JaI Haze Posted July 10, 2016 Author Report Posted July 10, 2016 I am getting into quite a debacle with someone over this. I am sure 99% of you are going to answer this the same way I do. Is there any point in having DUAL batteries in a DNA75? My point is if youre using dual 18650 its not going to stop the weak battery message because its in parallel. And you cant run the DNA75 with series batteries for a multitude of reasons and there is no point as you would just get the DNA200 if you wanted to run series battery on a DNA. I would like this to be clarified from you guys since alot of you work on this board religiously and know the ins and outs of the board
BillW50 Posted July 10, 2016 Report Posted July 10, 2016 Running a DNA75 with parallel batteries means half of the current is supplied by each battery. That means less battery sag and yes, less weak battery messages.
BillW50 Posted July 10, 2016 Report Posted July 10, 2016 Another way to look at it is instead of one battery supplying 75 watts (it's going to be actually more if less than 100% efficiency), each battery is only supplying 37.5 watts each.
JaI Haze Posted July 10, 2016 Author Report Posted July 10, 2016 so why would i still be getting the weak battery using 1 hb6 or even 2 hb6? Are we 100% sure on this? I was looking at VapingBad post on ecf and I think he questioned the validity of using the dna75 with parallel battery configuration.
JaI Haze Posted July 10, 2016 Author Report Posted July 10, 2016 here you go https://www.e-cigarette-forum.com/forum/threads/evolv-dna-75.733672/page-3#post-17519116 I hate to get him into the conversation but im not getting it....unless I dont know how to read the internet "But I don't understand why you are only considering parallel cells when series cells are better on safety and performance with the right board. EG. a DNA 200 in 2 cell operation (133 W) using series cells is >= 97% efficient and monitors each cell individually. With parallel cells you loose the better efficiency of step down only regulation, the individual cell monitoring and depending on the mod have a very real danger of generating extreme currents inserting cells if they are at different voltages"
VapingBad Posted July 10, 2016 Report Posted July 10, 2016 JaI Haze said:here you go https://www.e-cigarette-forum.com/forum/threads/evolv-dna-75.733672/page-3#post-17519116 I hate to get him into the conversation but im not getting it....unless I dont know how to read the internet "But I don't understand why you are only considering parallel cells when series cells are better on safety and performance with the right board. EG. a DNA 200 in 2 cell operation (133 W) using series cells is >= 97% efficient and monitors each cell individually. With parallel cells you loose the better efficiency of step down only regulation, the individual cell monitoring and depending on the mod have a very real danger of generating extreme currents inserting cells if they are at different voltages"Bill's correct, having 2 batteries in parallel in a DNA 75 will reduce the sag, but my post you quoted was looking at it from the point of view you had decided to build a dual 18650 mod and the merits of series vs parallel.
BillW50 Posted July 10, 2016 Report Posted July 10, 2016 Oh VB is talking about if you are going to have more than one battery, he says doing it in series would be better than parallel. Yes... well... kinda. There are pros and cons of using one or another. But he is right about the pros of using series batteries vs. parallel batteries. As far as watt hours goes, either way is exactly the same which is quite interesting.EDIT: Oh VB beat me by 30 seconds.
JaI Haze Posted July 10, 2016 Author Report Posted July 10, 2016 thank you for clearing that up VapingBad. But im still a little lost, so your saying putting in series (this cant be done with dna75) correct? Again I am not an electronical engineer nor do I claim to be. Learning is the key here, would like to know. My argument is there is not one mod out there aside from older dna40's (SOME) and the cloupor gt80 (series) that is dual battery parallel under 80W. At least I cant think of any.
Scarab Posted July 10, 2016 Report Posted July 10, 2016 Only 75W mod with 2x18650 looks little strange compare to 133W mod (on DNA200). DNA200 mod have more power with same size.
