Spirometry
Everything posted by Spirometry
Therion DNA75 SS316L Issues
Spirometry replied to goldfish18's topic in EScribe, Software and Firmware
You are fighting refinement. The cold resistance between your first post and 2nd post are pretty far apart. Always mate a cold atomizer with a cold Mod. It is even better if you set the mod down for about 20 minutes afterwards(after the new coil prompt). Wait for refinement before settling on a temperature to vape at. Don't set your temperature at 455° then try to force your mod to vape at that temperature. With the tank you have and the power you have it set at, I probably would have it set between 480 and 520. The DNA won't remember the cold resistance when removing the battery unless you have the resistance locked in. Replace the batteries one at a time so you don't loose power to the board. -
The cold resistance is different on all three devices. Try manually locking in 0.273 on all devices. If that fixes it, you can just make an adjustment to the mod resistance.
Switching Married batteries between mods
Spirometry replied to OcEaN's topic in Batteries and Charging
If using the Reuleaux in a 2 cell configuration, then it's no problem. It is safe to switch a married set from parallel to series. -
Current displayed on the screen is the output current to the atomizer not from the battery. 65w and 17 amps comes out to about 0.225?, sounds about right if you are using a SS coil. The dna will read the resistance down to three decimal places. The screen only displays down to two decimal places. So if the last digit is near a 5, it wouldn't be to uncommon to see the last digit rock back and forth due to rounding off the last digit. Normally the resistance should go down after refinement. I wouldn't lock the resistance. Just set it down for about 20 minutes with the usb unplugged, then reset the temperature. Atomizer Analyzer is under the mod tab. It may be hidden. Options> User Interface> Manufacturer
Looks like some of them left with the dna 200 silk screening also.
Why can't someone come up with an SS316L profile
Spirometry replied to 2legsshrt's topic in DNA 200 and 250
Not temp limiting because you can't heat water past 212° F. You can increase the power to a point that the water doesn't keep the coil cool, but then you will see the temp keep rising until it hits your limit. So yes, it is effectively running in power mode, but look at the temp it is running at. I just wanted to show that the Temco wire with the Evolv profile was pretty accurate. If I had a nice straight line at lets say 260F, then you would know that either the cold resistance was wrong or the tfr curve was wrong. -
Technically you could, but I wouldn't recommend it. The battery fit is very snug and not the easiest to remove. Over time I would worry about damaging the battery wires.
Did a water test tonight. Single coil 24awg Temco ss316l, Vaporshark dna200, kayfun5 deck, Evolv default ss316 wire profile. After mating atomizer, I let it sit unplugged for 20 minutes for refinement. -
Yes, The setting is in the theme tab, at the bottom under "Look And Feel"
If you like a warmer vape, why not just turn up the temperature, why mess with the TCR? I'm just trying to get a better understanding of why guys want their device to read a lower coil temperature than what it actually is. -
Nothing wrong with vaping at 480F . 100% VG has a boiling point of 554°F I vape a kayfun5 with 50/50 at 410F I vape a aromamizer with max VG at 520F. PG/VG ratio, air flow and wicking have a lot to do with the coil temperatures.
v1.2 SP3 won't do anything for how a dna75 vapes with SS316. The changes in firmware only apply to the DNA200. 1.2 SP3 is still worth getting for some of the changes they made in Device Monitor.
Evolv and steam-engine use a tcr of approximately 0.00087-0.00088 for ss316. it can't be calculated exactly because they are curves and not linear. There is an option in escribe to create your own graph based on tcr. You should try creating your own wire profile with a tcr of 0.00092 if you want the DNA to mimic your SX.
DNA 200 Ti temp control config (single parallel )
Spirometry replied to Leon's topic in DNA 200 and 250
TCR/TFR is the same for single wire, dual coils, parallel, clapton and Gargoyle Hooves as long as you're using all of the same material. -
v 1.0.42 is for a dna200 only v1.0.56 is the official version for a DNA75 (it also works with the DNA200) This version doesn't come with the latest firmware. You need to download the updated firmware separately. v1.2SP3 is the official version for the DNA250 & DNA60 (it also works with the 200 & 75) It also contains the newest firmware for all the boards. Hopefully Evolv will make V1.2 official version for everything and Kill all the other links because they are confusing the hell out of the new users.
[EARLY] *** 2016-08-08 EScribe 1.2 SP3 *** Will work with all Evolv boards and will contain the latest firmware files for all the different DNA boards. Everything else on that page is for a DNA200
I realize it can't be added now with a firmware update. I was really referring to to design phase of the board.
The DNA200 has a balance charging chip on board. The input current information was coming from this chip. Since the Dna75 doesn't have balance charging, this info is missing. Im sure Evolv could've added this feature to the 75, but they were aiming for a budget board with escribe to compete with all the newer 18650 devices on the market.
I think they should just do some renaming. The menu item should read "Create TFR graph from TCR value" The dialog box should be titled "Enter new TCR value" Evolv then should change the default value of 0.006 to 0.000 or just leave it blank.
I think I found my charging problem with SP3 If I plug in the 2 amp usb with the cell voltages above 4 volts each, then it wont charge just like SP2 If the cell voltages are below 4v, then it will charge normally at 2 amps.
Still having charging problem with SP3. It is a little better than before. I actually saw it charge at 2 amps a couple times. Using a smaller gauge usb cable to limit amps, I can get it charge at 1.4 amps. Switch back to the Anker cable and che charging exhibits the same behavior as SP2.
