, which early version does work? If you could find the last version that works and the first version that doesn't, we can figure out what we added in that version that is not working.At least gives us a place to start looking.
