Hello,
I've bought a Dovpo Top Gear mod last month, and since yesterday I can't unlock it (video 1), and when I manage to unlock it, sometimes it loops in the menu and I can't do anything (video 2)
What I've tried:
- Reset parameters on Escribe
- Remove the batteries for 30 minutes to erase memory
- Hard reset on Escribe
But the problems are still there ..
What can I do ?
Here's what I would do with the mod plugged in.
First , Start escribe -> Safety. Look at what the current unlock sequence is.
Then the 'Device Monitor' tab (up top)
DM ->Down on the bottom line, Just to the right of the date it should say buttons. If you now (on your mod) click the button sequence shown from the safety tab, that should show up beside the 'buttons' word
IF you DO NOT see the button you pressed, you can click the word 'buttons' and over to right side of the DM screen you'll see 'fire' 'up' 'select' 'down' appear. You can mouse over and click those
PS Neither of those .mov files worked for me
Let us know how you make out
Thanks you @Wayneo,
Here is a working link for the videos: https://imgur.com/a/5tMuZNt
I've checked the sequence, it's the default one: FFFFF
During the monitor, the button indicator is: Down
When I press the fire button on the mod, it says Down, Fire
I guess it means the down button is constantly firing ? That would explains why the menu is looping and why I can't unlock the device
Is there a quick fix to do in the software before opening the mod ?
I guess the suspect is the wheel on top, e-juice often get there
There is no software fix. If it were me, I'd do a complete delete of that top gear/thing
