GrumpyJoe Posted January 16, 2016 Author Report Share Posted January 16, 2016 Hey all, just received my first DNA200 a few days ago and it's the Panzer Box by Think Vape.Being new to the whole DNA200 scene, I started tinkering in escribe and made a few custom screens up, but that's about all I have really done so far.The battery is supposed to be a 1500mAh 3S LiPo (SDL823562HP - 1500 mAh according to the manufacturer AD brand made by Shida Batteries) and the watt hours set by the manufacturer 15. Using the calculator, it should be 16.65, but if I change it, my mod tells me that the battery is only 90% charged when each cell is @ 4.20V. Any suggestions?Secondly, the soft cut-off is set to 3.59V, this seems a bit high, so I changed it to 3.3V for now.Thanks for any help available Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted January 17, 2016 Report Share Posted January 17, 2016 GrumpyJoe said:Hey all, just received my first DNA200 a few days ago and it's the Panzer Box by Think Vape.Being new to the whole DNA200 scene, I started tinkering in escribe and made a few custom screens up, but that's about all I have really done so far.The battery is supposed to be a 1500mAh 3S LiPo (SDL823562HP - 1500 mAh according to the manufacturer AD brand made by Shida Batteries) and the watt hours set by the manufacturer 15. Using the calculator, it should be 16.65, but if I change it, my mod tells me that the battery is only 90% charged when each cell is @ 4.20V. Any suggestions?Secondly, the soft cut-off is set to 3.59V, this seems a bit high, so I changed it to 3.3V for now.Thanks for any help available best bet..........read through the threads here in this forum on the proper way to run battery analyzer, then run it at your avg vaping wattage and that'll give you an accurate batt meter and should charge to 100% most, if not all the time. mine charge to 100% after running the analyzer. also run case analyzer and do a mod resistance test (all of these tests are explained in this forum, do some reading, it'll help). all these analyzers are to make your dna board more accurate with the battery and the enclosure it came in. Link to comment Share on other sites More sharing options...
GrumpyJoe Posted January 17, 2016 Author Report Share Posted January 17, 2016 I was looking to see if anyone had experience with the Panzer Box. I did search these forums for that and came up empty. I have looked on YouTube for videos, but all I came up with were elaborate setups with resistors/blocks and meters. I will do some more digging, thanks for your input.Grumpy Link to comment Share on other sites More sharing options...
Gmdmichael1080 Posted January 23, 2016 Report Share Posted January 23, 2016 WHat should the cell cut off be on the think vape panzer DNA 200 Link to comment Share on other sites More sharing options...
GrumpyJoe Posted January 23, 2016 Author Report Share Posted January 23, 2016 The factory cutoff is set to 3.59 but I set mine @ 3.3v.I also ran the battery analyzer finally with two 6" loops of 26ga Kanthal and the end result was 14.6 wh. Link to comment Share on other sites More sharing options...
morphflow Posted April 3, 2016 Report Share Posted April 3, 2016 Hello all, Does anyone know the mod resistance of the Panzer Box DNA 200?I don't have the tools to run this test and I cannot find it through the manufacturer (Think Vape) Thanks a lot and happy vaping;-) Link to comment Share on other sites More sharing options...
Scy123 Posted April 3, 2016 Report Share Posted April 3, 2016 morphflow said:Hello all, Does anyone know the mod resistance of the Panzer Box DNA 200?I don't have the tools to run this test and I cannot find it through the manufacturer (Think Vape) Thanks a lot and happy vaping;-)If you're interested in the tool, you can find it here. https://forum.evolvapor.com/topic/66031-topic/ Link to comment Share on other sites More sharing options...
Jace Posted April 5, 2016 Report Share Posted April 5, 2016 Panzer settings from djlsbvapes.comBattery:Capacity: 15,85Electrical:Mod Resistance: 0,025Thermal:Case Cooling Time Constant: 460,91Case Heating Time Constant: 203,11Case USB Charge Temperature Rise: 11,75 14,12Minimum Ambient Temperature: -20Maximum Ambient Temperature: 110 Link to comment Share on other sites More sharing options...
dwcraig1 Posted April 5, 2016 Report Share Posted April 5, 2016 Jace said:Panzer settings from djlsbvapes.comBattery:Capacity: 15,85Electrical:Mod Resistance: 0,025Thermal:Case Cooling Time Constant: 460,91Case Heating Time Constant: 203,11Case USB Charge Temperature Rise: 11,75 14,12Minimum Ambient Temperature: -20Maximum Ambient Temperature: 110I'm not to sure what to make of the mod resistance, if one of mine come up with a figure like 0.025? I'd be tearing it down to find the problem. Isn't that about what he listed for the Hcigar 200 as well? Link to comment Share on other sites More sharing options...