VapingBad Posted July 10, 2016 Report Posted July 10, 2016 That's right you can't use series with the 75. VaporFlasks and the Hana One use parallel with a DNA 40. I use my old Panasonic CGR18650s in them, they are only 10 A and I have 10 of them so using them is these allows me to continue to get value from them as they are don't have enough current to run a DNA 40 or much else these days singly.
retird Posted July 10, 2016 Report Posted July 10, 2016 I thought the original question was : Is there any point in having DUAL batteries in a DNA75? That question was answered I thought..A DNA200 (133) requires series batteries and a DNA 75 can be configured with parallel batteries.... different technology and specifications... Evolv Data sheets in case you are interested:DNA200: http://www.evolvapor.com/datasheet/dna200.pdfDNA 75: http://www.evolvapor.com/datasheet/dna75.pdf
Spector NS5 RD Posted July 10, 2016 Report Posted July 10, 2016 JaI Haze said:so why would i still be getting the weak battery using 1 hb6 or even 2 hb6? Are we 100% sure on this? I was looking at VapingBad post on ecf and I think he questioned the validity of using the dna75 with parallel battery configuration. LET ME JUMP UP ON IN THIS......YA DIG?! a big reason people are getting the weak batt message isn't always from what battery or batteries they are using (50/50 crappy batt, crappy connection). a lot of the time it has to do with battery CONTACTS. if there is insufficient surface area of the contact to make connection with the ends of the battery this will make the dna 75 "think" the battery is incapable of providing the necessary current. also the amount of tension/pressure that is applied from the contact to the battery also plays a role in how well a battery will perform. weak contact spring = "weak batt" message.here's a helpful link......https://forum.evolvapor.com/topic/66816-topic/one more tiny edit.......my preference.....dual batt dna 133. a little more efficient than the 75 and who wouldn't like the extra headroom (wattage)
retird Posted July 10, 2016 Report Posted July 10, 2016 Dual 18650 DNA75:https://originvape.com/product/lost-vape-therion-dna75-mod/
JaI Haze Posted July 10, 2016 Author Report Posted July 10, 2016 yes I was aware of that one, thats what started this whole conversation on youtube. The issue I am having with the therion is I get weak battery 50% and below with hb6's AND it doesnt discharge the batteries evenly as a parallel. I knew about the contacts but when customers are buying them I dont want to tell them hey when you get home change the contacts out. And thanks chunky for letting me know that. So its not a battery issue per se, its more of a contact issue
BillW50 Posted July 10, 2016 Report Posted July 10, 2016 retird said:I thought the original question was : Is there any point in having DUAL batteries in a DNA75? That question was answered I thought..A DNA200 (133) requires series batteries and a DNA 75 can be configured with parallel batteries.... different technology and specifications...
BillW50 Posted July 10, 2016 Report Posted July 10, 2016 JaI Haze said:yes I was aware of that one, thats what started this whole conversation on youtube. The issue I am having with the therion is I get weak battery 50% and below with hb6's AND it doesnt discharge the batteries evenly as a parallel. I knew about the contacts but when customers are buying them I dont want to tell them hey when you get home change the contacts out. And thanks chunky for letting me know that. So its not a battery issue per se, its more of a contact issueWell if by 50%, you mean the battery voltages are like 3.70v... well in high amp usage... I consider them dead and needs to be recharged. If you are only running 15 watts or so, you can use them down to 3.0v without a problem and you can use the rest of the 50%. It is just battery sag becomes very high when the battery voltage is this low (<3.70v).
BillW50 Posted July 10, 2016 Report Posted July 10, 2016 I should add that a low battery voltage or a poor battery contacts will show virtually the same symptoms. So generically it could be either or both.
Spector NS5 RD Posted July 11, 2016 Report Posted July 11, 2016 "the low battery voltage bone is connected to the.......weak contact bone......the weak contact bone is connected to the....weak battery message bone." sorry, bored.
Z.Oregon Posted July 13, 2016 Report Posted July 13, 2016 The new test firmware linked in here basically absolves the weak battery messages...so far running under 60 watts...
