giz_60
giz_60 last won the day on January 13 2021
giz_60 had the most liked content!
4 Followers
    Texas
    Custom built, VT75C, Skar 75, Therion 166, Triade, VT75 Nano, Jac Vapour Series-B
9,569 profile views
giz_60's Achievements
Senior Member
Senior Member (3/3)
152
  1. Hi there, can u help me with check battery issue ? It's so random , mod did'nt fall . It's just random issue
  2. Any voltage over 4.2x is a good indicator of a bad board/charging circuit.
  3. You may have an issue with the Theme...can you post your theme? In Escribe, go to the Theme tab...click Save Theme & attach file here...
  4. Y Uou can only change the number of fire clicks (down to 3x, IIRC) to lock the device This will only help the battery indicator, fuel gauge, to be more accurate If a firmware update is available, Escribe will let you know and prompt to install
  5. At only .01 - .02 rise in resistance from a cold coil to hot, it would seem that you are not getting enough of a rise in resistance. If the board doesn't see enough rise in resistance in the first second or so, it will drop out of TC. For instance, my current SS316L coil is .178 cold & rises to .210 - .211 after firing. Have you tried spacing your coils? What kind of atty? Can you post a screen shot of Device Monitor while firing, with the following fields checked...Power, Power Set, Temperature, Temperature Set, Cold Ohms & Live Ohms...
  6. You can't use Ni200 material settings unless you are using the Ni200 coils...The info I previously posted was taken from Uwell's info on the Crown 3 coils & according to that info, the .25 & .5 ohm coils are better suited for wattage usage, not TC.... Edit:. Here is a response about a question of those coils found on another forum.... SS Coils on Uwell Crown have nickel legs, so they're to be used only on power mode because TC wouldn't read it correctly
  7. According to the info provided by Uwell on their coils, it seems that the SS coils you are trying to use for TC are better suited for wattage & the Ni200 coils for TC.... Uwell crown replacement coils use revolutionary food grade stainless steel. Standard 0.25 and 0.5 coils are made of SUS316 D-Grade Stainless Steel Heating Wire and use 100% Japanese organic cotton. Temperature Control coils are made with 0.2 Ni200 Nickel wire. 0.15 ohm (Ni200 – Nickel) 0.25 ohm (80 – 120W) 0.5 ohm (30 – 80W)
  8. In Escribe, go to the battery section of the Mod tab & make sure that it is set for 2 cell....restoring default in Escribe restores it to Evolvs default...3 cells...
  9. Or...you could open a ticket with Evolv & let them guide you....https://helpdesk.evolvapor.com/index.php?a=add&category=1
  10. Samsung_25R_18650.csv
  11. The .004 is NOT a live resistance reading, but rather what the Mod Resistance that is set at via Escribe...@retird was trying to get you to set it to 0 to show you that
  12. You can also fill out a ticket with Evolv & let them guide you...https://helpdesk.evolvapor.com/index.php?a=add&category=1
  13. Sounds like there is a connection problem between the board & the 510 connector...seems it is new, I would contact the seller about a warranty exchange...
  14. If you have a Paranormal, there is a known issue with them. Read this post...it can also be causing the problem you are describing.....https://forum.evolvapor.com/topic/69140-paranormal-75c-resistance-too-high-fix/
