Last Version Rev 2.8.9 - August 2021
Full options theme with Replay. Rev 2.8.8 - March 2019
Edited by Frank65
What's New in Version 2.8.9   See changelog
Hello
This is going to be last version of my theme(s) , unfortunately I have very short free time to work on it.
I've tested this for the whole last year , anyway If you find any bugs and\or misalignment I'm sorry.
  • Like 20
  • Thanks 14
  • Haha 1
Recommended Comments
GrumpyJoe
Frank,
I have loved your theme since day one, it has been my DNA75C/250C theme on all my devices!
I have a question however and it may be DNA related not actually your theme, but I have heard from a couple of people that REPLAY only works if the material selected is "Watts".  Your theme allows replay to work even if the actual temp metal you are using is selected (i.e. SS316 in my case).  When the metal is selected the temp is selected and then you can "Save" the setting to REPLAY.  Do you know if the REPLAY is actually working in this case or is it just acting like a normal temp sensing profile if you select a material other than "Watts"?  I am a bit concerned about using "watts" with something like Titanium for the REPLAY feature.
Many thanks and keep up the great work
Joe
Frank65
Hello
They're talking about this in this topic.
James from Evolve says :
Quote
Replay will play back whatever the original puff was. If the original puff was Watts mode, it will do that. The original puff wasn't a dry hit, so Replay will try to make sure the new puff isn't either.
(If, on the other hand, you really like dry hits, you can Save Puff on one, and it will be happy to repeat that for you too. ;))
Our default theme uses Replay in a Watts material profile. If you vape power controlled this is an easy step up to temperature protection.
(Yes, you can play back a temperature mode puff if you want, but then it's not as easy to use. Some people find it works better for finicky temperature-sensing coils, but it's a big gain for power controlled vapers mainly.)
My opinion is that replay is working in TC , and it records the last TC puff trying to replay it. Don't know if this answer your question , but yes I would use replay AND TC with Titanium coil 🙄
Foxium
Having a problem -
I'm in Replay profile (profile 1), watts set, and get a good vape. It shows the "Ready" with a green check, but after I take a puff and select this, the screen just blinks and it still says "Replay Idle" like it didn't save my puff. "Ready" is still displayed.  Any thoughts?
Frank65
Hello
Probably your coil is not replay compatible , what material are you using ? Does the screen shows Save icon ?
Edited by Frank65
  • Thanks 1
Foxium
It's the pre-installed coil that the Smok Resa Prince atomizer comes with. From what I read online, these are Kanthal.... I think I just figured out the problem then. Thanks for the help anyway :D
simy799
Sei un grande... il miglior tema in assoluto. Grazie per il tuo lavoro!
  • Thanks 1
vaperneto
Hi  Frank, first of all thanks for the great theme.
I just upload the 2.86 version and was playing with pre-heat with a SS coil and profile.
 Now when we change either temp or punch in the pre heat screen both change, for example, if punch 6, temp 183C, punch7, temp 191C.
Is that right? they should be linked this way?
Thanks
Frank65
Hello
Yes that's correct , it was wrong in previous versions , now it should work as expected.
  • Thanks 1
vaperneto
16 horas atrás, Frank65 disse:
Hello
Thanks Frank,
The way I see in Escribe is that you should choose either punch or Temp to tweak, ie, if you choose one the other should be disabled.
I might be wrong but anyway have a look and think about it
Frank65
4 hours ago, vaperneto said:
Thanks Frank,
Yep you're right , on Escribe you can choose punch OR temp , I will check for a solution on new theme revision. Thanks for finding this bug !
Hearts
Thank you @Frank65 for constantly working on this & updating us! My sincere thanks!
  • Thanks 1
FrankV
Hello Frank! Could you tell me how I can get the lock feature to come on when I'm on the change resistance page? Not sure if this is specific to only TC types of coil materials but I tried it with a SS316L and a Kanthal type of material with no luck. I can change the resistance and I see everything on that page except that lock button. Thats a huge deal for me especially when I'm trying to run replay mode with SS316L material as it changes resistance a good amount as the material gets warmer. Any help on getting this feature to come on or explain how I can lock the resistance in would be appreciated! Im sort of new to DNA devices so forgive me for the new guy questions :)
Edited by FrankV
FrankV
One last question. How can I change the time the screen goes into idle mode? I would like for the screen to stay on for a bit longer before it blacks out. Im constantly having to push a button to keep the screen from going into idle/sleep mode. The screen itself isn't locked or anything its just going away after only a couple of seconds. Thank you for your help!
