Clairenix Posted December 5, 2016 Author Report Posted December 5, 2016 Hi Guys, I've restored config on my Finder 167 and thought it was going to be the same as out of the box but little did I know that it restored the chip into zero and had to set even the battery again...I've lost all the OEM configuration and even the case configs and I'm completely lost now.. What should I do? I've recently got the batteries running and can vape now but I'm not sure what else I should do..
retird Posted December 6, 2016 Report Posted December 6, 2016 If nobody here has the .ecig file for you then you could contact Thinkvape and see if they could e-mail you the .ecig file.....http://www.thinkvap.com/
Clairenix Posted December 6, 2016 Author Report Posted December 6, 2016 Thanks, I am requesting now.. Since I've resetted my DNA250 chip is there anything I should look out for? I hope I'm not doing anything dangerous.. (while waiting for the ecig file atleast..)
Clairenix Posted December 6, 2016 Author Report Posted December 6, 2016 Thinkvape has already replied to me, Here's the Ecig file that I got and I think everything's a-okay now! Finder_167.ecigFetching info...
black lace Posted December 6, 2016 Report Posted December 6, 2016 Clairenix said: Thinkvape has already replied to me, Here's the Ecig file that I got and I think everything's a-okay now! Expand does escribe not read and save your settings? To a seperate file in documents, so even if you delete escribe you will still have them to retrieve later. ..
Clairenix Posted December 6, 2016 Author Report Posted December 6, 2016 black lace said: does escribe not read and save your settings? To a seperate file in documents, so even if you delete escribe you will still have them to retrieve later. .. Expand I was not able to make a backup beforehand It was an accident per se; I mindlessly clicked it not realizing what I have done..
black lace Posted December 6, 2016 Report Posted December 6, 2016 Oh well you got it now, lol, How long where you using it befor you realised it had re set, i wouldnt have thought that fine case res and battery would have stoped you from getting a draw off it..
Clairenix Posted December 6, 2016 Author Report Posted December 6, 2016 black lace said: Oh well you got it now, lol, How long where you using it befor you realised it had re set, i wouldnt have thought that fine case res and battery would have stoped you from getting a draw off it.. Expand Immediately as it also deleted battery settings, luckily someone on reddit shared their 2 cell settings and it allowed me to vape on the raw DNA250 while i was at the office.
VapingBad Posted December 6, 2016 Report Posted December 6, 2016 As long as you have the correct battery type and cell number (2 or 3) the defaults are fine, you should only loose a little accuracy at low res and high power, nothing to stop you getting a decent vape.
Clairenix Posted December 6, 2016 Author Report Posted December 6, 2016 VapingBad said: As long as you have the correct battery type and cell number (2 or 3) the defaults are fine, you should only loose a little accuracy at low res and high power, nothing to stop you getting a decent vape. Expand The default didn't work since it had inaccurate wattage and capacity. It gave me a check battery error.
VapingBad Posted December 6, 2016 Report Posted December 6, 2016 Clairenix said: The default didn't work since it had inaccurate wattage and capacity. It gave me a check battery error. Expand Maybe it set it to 3 cell when you were using 2, the cell number is the most vital setting followed by the battery type.
black lace Posted December 6, 2016 Report Posted December 6, 2016 Yep i would have bet money on it being a defalt three cell as default and had no idear it was a two cell mod. so what is your maximum wattage on that then??
Clairenix Posted December 6, 2016 Author Report Posted December 6, 2016 Probably guys, On the mod? 167
zainalrockyou Posted December 8, 2016 Report Posted December 8, 2016 Clairenix said: Thinkvape has already replied to me, Here's the Ecig file that I got and I think everything's a-okay now! Expand Thanks I've got the same problem and now Solved! Got the OEM configurations again..
Clairenix Posted December 14, 2016 Author Report Posted December 14, 2016 Hey guys, got something to follow up this discussion. I've noticed the the OEM soft cell cutoff was 2.5v, I've read alot that it was recommended to be 3.09v.. Would you guys have any good guesses as to why it was 2.5v default?
Spector NS5 RD Posted December 14, 2016 Report Posted December 14, 2016 Clairenix said: Hey guys, got something to follow up this discussion. I've noticed the the OEM soft cell cutoff was 2.5v, I've read alot that it was recommended to be 3.09v.. Would you guys have any good guesses as to why it was 2.5v default? Expand 3.09v is common cutoff for lipos. I use 2.7v for the cutoff when I'm using 18650's. And 3v when I'm using a lipo. 2.5v Is too low for the device. The board won't operate under 2.5v.
Clairenix Posted December 14, 2016 Author Report Posted December 14, 2016 Mine seems to be operating just fine at 2.5v but ofcourse I'm still curious as to why it's what ThinkVape set it at. I'm planning on bumping it up at around 2.7-2.9 but I'm not really seeing its effects for the past few days I've been using it.
dwcraig1 Posted December 14, 2016 Report Posted December 14, 2016 If it's the same hardware cutoff as the 200 it won't make much difference if set below 28.5 volts. I don't know what the hardware cutoff for the 250 is though.
Spector NS5 RD Posted December 14, 2016 Report Posted December 14, 2016 Clairenix said: Mine seems to be operating just fine at 2.5v but ofcourse I'm still curious as to why it's what ThinkVape set it at. I'm planning on bumping it up at around 2.7-2.9 but I'm not really seeing its effects for the past few days I've been using it. Expand bump it up to 2.85, like dwcraig1 suggested. my point about the 2.5v value is, the board will not operate below that voltage. just because you set "2.5" in EScribe doesn't mean the device accepted that value. there's a minimum voltage the board needs to see before it'll even turn on. there's a difference between voltage at rest and voltage under load as well. also DNA's have a hard cutoff voltage (non adjustable) and soft cutoff voltage (which you're able to set in EScribe).
jacknb1ack Posted January 5, 2017 Report Posted January 5, 2017 hello, i just bought finder167 and did the same mistake as OP. sadly i still can't download ecig file from this forum even after my account is approved ... can some one send the file to my email please ? thanks you in advance
retird Posted January 5, 2017 Report Posted January 5, 2017 I'm beginning to wonder if your country's internet footprint, your browser, or your provider is blocking .ecig type files? I have Zipped the file so you may be able to get the attached zip file. Let us know if you can get this zip file? Finder_167.zipFetching info...
gregg raps Posted January 5, 2017 Report Posted January 5, 2017 Hi there....thanks. I cannot open the zip file.
retird Posted January 5, 2017 Report Posted January 5, 2017 Were you able to download the zip file from here?
gregg raps Posted January 5, 2017 Report Posted January 5, 2017 Yes but it won't open saying format not supported.
