dwcraig1
Everything posted by dwcraig1
  1. The charger is a separate board for DNA60 and DNA60. Since the charger is not on the board there is no communication.
  2. So once that you familiar yourself with EScribe you might want to start checking out the boost feature. Very likely you will be able to tailor your desired vape with it.
  3. I think that if you change the wattage up to a whole number and want to change it back try this: Either go to select a profile and select the one that you are using or select a different one then go back and select the original profile. I think reselecting the existing profile will probably return it to your settings.
  4. What wattage does it show in Device Monitor when set with half watt settings? I did it with a DNA60 and it showed the half watt on the screen. I also did it with a DNA80C, set to 14.5 watts it showed 14 watts on the screen but 14.5 watts in Device Monitor. I also tried it with a DNA250 and got the same results as the DNA60.
  5. Once you get it setup in EScribe you will be able to switch between the profiles on the go. That will give you up to 8 different wattage settings.
  6. While not what your asking for here's what you could do to achieve the desired result. In EScribe create a profile for each wattage setting. Perhaps name them for example 6.2 watts, 6.5 watts, ect. Be sure to change all selected profiles material to watts and upload to device. Be sure to have boost set to zero unless you want it added. I hope this helps.
  7. Temp is hitting set temp almost immediately and throttling power down. There are quite a few variables involved here. Post screws not being tight enough is just one that we see often. 510 to 510 connections, ect. Your live resistance is most likely a false reading.
  8. Board malfunction, I doubt it.
  9. The TCR for 316 and 316L are so close that I consider them to be close enough to be called the same. Setting temp to 210 and getting 273 is puzzling to me.
  10. The next thing I would do would be to use Atomizer Analyzer to see that the atomizer is making good contact with the 510's positive pin at least one turn before the atomizer bottom out in the threads of the 510.
  11. I really need to see your Device Monitor showing cold ohms and live ohms when firing. Here is an image of mine, note that the live ohms on mine increase but then level out. The board determines temperature from the difference between the two readings. I suspect yours continues to climb till it hits temp setting.
  12. You show using a profile for SS316 but say that you are using Ni200 or Ti coils. What material is the coils that you are using?
  13. I have zero experience with Yihi but I dry burn every new or re-wick coil. Translation is perfect. You can post in your language if you wish. Google Chrome will translate upon request (right click)
  14. Is your cold ohms reading fairly close between your mods? Also check the live and cold ohms boxes and post another Device Monitor image firing.
  15. Start off by just using watts (watts for material) and no boost. Going by taste see how many watts your build is capable of. You are hitting your set temperature. Try increasing temp setting higher.
  16. What model mod is it and how is the battery door done? Is is a screw in cap or a battery door. While I can only guess from here I'd say there is a good chance the battery is not being held tight enough. If a cap it may bottom out in it's threads before getting tight against the cell or if a door, well same not tight enough. I expected it was a Dani mini but it appears to be another rendition.
  17. The option to re-boot it under the Tools/Diagnostics in EScribe.
  18. There are a couple things that I would try if it were mine. 1st I'd copy the .ecig file using EScribe. Using Escribe do a hard reboot. Still not good restore to factory defaults. Use Evolv's default theme. EScribe creates a backup so either with that or your saved ecig file you can always return it ti as before your changes were made.
  19. If possible return it to where you purchased it or to Vaperz Cloud
  20. Best when used in wattage mode but can also be used in TC. You need to use TC wire though for Replay to work properly.
  21. It will be listed as DNA60C and not Mission Droid. Try some of the backups, you can easily go back to what you currently have.
  22. If you have previously connected it to your computer EScribe has created a backup. Start EScribe , go to Tools/ Backup. Search by mod/board and date, apply, update to mod. As far as firmware. you should use the latest.
  23. I wasn't expecting to see a a post about a Darwin, ever. I suggest that you open a ticket with Evolv. Your cable and and any USB power source should do, must be more to the problem. https://helpdesk.evolvapor.com/index.php?a=add&category=1
  24. My DX200 (not DR200) was the earlier version. I still have the case and had a look at it just now. That plastic piece should have a sticker on it covering the screws that hold it in place. There are 3 on mine the same location and pattern as the board mounting holes. The three screws screw into three standoff screws which hold the board into the case.
