What's New in Version 1.6 See changelog
New Version 1.6
Added punch / preheat in place of the status bar on the Monitor and Status screen to better help dial in the perfect puff.
New Version 1.5
Further refinements to theme
New Version 1.4
New version 1.3
New version 1.2
With version 1.6:- Download