KevinMcc Posted August 6, 2016 Report Share Posted August 6, 2016 Does anyone know the measurements of the lipo in the panzer I think I found a maxamp 1800 mah battery that will fit it but I'm not sure Link to comment Share on other sites More sharing options...
gizman Posted November 15, 2016 Report Share Posted November 15, 2016 Did anyone ever measure the inside the case dimensions for the battery on the Panzer Box 200? Trying to come up with a replacement or larger mah battery to grab as a spare, I am loving mine so far! Link to comment Share on other sites More sharing options...
gizman Posted December 20, 2016 Report Share Posted December 20, 2016 dwcraig1 said:I'm not to sure what to make of the mod resistance, if one of mine come up with a figure like 0.025? I'd be tearing it down to find the problem. Isn't that about what he listed for the Hcigar 200 as well?Yes it is, I too was concerned, bought a brass plug and checked the mod resistance and came up with .008, not the best I've seen but MUCH better than .025 and my SS temp control is much better since I changed it. Link to comment Share on other sites More sharing options...
RedLabel Posted January 26, 2017 Report Share Posted January 26, 2017 Hello again.... i have again problems with my second Panzer box mod DNA200... I think fuse blow.... can you help me?I will attach some photos and a youtube video.https://www.youtube.com/watch?v=F1gENuPRP0gThank you. Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted January 26, 2017 Report Share Posted January 26, 2017 do you own a multi meter? you can check to see if there is continuity between the fuse. i would also check the individual cell voltages. could just be a dead lipo pack. what does EScribe's device monitor say for the 3 cell voltages and pack voltage? Link to comment Share on other sites More sharing options...
RedLabel Posted January 26, 2017 Report Share Posted January 26, 2017 Sorry but i don`t have tools to do that ... Here is a printscreen with device monitor. Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted January 26, 2017 Report Share Posted January 26, 2017 your pack is inline with the 3 cells. they also seem to be balanced. the lipo and fuse seem to be OK. will the device power on, even temporarily, if you HOLD DOWN the fire button (not just press and let go, hold the fire button in) and keep it held in? another thing to try, what happens if you plug in the USB charger and press the fire button? does the device display "check battery"? can you post a screenshot of your battery settings in EScribe? Link to comment Share on other sites More sharing options...
RedLabel Posted January 26, 2017 Report Share Posted January 26, 2017 If cable is not conected.....nothing appear on screen....black screen.If cable is conected....device it turn on and battery shows empty.https://www.youtube.com/watch?v=F1gENuPRP0g Link to comment Share on other sites More sharing options...
RedLabel Posted January 26, 2017 Report Share Posted January 26, 2017 When cable conected and i press fire it shows check atomizer Link to comment Share on other sites More sharing options...
RedLabel Posted January 26, 2017 Report Share Posted January 26, 2017 Question... when cable conected and device it turns on....when i`m screw an atomizer almost it burns my laptop....laptop display fluctuates and a lot of noise on speakers........i unscrewed it fast !!! .... what happened? Link to comment Share on other sites More sharing options...
RedLabel Posted January 26, 2017 Report Share Posted January 26, 2017 if cable is not conected and i LONG PRESS fire button.....nothing appear on screen... black screen ... Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted January 26, 2017 Report Share Posted January 26, 2017 what's happening is the mod, since it sees no battery, is dragging your laptop's USB voltage way down to the point of drawing too much power from the port when you try to fire the atty. basically it's trying to fire the atty by using the USB voltage instead of the battery. don't do that anymore or at least don't use your laptop as the USB power source.looks like you're running very old firmware. try updating to EScribe 1.2 SP5. the link is at the bottom of this post, in my signature.if that doesn't work, it could be the fuse. it's hard to tell from the picture but it does look like there is a little discoloration of the fuse.in that case i would open a help ticket with evolv. that link is also located in my signature. Link to comment Share on other sites More sharing options...
RedLabel Posted January 26, 2017 Report Share Posted January 26, 2017 Firmware update done. Lipo settings after updated firmware. Link to comment Share on other sites More sharing options...
RedLabel Posted January 26, 2017 Report Share Posted January 26, 2017 Something happened.... after i updated firmware... on my Device Monitor....cells voltages are not constant.... do you have any ideea? Link to comment Share on other sites More sharing options...
RedLabel Posted January 26, 2017 Report Share Posted January 26, 2017 CSV file from device monitor...panzer_dna200_problems.csv Link to comment Share on other sites More sharing options...
VapingBad Posted January 26, 2017 Report Share Posted January 26, 2017 Try bridging the fuse with a pair of tweezers to see if that fixes it. Link to comment Share on other sites More sharing options...
