I've noticed the DNA 60 screen in my delro is at what appears to be maximum brightness when firing. I'd prefer it dimmer to save battery life (2200mAh lipo) but don't like stealth mode.
I've messed with the Brightness settings in Escribe and they upload and appear to operate as they should - except the Firing brightness. No matter where I set it (currently at 6%), it stays at maximum brightness while firing.
Can anybody help?
I've attached a screenshot of the Escribe Screen page.
DNA 60 bright screen while firing.tiff
That's interesting and makes me feel a bit better that my setup doesn't seem to be faulty. I'm sure you're right about the battery savings but with this little lipo I'm trying to squeeze out as much life as I can.
I'll try that link.
Thanks for the welcome .
Edited by Pigs
By not having a DNA60 I might suggest starting a Ticket with Evolv.  Explain your situation to them as you did here.  They are really good at replying back.  Click on the link in my sig line below. The link to the right of the red wording.  Fill out the form and send it.
  • 2 months later...
On 6/15/2022 at 11:59 AM, Pigs said:
Thanks. I've already started a ticket - hopefully they'll get back to me soon.
Hi...sorry for bring up this few months old post...wanted to ask if you get any news from Evolv...regardless the max brightness while firing (DNA60)...?
TIA
  • Like 2
Wow! You're right. I just checked one of mine. The only setting that works (set to) is off while firing. Otherwise it is at max brightness. It must be a firmware bug.
This one is running SP6.1 INT (Device Manager).
Edited by BillW50
  • Like 2
TIA
Thanks for your interest. No unfortunately they didn't get back to me. And just now seeing Bill's post I guess I'll just have to live with it unless Evolv fix the bug. I'm also running SP6.1
  • Like 2
Thanks Bill. I just set it to off while firing. Best solution for sure.
Recently bought SXK BB DNA60 and I'm noticing this behaviour too...was searching for the answer/solution and stumbled upon this thread...I'm on version 1.2 SP6.1 INT
Sidenote: that's pretty bad news to know they ( Evolv) didn't get back to you after 2 months...🙄 still hoping they working on fixing this!
  • Like 2
It doesn't make any sense to have a slider in EScribe when all you can have is full brightness or off. Why not replace the slider with a switch instead? And why not have it adjustable like expected? This way it has a cheap Chinese engineered feel to it.
I also tried SP3 (an older firmware version) to see if that one does the same full brightness or off and it does.
  • Like 2
@BillW50 , I didn't write that datasheet BUT it's there. And that's why I posted the image. I'm sure by now both you and @storm119 have already opened tickets at the Help Desk, right?
  • Like 3
