jinx'd
Everything posted by jinx'd
  1. you should have changed it to = don't be a dope, lol
  2. oh. thanx for your help
  3. temp protect. it did it last night. so i swapped to my QPmini that i use every day, it worked fine. then i flipped over the dead rabbit and sure enough, the 510's were filthy. i cleaned and all is working fine. so, i'm a dope, lol. the thing is this DR never leaks, or so i thought, it must be extremely small leak at the 510 pin.
  4. i never purposely set to TC cause i have no use for it. i will investigate the next time it happens.
  5. i just tried a diff rta on it, it is fine. but, sometimes it didn't do it. now i just put the DR on it, still ok. the coil remeasures a lot.
  6. it goes straight to temp mode, and idk how to adjust it to work in that. and even though the screen says watt boost, when i hit the fire button it says temp protect and doesn't fire. yeah, but the DR works fine on other DNA mods, Paranormal. and when i can get this one to work, it works fine.
  7. it goes straight to temp mode, and idk how to adjust it to work in that. and even though the screen says watt boost, when i hit the fire button it says temp protect and doesn't fire.
  8. hello i have a problem with this. i only use it 2 nights a week while i am having a few beers. i put the batteries in and it goes to temp control, all i ever use it for is watt boost. i have been taking the batteries out however many times to get it to sort out, but last night it would not. i also tried switching themes, didn't work. i never use temp control so idk just what may be happening here. please advise. thanx
  9. ok, thanx
  10. you do it all the time ?
  11. is it ok when the screen is on ?
  12. lets see yours, Bill. i buffed the carbon on mine. it does make a different.
  13. well, i rinsed it with water, very well. then i blew it out with canned air. then i took it loose and had a look. there was a few tiny drops of water, i tasted, but nothing to worry about. so, it is what it is, time will tell.
  14. Hello, Bill the wheel works fine, though i don't use it. but i do know that juice can damage contacts. and i really don't know how well the switch is sealed. i do know there is a larger outside seal, but what, if any, is around the shaft . and that "perhaps" the switch contacts get corroded enough to short 2 contacts and kill the chip.
  15. i have a TOP GEAR mod. somehow juice got down around the knob. i am not concerned about the knob, unless you have info on it. mostly what i want to know = if i cut the wires for the knob, it wouldn't effect the chip ? i am figuring not, but i don't want to assume. on the dovpo FB page, i asked about cleaning the switch. after 2 lame recommendations, i gave an explanation of my concerns, my thread was deleted.
  16. real hid and real snake skin
    nice 👍
    this is a nice basic and easy to see theme. i like it
    the green on this one is AWESOME !
    this one is cool, i like snake skin, and the color matches my Ultem Drone very well.
    this is VERY cool ! but, its nearly impossible to read the mods specs. if you LOVE OZZY, and "set & forget" your settings, this could be for you. 5 stars for the theme, 2 stars for functionality .
    very basic, but lots of Bling ! i like it. what is really nice about it = when tilting the mod "to & fro" the wallpaper always looks good.
  17. Why is your language better than mine? I'm on the Russian, I'm thinking on Russian, and everyone can use Google. Forum rules do not prohibit writing answers in your native language its is for me, because i can understand it.
