Buhar Abi Posted December 8, 2016 Report Posted December 8, 2016 Not Working... EScribe Versiyon - 1.2 SP5VT75 Nano Versiyon - 2016-06-05
agung indrajaya Posted December 8, 2016 Report Posted December 8, 2016 I tried to download the CSV file but it display warning, eventho my account has been aproved, could someone mirroring it?
Spector NS5 RD Posted December 8, 2016 Report Posted December 8, 2016 Buhar Abi said:Not Working... EScribe Versiyon - 1.2 SP5VT75 Nano Versiyon - 2016-06-05you may have to adjust the "punch", "preheat power", "time limit" and slightly adjust your "cold resistance" in EScribe. lock in a slightly lower resistance than what the device reads. for example,say your devices reads the coil at 0.145 ohms - lock in a resistance of 0.140 ohms or until the preheat begins to work. 1
voidovscy Posted December 9, 2016 Report Posted December 9, 2016 @ChunkyButt200, kudos to you sir! Your help is appreciated, but I should mention, that preheat will work when the device asks if it's a new coil you're supposed to choose "yes".
ron063096 Posted December 10, 2016 Report Posted December 10, 2016 cant download the csv file as well. i hope someone can send it to me via pm or email. thanks guys! i'm trying to add it to my vt75 nano.
sh8ker Posted December 11, 2016 Report Posted December 11, 2016 hi,can't get it to work on therion 133. tried using kanthal_a1_preheat.csvalso tried Nichrome_N80.csv but no luck! Thanks.
oyonk23 Posted December 15, 2016 Report Posted December 15, 2016 Makasih atas sharenya gan. saya dari indonesia. tidak bisa berbahasa inggris yang benar. terimakasih
Davinega Posted December 22, 2016 Report Posted December 22, 2016 Hello,I can download the preheat profile but I can't download the preheat csv. Can someone send me via PM? Thanks in advance.
Davinega Posted December 23, 2016 Report Posted December 23, 2016 Ah, another thing. It works! When the first time I set the csv and the profile, the preheat kicks in.But, after the second time I connect my Therion 133 to escribe and try to change the preheat time to 0.75 second, the preheat didn't work. Already try to revert it back to 1 second and "trick" the DNA with "new coil" stuff and still no luck. Is there any way to make the preheat work again?Thanks!
VapingBad Posted December 23, 2016 Report Posted December 23, 2016 Not sure this is your issue, but preheat only switches on after the board is sure it is a temp sensing coil, so never the first time after a new coil or reset.
Fethi Posted December 29, 2016 Report Posted December 29, 2016 Thank you for sharing this. Give a try but forum does not allow me to download the files
ardhifabel24 Posted December 30, 2016 Report Posted December 30, 2016 FtnBttL said:I downloaded the profile file but still can't download the csv file. It says you are not approved. Can someone send it to me with another way (email, drive or sth)?Me too, please send to my email
rainskov Posted January 3, 2017 Report Posted January 3, 2017 same here, cant download a thing (e-mail verified)someone please send me via e-mailthanks
zindhu2k10 Posted January 6, 2017 Report Posted January 6, 2017 i need download .csv file for khantal A1 and Nicrhome. thankyou
Valerou Posted January 6, 2017 Report Posted January 6, 2017 can't download .csv too, can someone help plz?
Sadhana Posted January 12, 2017 Report Posted January 12, 2017 I can't download ni80 profile provided in this thread. Would someone give me that file via pm or something?
aditbramanto Posted January 16, 2017 Report Posted January 16, 2017 Hi All, It seem i must download and upload the csv file on the mod, if there another way to setting preheat manually steps on escribe? Thanks and keep vaping mates
jajaden Posted January 20, 2017 Report Posted January 20, 2017 hi all unfortunately it seems my account can't download the csv and ecig profile could someone kindly upload those file to another hosting other than this forum (googledrive)
ejlover Posted January 26, 2017 Report Posted January 26, 2017 Today I have bought a Therion 166 with DNA250 chip on it. I was using a non DNA device and I could use preheat (set to a certain watt for certain time) and had no problems with a Kanthal. Just to use Temperature mode I have spent lots of money for a DNA device and I can not use Temp, mode on it Also I can not use preheat function too!!!!!!! I am totally disappointed with DNA device. It is worthless with a Kanthal wire.. I have tried everything and it not working..... My ressistance is constant so I am sure problem is not with the atomizer or resistance..At least tell me how to use preheat function please I need support in here
giz_60 Posted January 26, 2017 Report Posted January 26, 2017 Hi...Kanthal is normally NOT a temperature control wire...however there is a way to cheat & get the preheat function to work with Kanthal...go back to the very first post in this thread...download the kanthal_preheat.ecigprofile...load it into one of the proiles in your device & you should be able to set up preheat for Kanthal...
ejlover Posted January 26, 2017 Report Posted January 26, 2017 giz_60 said:Hi...Kanthal is normally NOT a temperature control wire...however there is a way to cheat & get the preheat function to work with Kanthal...go back to the very first post in this thread...download the kanthal_preheat.ecigprofile...load it into one of the proiles in your device & you should be able to set up preheat for Kanthal... I've tried it and it's not working My decice is on SP5 firmware does it affect it? Please help me to activate preheat somehow
joel Posted January 26, 2017 Report Posted January 26, 2017 You will need to manually tweak the resistance until it works. To do so, you will also need to lock the resistance. You do this while your device is connected to escribe software. Example, my resistance is showing 0.23. I will then try 0.20, 21, 22 etc until it works. You can also start with 0.24, .25, etc. Read the whole thread, it contains all you need to get this working. HTH, Joel. ejlover said: I've tried it and it's not working My decice is on SP5 firmware does it affect it? Please help me to activate preheat somehow
joel Posted January 26, 2017 Report Posted January 26, 2017 ejlover said:Today I have bought a Therion 166 with DNA250 chip on it. I was using a non DNA device and I could use preheat (set to a certain watt for certain time) and had no problems with a Kanthal. Just to use Temperature mode I have spent lots of money for a DNA device and I can not use Temp, mode on it Also I can not use preheat function too!!!!!!! I am totally disappointed with DNA device. It is worthless with a Kanthal wire.. I have tried everything and it not working..... My ressistance is constant so I am sure problem is not with the atomizer or resistance..At least tell me how to use preheat function please I need support in here You can use à SS wire that can be used in both watt and TC. Kanthal is not a TC wire. You can setup preheat as explained further below in another thread I just answered. There is a philosophy behind a DNA chip which explains why there is not a preheat functionality in the chip. If you search through the forum there is a thread talking about this. The DNA is a great chip, surely the best on the market that renders great flavour better than any other chip I have used (subjective statement based on my personal taste). Mind you, yihi chip I have not tried but only tested the TC on it from a friend and I do not like the "pulsing" it created while firing in TC mode. HTH, Joel.
