2legsshrt Posted August 22, 2016 Author Report Share Posted August 22, 2016 I've tried Jaquiths V4 V7 the only ones still available the SS316L from SE and the escribes SS316. The V4 is way too hot even at 375F the V7 is too cool the escribes isn't bad at 480+F this one is the most accurate very rarely hits TP seems to work well with the firmware the SE is ok. I can't get Jaquiths V3.5 or 3.25 which I think might be better then the V4. Will try escribes SS304 heard that's not bad but I'm really not impressed with the way this DNA75 works with SS316L. Link to comment Share on other sites More sharing options...
retird Posted August 22, 2016 Report Share Posted August 22, 2016 @2legsshrt, as you know the DNA technology is not the same as the SX you are used to using. The SS316 EScribe works very well once you set your settings to get the vape you want. You may not get the same vape using the same temp/wattage/etc you set on the SX. You just need to adjust the settings accordingly to achieve the same vape as the SX. Here is a screenshot of EScribe SS316 profile I use. The temp is currently 400F, wattage set at 25 watts, preheat set at 60 watts/punch 5/duration 1s. I am using a SS316 Notch Coil with a ohm's reading of 0.25. Note the smooth temp line. The Temp Protect is not an error message it just lets you know the temp setting has been reached.This Device Monitor screenshot is using the DNA200 but my DNA75's are set the same and have the same smooth temp graph ...... Link to comment Share on other sites More sharing options...
2legsshrt Posted August 22, 2016 Author Report Share Posted August 22, 2016 How do you get a screenshot that you can display on this forum or others? Link to comment Share on other sites More sharing options...
VapingBad Posted August 22, 2016 Report Share Posted August 22, 2016 [ALT]+[PRT SC] then open ms paint ([WIN]+[R] and type mspaint) and paste [CTRL]+[V] Link to comment Share on other sites More sharing options...
awsum140 Posted August 22, 2016 Report Share Posted August 22, 2016 Alternately, use the "snipping tool" in Win7 and up. Save it as a .jpg Link to comment Share on other sites More sharing options...
2legsshrt Posted August 22, 2016 Author Report Share Posted August 22, 2016 We'll see if this worksNope something else I have to learn anyway the curves for the escribe SS316 and the SE SS316L elite are real good using 25w at 485F very smooth and that seems to be where I like the vape. Can't decide between those 2 they are pretty close. I am using a 6 wrap spaced 26awg SS316L at .45ohms. Just not used to using those kind of temps. the SS is from Temco. Link to comment Share on other sites More sharing options...
2legsshrt Posted August 22, 2016 Author Report Share Posted August 22, 2016 I am just used to the SX using TCR .00092 at 420F but those settings on the DNA are very similar. On the SX it would probably burn the cotton. Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted August 22, 2016 Report Share Posted August 22, 2016 SS has such a crappy small temp curve, i find just using a simple TCR works best for my needs. i find little advantage using a csv. curve over a TCR for SS. i usually run all my SS 316L at a TCR of 0.00097-0.00099. i like a warm vape tho. Link to comment Share on other sites More sharing options...
Spirometry Posted August 22, 2016 Report Share Posted August 22, 2016 If you like a warmer vape, why not just turn up the temperature, why mess with the TCR? I'm just trying to get a better understanding of why guys want their device to read a lower coil temperature than what it actually is. Link to comment Share on other sites More sharing options...
Spirometry Posted August 23, 2016 Report Share Posted August 23, 2016 Did a water test tonight. Single coil 24awg Temco ss316l, Vaporshark dna200, kayfun5 deck, Evolv default ss316 wire profile. After mating atomizer, I let it sit unplugged for 20 minutes for refinement. Link to comment Share on other sites More sharing options...
VapingBad Posted August 23, 2016 Report Share Posted August 23, 2016 Your power is set way below your temp and it is not temp limiting and effectively in power mode, nothing wrong with that just saying. Link to comment Share on other sites More sharing options...
Spirometry Posted August 23, 2016 Report Share Posted August 23, 2016 Not temp limiting because you can't heat water past 212° F. You can increase the power to a point that the water doesn't keep the coil cool, but then you will see the temp keep rising until it hits your limit. So yes, it is effectively running in power mode, but look at the temp it is running at. I just wanted to show that the Temco wire with the Evolv profile was pretty accurate. If I had a nice straight line at lets say 260F, then you would know that either the cold resistance was wrong or the tfr curve was wrong. Link to comment Share on other sites More sharing options...
dylang919 Posted August 23, 2016 Report Share Posted August 23, 2016 Did Evolv release the firmware update yet to make SS temp control on the DNA 200 as smooth as the DNA 75? Link to comment Share on other sites More sharing options...
VapingBad Posted August 23, 2016 Report Share Posted August 23, 2016 dylang919 said:Did Evolv release the firmware update yet to make SS temp control on the DNA 200 as smooth as the DNA 75?They sure did, the early version linked in my footer. Link to comment Share on other sites More sharing options...
dylang919 Posted August 23, 2016 Report Share Posted August 23, 2016 VapingBad said:They sure did, the early version linked in my footer. So do I just go to escribe as usual? What do I do to get the new firmware update? Link to comment Share on other sites More sharing options...