Frank65
Hello
To lock the resistance : from  the main menu select the ohm values and click , you go in the coil menu (see below) , where you can lock the coil
You cannot do that directly from the theme , but from theme designer :
open the theme with theme designer -> Appareance menu -> Fading -> Active time (modify this field as you wish and save\upload theme to your mod)
@FrankV
FrankV
Thank you for your help Frank! So I fixed the fading time and I appreciate your help. I’m still having issues not locking in the resistance on replay mode. I see it in the SS316L profile, but I don’t see it in replay. I just built a dual SS316L alien coil and the resistance jumps around as it heats up from .16-.18 ohms. Just curious if I can sample the resistance when it’s cold and lock that in while doing replay mode?
My other her issue is the theme doesn’t wake up instantly when I press the fire button. After multiple fire button presses, it will wake up but it has a lag from idle to active mode. The device isn’t locked it’s just idiling and I’m not sure why it won’t wake up quickly. Any help?
Thank you you again for your help!
Frank65
Hello
I'm not sure to understand 100% , but as far as I know no locking is necessary in replay mode. Said that , you see no lock icon with that coil because the firmware doesn't recognize it as a temperature sensing material. Try with a simple TC wire and then you will be able to lock it. The lock icon in the theme is hidden if "coil temp sensing material" is "untrue" .
I think this problem is firmware related , not theme.
Take a look at this thread , there is a patch you can try (at your risk :) ):
FrankV
9 minutes ago, Frank65 said:
Hello
Thank you for your help Frank! I really like your theme. Very nice presentation and easy to navigate through.
So I do have a temp sensing coil installed and it will let me lock my resistance on the SS316L page but I don’t have that option on the replay page. On the replay page, I see my resistance reading go from .159 to 0 sometimes or jump up to .185. I don’t understand why this happens. But every time I let off the firing button, the resistance jumps back to what it was detected at, .159.
So I don’t understand why I can lock the resistance on the TC SS316L page but I can’t do it in replay or watts mode. I’m not sure if it’s not meant to be this way but I wanted to let you know this is happening to see if you can replicate this. You can lock the resistance in on the replay profile inside escribe but I can’t do it on the mod.
The replay mode works fine so I know it’s detecting a TC coil material. Not sure what the problem is. Any help is appreciated!
I just was reading that thread in the forum haha! That’s funny you just posted it. I’m glad it’s no hardware related and I hope hey get it fixed soon. Thank you again for your help!
Frank65
Yep that's true I can replicate that. That's strange because in the theme the only condition for lock icon to be hidden is temp sensing material is not true  and this condition is true if replay is working😲
Anyway , if you remove the above condition , you can lock the coil no matter what , I've attached a modified theme for you , please check and let me know if it works.
Regards
TEST_LOCK.ecigtheme
FrankV
Thank you! I downloaded the test theme to my device and it let me lock the resistance but the device is still showing a different resistance as I Vape on it. Not sure if this is normal or what. But it did let me lock the resistance in yet the mod still wants to fire at a different resistance. Not sure why but that’s what is going on.
FrankV
Here are some pictures to show my device and how as it heats up, the resistance changes. It starts at .159 ohms and works it’s way higher.
Frank65
Hello
I think that when you fire it the resistance impedance getting higher is very normal .
Actually I'm vaping on a ni200 0.25ohm coil in TC and when I fire it jumps to 0.45ohm , locked or not.
I'm not a DNA guru , been reading this : https://ziggicig.com/why-does-my-coil-resistance-keep-changing/ 😁
Sorry ,maybe if you ask directly in the forum I'm sure you can get better help !
FrankV
I think your right. Biggest thing is the mod dies return to its original resistance value after I let off the firing button. As long as it does this then I know it’s not a build issue or anything wrong. I’m wondering though if the mod fires at the initial resistance or if it fluctuates as the live ohms changes during the vaping experience.
Thank you again for your help! I do like having the lock feature you added and how you got rid of that rule so I’m going to run with your test theme for a while :)
FrankV
Hello Frank! My apologies for all the questions. Is there anyway I can change the replay Watts units from .5 to 1? I believe it was like this before the test theme you sent me. Not sure. Thank you for your help! Oh and the idle issue is getting solved on the next SP. Evolv is also giving out a beta firmware to users with the issue of not waking up. Incase anyone is wondering if it’s hardware or software related. It’s definitely software and a fix will be here soon! Thank you again for a great theme! Oh BTW...what happened to the paranormal logo that was on the original theme? Mine shows a different image now on the lock screen 😀
FrankV
Fixed the .5W step issue. When I turned it on, it switched to 1W so my apologies for not noticing this.
Edited by FrankV
