Everything posted by CMK
I've looked at the theme now - cruel. The theme, even if it is original from the manufacturer, has graphical defects as well as a functional error, which leads to a "white screen error": the "About" screen was simply forgotten without removing the link in the menu! Here the theme with the missing screen and a visually revised version. This is not only easier to read, but also sensibly shows the output voltage of all 4 cells separately. HOG 400 Default corrected.ecigtheme HOG 400 Default 2.0.ecigtheme @Gr13f If you are really interested, I can revise the optics (and perhaps functionally) a little further.
The theme, even if it is original from the manufacturer, has graphical defects as well as a functional error, which leads to a "white screen error": the "About" screen was simply forgotten without removing the link in the menu ! " Here the theme with the missing screen and a visually revised version. This is not only easier to read, but also sensibly shows the output voltage of all 4 cells separately. HOG 400 Default corrected.ecigtheme HOG 400 Default 2.0.ecigtheme
- 1 comment
- hog
- hammer of god
(and 3 more)
Tagged with:
If the theme corresponds to this, I am not surprised by the error - the "About" screen simply seems to be missing ... (I did NOT download the theme and looked it up in the ThemeDesigner, I do not have my laptop at hand) I would URGENTLY recommend a different theme anyway - this is a catastrophe for the eyes 🧐
Stock theme or custom theme? I'm assuming a custom theme, at least a modified theme. In this case, please contact the theme author.
replay ghumtl Paranormal/Therion 250c/75c
CMK commented on ghu-mtl's file in DNA 75 Color, 100 Color, 250 Color
Then we want to hope that the less experienced user doesn't think that the theme or even its mod are defective ... Very few theme authors think about such things. It is so easy to implement, especially with regard to the power bank function: Condition "capable" => no => hidden. And then the power bank function is gone from the menu - no questions, no confusion.
BMan1959, you have really great graphics - but unfortunately I see considerable flaws for my claim to a good theme on the functional level and this affects your entire current series. You use the tags "dna 75c" and "dna 100c" first in the posts. Nevertheless, both the menu item "Powerbank" and (constantly visible) the evaluation of 4 battery cells can be found in the theme without restriction. What shoud that? A car won't get any faster if I put a "turbo" sticker on but none is installed. So either separate themes should be created for the chipsets, or you can set about designing the theme in such a way that only what is actually available is displayed.
Technically, what are the differences between Boost Punch & Preheat Punch?
CMK replied to mix11898's topic in DNA 250 Color
I think I expressed myself ambiguously; the target temperature is not necessarily exceeded in the preheat phase. Even with a setting preheat punch = 11 (max), the temperature assigned by the chipset is below the final target temperature, for example target temperature 450 ° F + preheat punch 11 = preheat temperature 440 ° F. I assume that Evolv designed this precisely to counteract the re-heating of the coil. Ultimately, however, one of the developers would have to comment on this. In any case, I have not yet succeeded in setting the mod so that the maximum temperature of a puff matches the target temperature - UNLESS I go down accordingly with the output power. -
Even if the wattage is almost optimally adjusted to the target temperature, the maximum temperature will always be slightly above the target temperature, since the power supply is only reduced when the target temperature is reached and the coil continues to heat briefly due to its inertia. The average temperature will ALWAYS be below the target temperature, as the heat-up phase is also taken into account in the evaluation. In order to be able to optimally coordinate the power and preheat to the coil, in my current landscape themes in TC mode I always show the power actually used next to the target temperature, as well as the maximum and average temperature, directly on the main screen. I show the temperature of the preheat here, but when this is selected the display changes to the punch assigned to the temperature and the setting is also made as a punch (1 to 11). In this way, the internal dependency (Preheat-Temp <=> Preheat Punch) can also be clearly seen, as well as the influence of the target temperature on the presetting that I described above. -
In order to understand the functionality and interrelationships of preheat in TC mode, it is helpful to create a screen in the theme in which the target temperature, preheat temperature and preheat punch are displayed at the same time. Then you will see that as the punch changes, the preheat temperature changes in fixed steps. These in turn depend on the target temperature. I can only recommend this approach, it really creates a lot of understanding. -
As far as I interpret the photos correctly, different fields, even different screens are displayed at the same time, which should not be displayed at the same time; It is therefore not a matter of a fault in the display, but of the control. The error can only be in the firmware, the theme, or directly in the chipset. You can actually exclude the connector from the board.
For the actual function of the chipset, it is irrelevant from which mod the basic settings come. Here it is the factory settings of the Centaurus. The differences are - if made at all by the mod manufacturer - in the electrical correction values.
There are a lot of display errors, I would first go back completely to the factory settings of Evolv. You can load attached files with Escribe. Otherwise, an update of the firmware cannot do any harm ... 250C.ecig
permissible voltage differences when using several cells
CMK replied to CMK's topic in Batteries and Charging
The set of 2, which I was talking about at the beginning, is almost 3 years old ... So I don't complain if the capacities of the two deviate from each other as described. -
I have never heard that before. Not forbidden in the sense of "Evolv did not allow it", but if more than 1 battery cell is used, the batteries of the 75C (100C?) Are operated in parallel. They are not evaluated individually and therefore cannot be loaded reliably. In the extreme case - 1 new cell + 1 deeply discharged cell - an explosion can occur. -
Ok, that's the crucial piece of information, at least in terms of 250c (100c: "The DNA 100 Colour is powered by a single lithium cell and can also be wired in parallel configuration") Basically, I always have a few cells ready in the charger, in the mod I actually only charge when I'm traveling. Internal charging is actually only prohibited with the 75c and more than 1 cell (e.g. Therion 75c, or Paranormal 75c). However, I don't know anything about non-C chipsets. -
Hi everyone, I hope that the question has not been asked too often and that this is not the umpteenth question: When using several cells, it is normal to a certain extent that they age differently or have aged differently. Which (open circuit) voltage difference between the individual cells can be regarded as problem-free with regard to the risk of deep discharge of the weakest cell? As an example, I have 2 cells here and now with a total battery level of 30%. Cell 1: 3.66V Cell 2: 3.54V Both the same cell type / manufacturer. In my other pairings, the individual voltages are a maximum of 0.02V apart. Do I have to worry now?
82 downloads
Even if the theme looks like a pimped out stock theme at first glance, the actual operation has been completely revised and equipped with extensive functions to prevent incorrect operation. Furthermore, the entire boost / preheat control is also carried out on the main screen - only the control elements are displayed that are also switched on and off from there. The navigation is very intuitive and fast. Description_for _translation.txt You may also like:
