Lpearce7 Posted October 25, 2016 Report Posted October 25, 2016 If this information is posted in another thread, please let me know. I wasn't able to find the .csv Discharge Profile for the following batteries:Sony VTC6Samsung 30Q (I have the triple 18650 .csv, but not the dual)I'm new to the battery analyzer, but have been using escribe for about a year now. I have several DNA250 & 200 mods with both 2 & 3 18650s. So I've been trying to get the most accurate battery reading for each and have only been able to find the .csv for the (3 18650) LG HG2 3000mAh, (2 18650) LG HG2 3000mAH and (3 18650) Samsung 30Q 3000mAh.Right now I'm only really using the VTC6 and 30Q. I don't really want to run the battery analyzer and was hoping someone has one this already.Also, what should the nominal pack voltage be? I've read conflicting opinions. Most say 3.7 x # of cells and some say 3.6. On all the datasheets, it says 3.6v. Last question, for 18650 mods, what is the recommended soft cell cutoff. Most of my mods came with 3.09 or 2.9. Thanks for any help!
Spector NS5 RD Posted October 25, 2016 Report Posted October 25, 2016 welcome to forum Lpearce7. can't help you with the vtc6 curve. i do have the curve for 2 vtc6's but you need the curve for 3. as for nominal voltage, it should be listed on the batteries. i use 3.7v. most 18650 manufacturers test their cells down to the 2.5v mark. for a dna 200/133/250, i usually have the CSC set to around 2.7v - 2.8v.
Lpearce7 Posted October 25, 2016 Author Report Posted October 25, 2016 Thanks. I've been reading threads on the forum for a while now. Finally have a question that I couldn't find an answer for.I actually do need the curve for the dual 18650 Sony VTC6. I have the VaporShark DNA133, VaporShark Vapor Flask DNA133 and Boxer Classic DNA 167 that are all using the VTC6. I would greatly appreciate that csv when you get a chance.Thanks for the help!
Spector NS5 RD Posted October 26, 2016 Report Posted October 26, 2016 okie dokie,here ya go........... THIS CURVE IS FOR 2 SONY VTC6 18650 CELLS THEIR CAPACITY (WATT HOURS) IS - 18.78 I USED A "CELL SOFT CUTOFF" OF - 2.6V. Sony VTC6 Battery Curve.csv you might have to remove the ".txt" extension and leave the "csv" part for it to be usable with the escribe program, i think. 2
Lpearce7 Posted November 24, 2016 Author Report Posted November 24, 2016 I would also like to get the csv. for the Sony VTC5A (both dual and triple 18650)Anyone have this or the VTC6 in triple 18650???
RichieM Posted December 7, 2016 Report Posted December 7, 2016 ChunkyButt200 said:okie dokie,here ya go........... (THIS CURVE IS FOR 2 SONY VTC6 18650 CELLS (DNA 133,167 COMPATIBLE ONLY) Sony VTC6 Battery Curve.csv.txt i think you have to remove the ".txt" extension and leave the "csv" part for it to be usable with the escribe program, i think. Hey chunky, thanks for sharing this but it doesn't let me dowload the csv, it says I don't have the permission to "perform this action". Can you please help me? Is it because I'm a new member?
lynchaniano Posted December 10, 2016 Report Posted December 10, 2016 2xSamsung 30Q/Therion133 Samsung_30Q_17.811Wh.csv
Lpearce7 Posted December 10, 2016 Author Report Posted December 10, 2016 Thanks for the 30Q profile!!
Sneak Posted December 14, 2016 Report Posted December 14, 2016 Downloaded the VTC6 profile for my Therion, works great! Cheers!
Almaz Posted December 24, 2016 Report Posted December 24, 2016 I can not download, although registered
Spector NS5 RD Posted December 24, 2016 Report Posted December 24, 2016 Almaz said:I can not download, although registeredwhat CSV's do you want? i can PM them to you. 2
Almaz Posted December 26, 2016 Report Posted December 26, 2016 ChunkyButt200 thank you after some time came and all downloaded.
Sylvain Cloud Vaping Posted January 2, 2017 Report Posted January 2, 2017 Hello good year 2017Nobody has CVS sony vtc6 please for three batteries
blaed Posted January 3, 2017 Report Posted January 3, 2017 i have an Hcigar VT167 (dna 250) with two Samsung 30Q batteries. what csv would work with this, or what should i change the values in escribe to manually?
Spector NS5 RD Posted January 4, 2017 Report Posted January 4, 2017 hi blaed. here is the CSV for 2 Samsung 30Q cells. Samsung_30Q_17.811Wh.csv (389 Bytes, 32 views)the watt hours for these 2 cells are 17.811 (input that number for the "capacity" in EScribe)
Strongice Posted January 5, 2017 Report Posted January 5, 2017 I have 1 pair of samsung 25r and 1 pair of sony vtc6 do i need to change the csv file every time i change my battery? And can anyone share me 2battery csv for 25r and sony vtc6 since i only got my therion166 two days ago thanks!
blevatron Posted January 9, 2017 Report Posted January 9, 2017 Hi all, if someone has a .csv file for 3x(18650) sony vtc5a, please share.Thanks in advance.
Astraion Posted January 14, 2017 Report Posted January 14, 2017 ChunkyButt200 said:..here is the CSV for 2 Samsung 30Q cells. Samsung_30Q_17.811Wh.csv (389 Bytes, 32 views)the watt hours for these 2 cells are 17.811 (input that number for the "capacity" in EScribe)Thanks for the csv file.I've found a post on vapingunderground with different values for the watt hours, and since 30Q's and HG2's are almost identical, I think this counts for both?In the mod section of Escribe there is a watt hour calculator. It should be set to 7.4v for battery pack voltage. You then set the mah of your batteries (HG2's are 3000mah). When you enter that, your watt hours should come out to 22.2 watt hours. This is basically so your battery meter will be accurate. If you find you still have bars left on your meter when getting the weak battery signal, just slightly lower your watt hours (I have my cell soft cutoff set to 3.09V so I won't get the full 22.2WH). Hope that helps.Can you tell me which one is more accurate?Thank you.
David89 Posted January 15, 2017 Report Posted January 15, 2017 Hello, unfortunately I can not download this curve, because my Accout is still not quite open, what must I do there to be able to download it.thank you
blevatron Posted January 16, 2017 Report Posted January 16, 2017 David89 said:Hello, unfortunately I can not download this curve, because my Accout is still not quite open, what must I do there to be able to download it.thank youJust wait a little. I thik now yor account already open.
praet0rian Posted January 19, 2017 Report Posted January 19, 2017 Does anyone know where to find the triple Sony VTC6 profile for my DNA250?
retird Posted January 19, 2017 Report Posted January 19, 2017 https://forum.evolvapor.com/topic/65641-topic/?do=findComment&comment=887339 1
