Evolv Default Enhanced 250C Theme 3.5
   (7 reviews)
Device screen now has power bank settings, and battery voltages for up to 4 batteries.
About Menu with Lifetime puff count, Theme revision,  current firmware, current revision, edition, current puff count, puff count total energy, and reset to take you to a rest statistics screen.
What's New in Version 2.1   See changelog
New Version 2.1
Further appearance adjustments overall.
Added ability to change unlock sequence to display screen
New revamped Version 2.0
Overall visual improvements and better refinement with removal of redundancies across screens.
Back buttons added back to Menu and Settings with round robin scrolling as it just seems more functional.
Added coil material to Profile and Status Screen for those who want custom profile names.
Profile screen now has a lock ohms option if needed.
Removed ohms measurement on Status screen as it can be done on Profile screen.
Device screen is a complete makeover now with power bank settings as well as individual battery voltages for up to 4 batteries.
About screen changed lifetime energy to lifetime puffs. Reset now takes you to separate reset screen to prevent accidental resets.
Reset screen added with current puff info, yes or no to reset, and reset counts.
New Version 1.6
Added punch / preheat in place of the status bar on the Puff Info and Status screen to better help dial in the perfect puff.
New Version 1.5
Further refinements to theme
New Version 1.4
New version 1.3
New version 1.2
  • Like 4
  • Thanks 2
maximumsport
Nice theme! Always liked the default theme just wanted all the hidden options in the theme rather than loading  escribe and editing those settings. Good to see this keeps everything transparent!
Keep up the good work!
Thank you so much for the review and I am glad you like the theme. I also really like the default theme and just wanted the added options without having to have my computer. I wanted to try to keep it simple and straight forward just like the default theme and hopefully the added status bars help with explanation of everything else. Thank you for your kind review and let me know of any problems encountered or any additions you would like to see.
MauriceValletta
Great Job in bringing all important options of Escribe (for my usage) on to the mod screen without altering the simplicity of the orginal Evolv-theme design. This is exactly what I was looking for, not fancy with graphics, eventually using up too many resources of the 250C, but simple in look, intuitive in use and comprehensive in function.
If I would have started at getting really into the Theme-Designer, it would at best have resulted in a theme like yours…
For my purposes I changed the increments of Watts back to 0.1 W, since my usage ist around 20 Watts, and small changes can count. But that modification is a game, compared to all the great Expansions you brought to the original Evolv-Theme.
Many Thanks and Greetings from Germany
John R
Great theme for those of us not wanting to stray too far from the default look and feel. I'd been messing with the theme designer for a few days trying to achieve a 1W increment as I find 0.1 increments meaningless. This theme does that for me without the headache of the designer, for which the documentation is sorely out of date and unhelpful.
Piyush
Just the theme I wanted. Clean as the original with added features. The 1W increment is a big plus.
McGee
One of the best (if not the best) themes available in my opinion! Great work, cheers for sharing bro 🙌
Thank you for your review and I am so glad you like the theme. I will continue to try to make it better and better for everyone.
Davebenge
Love the simplicity of this theme. Some of the others just seem a bit too busy.  Great stuff.
Thank you for the review. I love the simplicity but still having the available extra options of this theme. I do agree some of the other themes seem just too busy. I try to keep it very simple but functional in the back ground with all available options. Thank you for your request as I'm always open for requests as well to make it the best theme possible.