VapingBad Posted August 23, 2016 Report Share Posted August 23, 2016 dylang919 said: So do I just go to escribe as usual? What do I do to get the new firmware update? go here https://forum.evolvapor.com/topic/66731-topic/and download and install the early version, 2nd in the list. It will prompt you to update the firmware when you connect your DNA200. Link to comment Share on other sites More sharing options...
dylang919 Posted August 24, 2016 Report Share Posted August 24, 2016 VapingBad said: go here https://forum.evolvapor.com/topic/66731-topic/and download and install the early version, 2nd in the list. It will prompt you to update the firmware when you connect your DNA200. Thank you! It's not a beta version that's going to brick any of my devices is it? Link to comment Share on other sites More sharing options...
VapingBad Posted August 24, 2016 Report Share Posted August 24, 2016 dylang919 said: Thank you! It's not a beta version that's going to brick any of my devices is it?No it's not beta, noting you download from Evolv (evolvapor.com) would affect your warranty. I have been running it for a few weeks and no reports of bricked devices that I am aware of. It does have one issue that after updating the fw your battery bar may zero, but uploading settings, soft reboot or just waiting bring it back. Link to comment Share on other sites More sharing options...
dylang919 Posted August 25, 2016 Report Share Posted August 25, 2016 VapingBad said:No it's not beta, noting you download from Evolv (evolvapor.com) would affect your warranty. I have been running it for a few weeks and no reports of bricked devices that I am aware of. It does have one issue that after updating the fw your battery bar may zero, but uploading settings, soft reboot or just waiting bring it back. ok, got the new version of escribe. It runs all of the boards correct? The 60, 75, 200, and 250 it's showing. Anyway, I'm updating a new DNA 75 I just received and I don't see the mod tab for the case thermals and battery analyzer and such. Where did it go?? Link to comment Share on other sites More sharing options...
VapingBad Posted August 25, 2016 Report Share Posted August 25, 2016 EScribe now has 4 display modes accessible through the menu under Options - Interface. The differences in each mode compared to the previous versions are: Clean: no Mod or Research tabs and no Atomizer Analyzer. Advanced: no Research tab and only Charging Mode and Kanthal Power Limit on mod tab Researcher: only Charging Mode and Kanthal Power Limit on mod tab Manufacturer: same as the previous version with the Manufacturer settings on the mod tab expanded Link to comment Share on other sites More sharing options...
dylang919 Posted August 25, 2016 Report Share Posted August 25, 2016 VapingBad said:EScribe now has 4 display modes accessible through the menu under Options - Interface. The differences in each mode compared to the previous versions are: Clean: no Mod or Research tabs and no Atomizer Analyzer. Advanced: no Research tab and only Charging Mode and Kanthal Power Limit on mod tab Researcher: only Charging Mode and Kanthal Power Limit on mod tab Manufacturer: same as the previous version with the Manufacturer settings on the mod tab expanded Ok, thank you. So...go to manufacturer and it will provide everything? Link to comment Share on other sites More sharing options...
VapingBad Posted August 25, 2016 Report Share Posted August 25, 2016 Yes, sorry I just cut & pasted what I had put in the FAQ. Link to comment Share on other sites More sharing options...
dylang919 Posted August 25, 2016 Report Share Posted August 25, 2016 dylang919 said: Ok, thank you. So...go to manufacturer and it will provide everything? Thank you bro, I appreciate all of your help. Link to comment Share on other sites More sharing options...
2legsshrt Posted September 9, 2016 Author Report Share Posted September 9, 2016 Well thanks guys for all the help but I discovered it was user error more or less. I was expecting it to act like a YiHi. I DL SE .csv file for SS316L made it temperature dominant and it works great. The temp is different then the YiHi but I think it is better then the YiHI. I like it so much I bought 2 more a Triade and a Lavabox75. Plan to get a couple more also. Thinking along the lines of a 133. I wish I would've believed people about how good these DNA boards actually are I would have saved a lot of money. I sold my SXmini Q's and bought a couple more DNA's Link to comment Share on other sites More sharing options...
retird Posted September 9, 2016 Report Share Posted September 9, 2016 2legsshrt said:Well thanks guys for all the help but I discovered it was user error more or less. I was expecting it to act like a YiHi. I DL SE .csv file for SS316L made it temperature dominant and it works great. The temp is different then the YiHi but I think it is better then the YiHI. I like it so much I bought 2 more a Triade and a Lavabox75. Plan to get a couple more also. Thinking along the lines of a 133. I wish I would've believed people about how good these DNA boards actually are I would have saved a lot of money. I sold my SXmini Q's and bought a couple more DNA'sGlad you are enjoying the Evolv technology devices. Welcome aboard...... !!!!!! Link to comment Share on other sites More sharing options...
