What's New in Version 3.0 See changelog
New Version 3.0
Removed Status screen and replaced with Coil Info screen
When on main screen and not in active Replay saved puff, you can select ohm reading to shortcut you to coil info screen to remeasure and or fine tune coil ohm reading per a user request for more exotic coils.
Other visual improvements overall.
New Version 2.3
Left arrow takes you back one step at a time, right arrow takes you to newest puff.
New Version 2.2
Fixed Temp highlight issue on Puff Info screen
Added ability to change watts in Replay on Status screen
New Version 2.1
Further appearance adjustments overall.
Added ability to change unlock sequence to display screen
New revamped Version 2.0
Overall visual improvements and better refinement with removal of redundancies across screens.
Back buttons added back to Menu and Settings with round robin scrolling as it just seems more functional.
Added coil material to Profile and Status Screen for those who want custom profile names.
Profile screen now has a lock ohms option if needed.
Removed ohms measurement on Status screen as it can be done on Profile screen.
Device screen is a complete makeover now with power bank settings as well as individual battery voltages for up to 4 batteries.
About screen changed lifetime energy to lifetime puffs. Reset now takes you to separate reset screen to prevent accidental resets.
Reset screen added with current puff info, yes or no to reset, and reset counts.
New Version 1.6
Added punch / preheat in place of the status bar on the Puff Info and Status screen to better help dial in the perfect puff.
New Version 1.5
Further refinements to theme
New Version 1.4
New version 1.3
New version 1.2
With version 3.0:- Download
