* Time is centered in the actual themes!
Available in 6 colors: Black - Red - Blue - Green - Orange (Ultem) - White
I decided to re-design the iOS Theme for my new mod design. All the mix-colored heavy themes were just too much all the time, so I knew that I had to make something simple this time. I settled on doing a theme that Ι wouldn't get tired of looking at, using the controls of the iOS theme that I really love.
I started developing V2 of this theme with the addition of red in mind and ended up expanding the color options more. The soul of the theme is to be a single color, so now you can choose more than black or white. The Orange specifically was added to match my Ultem drip tips, that is why it is in a darker shade. V1 of this Theme was known as B&W, that name got left behind in V2. RIP
Main Screens
Ok, lets say your mod is now unlocked. These are the main vaping screens you're going to spend the most amount of time on.
Wattage: Temp Control: Replay Mode:
Menus
The familiar menus from the iOS Theme.
Coil: Preheat/Boost: Puff info: Settings:
Smart Watt Adjustment
Adjusting watts is different for every wattage range to cater both MTL and DTL vapers.
1-29.5W= adjusted by 0.5
30-99W = adjusted by 1
100W and above = adjusted by 5
(Need to register a wattage number before the change applies)
Choose how your Lockscreen looks
There are 3 options:
1. Date, time and battery
2. Time and battery
3. Just battery
Extremely accurate battery gauges. The battery will turn red when you are at 20% or below. Need to charge 'em once in a while!
Preheat On/Off Indicator
The speedometer's needle will move and turn red when Preheat/ Boost is on.
Swap battery % for time
I felt like the "time or battery %" option shouldn't be missing from this theme. Some people may be used to it from the iOS theme. The option to choose which one you prefer is once again here.
Color Mapping chart
Multiple Battery Volts
In this sub-menu, you can check individual battery volts for up to 4 batteries. Batteries are named 1-4 in order to know if one is misbehaving.
(Displaying multiple batteries is only supported by DNA 250C mods)
Edited by Tortuga
What's New in Version 1.2 See changelog
Big changes:
- New overlay. Main screen's most important data are in a border now. I got the idea from Herbestos' Shiny Yellow Theme that I like aesthetically. If you like this change, make sure to check out his theme.
- Changed "Preheat" icon since the thermometer may be confused with temp control. It is now a speedometer.
- When preheat or boost is enabled, the speedometer's needle turns red and goes to the right side as an indicator, emulating a speedometer. When it is off, it is on the left side and white.
- Changed "Coil" menu icon from resembling a Goon RDA to a Hadaly RDA.
- New overlay for "New atomizer" screen.
- Added 0.1 watt adjustment when below 15 watts. The 0.5 adjustment is now for 15-30 watts.
- Added 5 watt adjustment when above 100 watts in TC mode. I doubt that anyone uses TC that high, but if you do the option is there now.
Small changes:
- Redesigned "Battery Volts" info under "Mod Info" sub-menu. It now names batteries (B1-B4) when using a DNA 250C mod with multiple batteries. Also added more decimals for single (or internal) battery mods.
- Added more decimals in last puff info: Power, Ampers, Volts
- Fixed the temp units. They are now "°c" and "°f", as they should be. I had the degrees symbol on the right before... I blame my education.
- Under the "Coil" menu, the "Material" field now fits 2 lines of text.
- Highlighted non-selected sections are now a bit more discreet.
- Ohm value on main screen has a bit smaller and italic font now.
- Gauge bars are now visually smoother. More noticable if you add a wallpaper.
"Settings" icon looks smoother now on the Black & White versions.
With version 1.2:- Download
